vacuum petcock failing.
Discussion in 'XJ Technical Chat' started by fintip, Nov 29, 2012.
  1. fintip
    fintip Member
    Austin
    So on the FJ, as the XJ, there is a vacuum operated petcock. I have become aware of the fact that the vacuum seal on mine is starting to fail.
    What I mean is this: when you suck on the vacuum port on the petcock, it is supposed to feel like sucking on a straw that all of a sudden gets blocked by a piece of paper, seals shut. On mine, you have to keep sucking to keep gas flowing--meaning there's an air leak.
    Any ideas for rehabilitating that seal? This bike has massive gravity fed gas lines, and has a bit of a problem getting enough fuel into its system if everything isn't perfectly smooth. I started experiencing fuel starvation issues on my last long ride, where I did some long term high speed cruising. Keeping the throttle a little less open made the issues go away.
    So, yeah, ideas?
  2. adrian1
    adrian1 Active Member
    Wrong way round mate. No vacuum means valve shut. Vacuum ie sucking opens the valve.
  3. fintip
    fintip Member
    Austin
    I'm aware. Think a little harder and you'll understand what I mean. Vacuum port seals, thus opening gas port.
  4. maximike
    maximike Member
    Portland, OR, USA
    Yeah, I see what you mean, but I'm not sure I understand the question. Is there no rebuild kit for that petcock? Or you could do what I did, buy a petcock at the junkyard, take off failing one "planning" to rebuild it. Then throw it in a tool box and forget about it because your "new" junk part is working fine. LOL.
    Or did you want a super cheap way of fixing just one seal in the petcock? No idea, but maybe you could put some silicone on it or something. I wouldn't bother, if I took one apart, at that point might as well do full rebuild. Fitz has a write-up, showing what surfaces need polishing and everything.
    Here ya go, a little hard to find since he never says "petcock" haha. http://xjbikes.com/Forums/viewtopic/t=25058.html
  5. fintip
    fintip Member
    Austin
    There is no rebuild kit. This bike happens to have the most expensive petcock Yamaha ever built--on the 86/87 FJ1200's, Yamaha tried an experiment with an 'electronic reserve' function, building in a solenoid with a plug coming off and going to a button in the fairing.
    Cost for replacement: $250 new. One parts guy for the forum has gotten them down to like $175 somehow. The ONLY generic replacement option is like $135, and isn't vacuum operated... Which is a huge problem since you can't see/access the petcock while the fairing is put together.
    So yes, just trying to figure out home repairs for my woes. Maybe finding some spare rubber and cutting a replacement gasket for the seal in question?
  6. bigfitz52
    Maybe carefully take it apart, snap a couple of pics, and let's compare it to the rebuild kits for the vac-op petcocks that ARE available? Maybe a usable bit there?
    I didn't use the word "petcock" in the title because it would get auto-censored.
  7. fintip
    fintip Member
    Austin
    I'll do that. Actually, it had a leak when I got it, so I filmed some video of the 'fix' as a how-to video. I'll try and get that edited here quickly so you can see the internals.
