Uk 1984 XJ900 tail light not working, brake light fine. Help please
Discussion in 'Other' started by mxlower, Mar 31, 2018.
  1. mxlower
    mxlower New Member
    UK
    Hi all
    Just been given an xj900 1984. Not been run since 2005! Got the engine going and new brake lines fitted. Got a problem with the rear light. Brake light works fine but no back / tail light. Any suggestions greatfully received. Be warned I’m a beginner with bike electrics so please be gentle. bulbs checked and fine
  2. Rooster53
    The tail light typically works off a separate contact in the ignition switch - either a L or L/R wire.
    Do you have a "P" position on the ignition switch? If so try this to see if the tail light illuminates. If it does, then the wiring would be OK and likely an issue with the ignition switch or light switch. If you have the light switch try it both in "PO" and "ON" to see if the tail light will illuminate.
    mxlower likes this.
  3. mxlower
    mxlower New Member
    UK
    Don’t have a p position on the ignition. Tail light doesn’t work in either side light or full on. I’ve got a multimeter coming tomorrow so I can properly test the power going to the actual lights.
  4. mxlower
    mxlower New Member
    UK
    Found a broken wire from the light switch. Replaced and all working fine. Thanks for the advice
    Rooster53 likes this.
