Turn signals as running lights
Discussion in 'XJ Technical Chat' started by Michael R Bernardi, Oct 3, 2020.
  1. Michael R Bernardi
    Michael R Bernardi New Member
    chicago
    Searched around, but could not find an answer.......
    Are the turn signals supposed to be lit up as running lights on a 1982 xj650 maxim ?
    I have an 83 Honda, and those are lit up.
    Thanks for any response
    no the bulb is a 1 filiment bulb on the xj650 )550 and 750) as well.
    you can install the dual filiment style lights if you want.
  3. k-moe
    Dual filimaent lights require a dual filiment socket, and some minor wiring changes.
  4. Michael R Bernardi
    chicago
    Thanks for the quick response.
  5. Jetfixer
    I have 3 wire turn signals with dual element bulbs , I have these wired to the low beam of the head light , these light up and go out when high beam is switched on .
  6. Polock
    a turn signal that is always on and blinks off doesn't sound hard on paper but might not be legal
  7. k-moe
    Running lights that serve as indicators are legal per federal DOT. State laws may vary (but shouldn't).
