Typical add on parts?
Discussion in 'XJ Technical Chat' started by flatheadsix1949, Oct 14, 2015.
  1. flatheadsix1949
    flatheadsix1949 Member
    Ohio
    I have the opportunity to get some motorcycle parts for my '82 xj650 for really cheap; aftermarket and maybe some replacement parts. I am trying to compose a list of things I need, but me, not knowing much about these have a few questions. First, are there any usual aftermarket parts that people add on to these bikes to "update it"? and also, is there a set of aftermarket coils that work with the TCI/CDI ignitor unit? Finally, I am thinking of getting a shorter set of rear suspension shocks to compensate for my short stature. Are there any particular brands you guys recommend? Thanks.
    click the logo upper right xj4ever start a conversation with Chacal he has the coils setup you need.
    did you try adjusting the shocks as advised in your other thread?
    whats your inseam measure at?
  3. flatheadsix1949
    Ohio
    Going to, I have to get home to do it. at college right now I'm going back this weekend. Inseam length (from floor to top of leg) is about 29.5"
  4. Polock
    coils with 3 ohm primary resistance is what you need, the trick is getting them to fit in the space you have.
    you might want to look for steering head bearings, wheel bearings, any exhaust parts.
    if it's rubber or shines, buy it :)
  5. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    New parts or used or
    Nos? Right side covers R hard to find, and so are carb boots (manifolds). Even if you don't need 'em, someone else here might, so you could help a bro out, AND turn a profit!
  6. flatheadsix1949
    Ohio
    are the carb boots also called the diaphragm? I'm not quite sure what you are referring to.
  7. Busted Knuckles
    Busted Knuckles Member
    North
    The boots are also called the manifold. They're the rubber section that connect the carbs to the motors. I'll be ordering myself some in the near future.
  8. chacal
    rubber tubes from the carbs forward to the cylinder head = INTAKE MANIFOLDS
    rubber tubes from the carbs back to the airbox = AIRBOX BOOTS
    rubber seal surrounding/attached to the internal piston inside the carbs = VACUUM PISTON DIAPHRAM
