Valve clearance - exhaust side
Discussion in 'XJ Technical Chat' started by Lightcs1776, Jun 18, 2016.
  1. Trotskie_10
    Trotskie_10 Member
    Iowa
    After adjusting the valves will the carbs need adjusted as well?
  2. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    It is a good idea to resynch after a valve clearance adjustment. Running synch that is.
    Trotskie_10 and rocs82650 like this.
  3. Jerrod Robinson1086
    Jerrod Robinson1086 Member
    Marion Ohio
    I was able to Find Them all on eBay, Paid like 3 Bucks a Shim if Memory serves.
  4. Jerrod Robinson1086
    Marion Ohio
    I could not get the Shims out to save My Life. I ended up just pulling the Cams, and still had to tap a Small Flathead up under with a Small Hammer.
  5. Dave in Ireland
    Ireland
    Yep, sometimes the shim is well stuck in. Luckily I've not had to remove cams yet, but it's been close.
    Generally find a small sharp screwdriver of just the right size gets in there, and if it's just oil being grabby it will release. A set of hemostats work well for shim removal and replacement too.
    Roast644 and chacal like this.
  6. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    A blast of compressed air aimed at the notch has freed them up for me when they are particularly stubborn.
  7. Dan Gardner
    Minneapolis, MN
    That's a good idea @Roast644 - will have to try that next time
    Roast644 likes this.
  8. Melnic
    Melnic Active Member
    Did you rotate the notch opening of the outer ring to the top before you put the clamp tool on to hold the ring down and then rotate the cam?
