Ultrasonic Cleaning Solution
Discussion in 'Hangout Lounge' started by RTB, Jun 21, 2017.
  1. RTB
    RTB Member
    Rockingham Va
    I just ordered an ultrasonic cleaner to clean carbs with and my question to you great minds is what solution works best to clean carbs with? I've read many different types of solutions to use but was curious if anyone on here has used one and what they used?
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Is the ultra-sonic tank also heated?
  3. k-moe
    Pine-Sol (the original blend).
    But I prefer using Beyman's Carb Dip to using an ultrasonic system (just a prefrence, not a critique).
    Stumplifter likes this.
  4. RTB
    RTB Member
    Rockingham Va
    Yes it can be either heated or not.
  5. TheCrazyGnat
    Central PA
    I've just used distilled water in mine. I used simple green the first time and it etched the aluminum in my first two carb bodies. I have heard some use simple green hd, which is supposedly safe for aluminum, but I haven't had the chance to try it myself.
    smeagol21b and Stumplifter like this.
  6. RTB
    RTB Member
    Rockingham Va
  7. Stumplifter
    near Irma, WI
    I have heard the same about Simple Green. I also am a 'gallon of Berryman's' kinda guy. Basically the Ultra Sonic 'action' does the cleaning for you and distilled water is a good option. Perhaps a few drops of dish detergent to help break away any greasy kid stuff . . .
    Where I used to work we would clean ceramic parts and D2 parts with a solution of almost pure industrial floor cleaner - only for a few minutes followed immediately with a rinse. . . . I would not be so aggressive with the carbs. Some others have used Ultra Sonics perhaps they will chime in.
  8. XJ550H
    I worked for a contact lens company we uses kerosene in the ultrasonic cleaners to clean contact lens
  9. RTB
    RTB Member
    Rockingham Va
    I've read of people using, dish detergent, laundry soap, simple green, HF degreaser, distilled water and a host of other things. I'm thinking ill go with K-Moe's suggestion and try the pine-sol original and see how that does.
  10. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    I did mine with C L R. Give them a good rinse when done blow dry, spick and span shinny clean. 50/50 mix with water.
  11. k-moe
    Careful using CLR on aluminum. It removes the aluminum oxide from the surface, and can remove enough of the surface that cleaances will change if left in for too long.
  12. Door dude
    Wow, i hope i got lucky.
  13. hogfiddles
    Hmmmm
  14. RTB
    RTB Member
    Rockingham Va
    The ultrasonic cleaner came today so I gave it a workout on a set of carbs off an 83 Kawasaki KZ440LTD I'm doing for a young man. I do believe these carbs have been out of service for many years and a pretty good test for the cleaner. I used original pinesol deluded with water 50/50 mitxure and ran the carbs through a couple 30 min cycles. Rinsed them off and blew air through them. Look pretty good considering what they looked like. I'll give them a little bit more TLC but i'm impressed with the cleaner.
  15. hogfiddles
    I bet it worked like CRAZY
  16. RTB
    RTB Member
    Rockingham Va
    Yes it DID
