TURN SIGNAL RELAY
Discussion in 'XJ Technical Chat' started by tebo, Apr 5, 2008.
  1. Gamuru
    Gamuru Guest
    Granite Falls, WA
    A prototype was built and sent to Len (chacal) for testing. Here are the results:
    I believe we are looking at electronic LED-rated flasher relays to see if one can be modified to work with the self-canceler unit on these bikes.
    Right now, we have a like-OEM electronic flasher that will work as a stock flasher replacement. I'm waiting to hear from Len which direction we will go next, whether it be with an LED-ready flasher or offer both or neither.
  2. flash1259
    flash1259 Member
    W.R. Wisconsin
    I found this information on the turn signals auto cancelling feature:
    I recently restored an '81 XS650 and the turn signals would not cancel automatically like they are supposed to. I immediately suspected the little black box that is the cancelling unit. Having several other '81-'81 Yamaha's to test with I tried the suspect unit on another bike and it worked perfectly. Next I pulled the speedo out of it's cover and found the sensor was not in place as it should be. It is a black plastic piece with two wires attached and pops into a slot just below the speedo lightbulb. The sensor is a magnetic reed switch that closes when a magnetic field comes close to it. The speedo works by spinning a round magnet inside a cup attached to the speedo needle and the turn signal sensor sits close to this magnet and switches on/off as the magnet rotates telling the turn signals that the bike has traveled so much distance. After repositioning the sensor and having it still not work I looked closer and saw that the reed switch was broken. The reed switch is sealed inside a glass tube with an inert gas so the contacts never corrode or get dirty. I found a new reed switch at an electronics shop for about $1.50 and soldered it back in place, assembled the speedo and still my signals would not cancel.
    The whole history of repairing this bike had been one of finding odd problems where every possible part had already been replaced by someone (usually incorrectly) except for the actual failed part. I decided the sensor being out of place and broken only indicated that someone had already tried their best to fix the problem and broken it in the process.
    I observed that all of my other Yamaha's will cancel the turn signal when the key is turned off and back on again. This particular one did not do that, turn the key off and back on and the signals started flashing again -- aha, a clue! I took the switch apart and saw how it works. A slider switch connects left or right signal and stays slid to whichever side you last selected. Only when you push the turn signal button in does it re-center the slider. There is a copper plate under the selector lever with copper leaves on either side of the inner part of the lever. Looking at a good switch I saw that these leaves do NOT contact the lever except for while the lever is pushed fully left or right - on the malfunctioning bike these copper leaves were touching the lever all the time. It turns out this copper piece is a switch to allow you to start the turn signals working the same direction again even after the canceller has stopped them. With the copper leaves touching all the time the canceller thought I was holding the lever in left or right position and so it kept the signals flashing. I simply bent them out a bit to the proper location (so the lever just touches them when pushed fully left or right) and finally everything works perfectly.
  3. Gamuru
    Gamuru Guest
    Granite Falls, WA
    That sounds about right. The turn signal switch is just a momentary switch.
  4. kd5uzz
    kd5uzz Member
    Sorry to chime in so late in the game, but I have a question. The flasher unit is designed so that when you close a switch it starts blinking until you either open the switch or until it receives a signal from the canceling unit, correct?
    Once the canceling unit is activated it puts a high 12v on the 3rd pin of the flashing unit, and keeps that signal there until the blinker switch is opened by the rider pressing it, correct?
    IF this is correct, then you could say the entire system acts like a normal blinker relay that is controlled by an scr. With an scr you apply power and it stays engaged even after the input is unengergised. The only way to unlatch it is to remove power. If your power to the SCR was controlled via a NOR gate when you apply power to the 2nd input to the NOR it would cut it's output.
    If this is the case, part count would be low (SCR, NOR, a few transistors, and a 'normal' blinker relay), and could be made quite small. I wonder if it could be small enough to fit into the existing socket, with a new 'normal' socket on top...
    I'm going to go see about drawing a schematic...
    Also...you could put any blinker relay in...one for LEDs or normal lights.
  5. kd5uzz
    kd5uzz Member
    Maybe an SCR isn't the optimal choice. Still working on it. Did anyone ever figure out how the canceling unit is deactiaved?
