Turn signals not working
Discussion in 'XJ Technical Chat' started by Timmy89, May 17, 2022.
  1. Timmy89
    Timmy89 Member
    Michigan
    So I have a 1982 Yamaha XJ 650 maxim. Got the bike. Turn signals don’t work. I believe they are wired correctly. I attached some pics to show what the turn signal wire. The brown wire on each turn signal are not connected. I don’t even know where to begin.
    thanks for any info
    235797FC-EE4D-43D6-AA43-E35CDD7D218B.jpeg 235797FC-EE4D-43D6-AA43-E35CDD7D218B.jpeg 39ED2ABF-5A26-44F8-B225-EFADD5A25EEB.jpeg
  2. Dan Gardner
    Minneapolis, MN
    This photo shows what the stock connections look like, if that helps. You can see the sort of "two wire" connector connecting to the single wire that is the turn signal. In other words, the connection kind of forms a "Y".
    Timmy89 likes this.
  3. Timmy89
    Timmy89 Member
    Michigan
    Thank you for the info
  4. Timmy89
    Timmy89 Member
    Michigan
    1852AB4E-D28F-4D32-813A-ED57B6CA181E.jpeg Found two connections that that need to be re soldered
    Cheri Lynn and Huntchuks like this.
  5. Timmy89
    Timmy89 Member
    Michigan
    Getting no power to the turn signals at the fuse box
  6. Rooster53
    You had a similar thread on turn signals before:
    https://www.xjbikes.com/forums/threads/turn-signal-issue-help.101149/
    Did you follow through with any of that - changing bulbs or changing flasher to a type that works with the lower wattage?
    That's a pretty common failure on the switch, hopefully it's all you need
  7. Rooster53
    That looks like R/Y, which would be headlight circuit - should have 12V though if the key is set to "ON" and the main fuse is good
    Signal wiring (turn signals) are Brn
  8. Timmy89
    Timmy89 Member
    Michigan
    I forgot all about this post. Sorry
    I’ll retrace my steps with the older post
  9. Rooster53
    The main take in the other thread was you can't run low wattage bulbs with the stock flasher, so just keep that in mind as you sort out the wiring and switches
    Timmy89 likes this.
  10. Timmy89
    Timmy89 Member
    Michigan
    So traced some of the flasher relay I believe from the wire diagram. And they are just cut. They go no where. Is there anyone that can tell
    Me where the flasher relay would be on my bike
  11. Rooster53
    https://www.xjbikes.com/forums/threads/the-ultimate-relay-switch-sensor-and-diodes-guide.27543/
    "XJ650 Maxim and Midnight Maxim models:
    Flasher: near the steering headpipe, on right side frame rail, under the right side ignition coil.
    Flasher canceller: under the rear of gas tank, behind ignition coils
    Starter motor solenoid/relay: on right hand side, attached to and behind the battery box.
    Diode block: inside the headlight housing.
    Starter/Ignition cut-off relay (no color): behind the turn signal self-canceller. (note: the drawing and the description in the service manual is wrong).
    1980-81 Sidestand (kickstand) relay (blue): did not use.
    1982-84 Sidestand (kickstand) relay (blue): frame bracket outbound of LH frame tube, just behind the left ignition coil.
    Headlight relay (yellow): behind the left frame side cover, on the plastic regulator-rectifier mounting plate. (note: the drawing and the description in the service manual is wrong).
    Neutral switch: in a hole in the bottom of the crankcase, just "outside" of the oil pan, on the bottom of the engine, up inside a recessed "well"."
  12. Timmy89
    Timmy89 Member
    Michigan
    Thank you very much rooster i appreciate all your knowledge and help
  13. Timmy89
    Timmy89 Member
    Michigan
    So do you see a flasher relay. Because I don’t think I do
  14. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    just a note about your testing, in the picture with the " digital multimeter"-- DMM, the black (negative) lead from your DMM should go onto ground, to check for 12v at the live wire
  15. Rooster53
    So I don't really think you should expect to find one when you showed us the cut wires in post #10. You will have to repair those wires by adding a connector or terminals and then installing a flasher relay of your choice. If you look up under the frame tubes just above the valve cover you should see a bracket welded to the frame where the original flasher relay hung
  16. Timmy89
    Timmy89 Member
    Michigan
    I’m gonna try working on it tonight
  17. Timmy89
    Timmy89 Member
    Michigan
    Thanks I’m new to this
  18. Timmy89
    Timmy89 Member
    Michigan
    Thank you for all of your help. I fixed my turn signals
    Huntchuks and Rooster53 like this.
