Ultrasonic Carb Cleaning with Simple Green Warning
Discussion in 'XJ Technical Chat' started by Dstrong77, May 25, 2018.
  1. Dstrong77
    Dstrong77 Member
    Iowa
    Hello,
    My 81 xj 650 maxim is currently down. I have another post on that matter here: https://xjbikes.com/forums/threads/xj-650-maxim-sputtering-on-acceleration.119368/ like to do everything the hard way so I usually only read about 75% of the instructions. It worked in college but hey I'm learning.
    Anyways while trying to chase down a possible vacuum leak I went back to In the church of clean and really wanted to get it right this time. So I got an ultrasonic cleaner. Googled around for "motorcycle carb cleaning ultrasonic cleaner" and seen people using simple green. So without reading all of the information available, I determined that simple green was safe and bought a gallon. I then set my first carb in an undiluted solution and set it for 2 hours.
    The finish of the carb has now changed to a dull oxidized look. I am unsure if I have damaged it or if it will be ok. After more digging after the fact that simple green will work in an ultrasonic however just set it for a few minutes.
    Has anyone else had this happen and did it affect the carb at all? Slides in particular? There is a pic for comparison
  2. Jetfixer
    Certain chemicals will cause a chemical reaction and etching . Try washing in hot water and dawn dish detergent I think you will be ok ..I expected it to be worse than your thread ...I use a one gallon of Berrymans carb cleaner it comes with a basket inside can it is safe to soak parts in but that is just me . :D
  3. Polock
    now use the ultrasonic cleaner to get all the simple green out. just wipe the slide bore out, don't try to make it shine again. i don't think you killed it, but you didn't do it any good.
    did you take the seals out?
  4. Dstrong77
    Dstrong77 Member
    Iowa
    Yeah seals are out. Live and learn. Just thought I would try to help the next guy.
