Vacuum Leak and High Idle After Carb Rebuild
Discussion in 'XJ Technical Chat' started by Deneb Hernandez, May 21, 2024.
  1. Deneb Hernandez
    Deneb Hernandez New Member
    Ohio
    So here's a fun one that's been puzzling me. I've got an 82 XJ650 Maxim I've been working on for a while now, got it cheap, went through the works undoing things from the PO and rebuilding things, starter, carbs etc.
    I rebuilt the carbs, all went well, did bench sync with feeler gauges, once again went well. Once I got the bike started again, it idles high, only once warmed up. Goes to about 2k, regardless of if I touch the throttle or not. I can pull the idle control screw all the way with no change. After I've rode it for around 5+ minutes, it idles at 4k. Vacuum sync readings are good as well, all cylinders are very close in vacuum, until it gets warmed up and 2 and 3 read all over the place. It also has low power until warmed up.
    My first thought was carb boots, replaced them with no effect. Same symptoms, same severity. Made sure all the valve clearances were in spec, they are. Anyone have any ideas what this could be?
  2. cds1984
    cds1984 Well-Known Member
    Perth, Western Australia
    Can you do a compression test cold and then hot.
    Might help to remove a question if nothing else.
    Although it does sound like a sync issue.
  3. Timbox
    Throttle cable is not suck on the top of the holder at the carb? Not too sure how many of these carbs you have cleaned. I will tell you the first set I did, I cleaned them six times. I kept missing little things. Once the carbs are good and the cables are all properly seated and adjusted issues should go away. I see you are new to the board only reason I am asking if you have cleaned these type of carbs before. That little jet in the bottom of the float bows is a bugger to get clean.
    Franz and chris123 like this.
  4. McTavish
    McTavish Active Member
    Daytona Beach, Fla.
    in my opinion - intake gaskets.
    I had similar issue only while hot. [1/2hr into riding] except the low power thing.
  5. Deneb Hernandez
    Ohio
    I replaced them, theyre sealed tight.
  6. Deneb Hernandez
    Ohio
    Cables are good. Moves freely, plus the other two carbs, which have interlinked throttles of course, are not experiencing this.
  7. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    I don't get the bench sync with feeler gauges, bits of wire etc. Do it by lining up on the edge of the first hole, foolproof method.
  8. Dave in Ireland
    Ireland
    Check with propane wafted over them to see if the idle revs pick up.
    It's not unknown for the flanges to be distorted and bowed in the middle.
  9. Everett Larouche
    Everett Larouche New Member
    Windsor Ontario
    hey any new updates? I am having the same issue and posted about it.
  10. Minimutly
    West Wales, uk
    Posted? where? not here?
  11. Everett Larouche
    Windsor Ontario
    My bad, I posted as a conversation not in the Xj tech chat...
