Valve clearance waaay out of spec :(
Discussion in 'XJ Technical Chat' started by discostu_001, Sep 10, 2016.
  1. discostu_001
    discostu_001 New Member
    So today I thought I would do my first compression & valve clearance check on my 86 xj900n - i've had it for 3 years but never done the clearance check :/
    As you can imagine from the results below, its not running all that well - poor mileage and trouble starting etc... Other than that, the power seems to be okay.
    Cyl 1 2 3 4
    Compression
    Dry 160 150 60 65
    Wet 1 65 160 130 125
    Clearance
    Intak 0.063 0.102 0.076 0.102
    Exhaust 0.140 0.152 0.152 0.152
    Another thing, i've never taken my valve cover off before, and noticed that one of the bolt holes has been snapped inside, with the broken alloy no where to be seen.
    I haven't got the tool to take out the shims but will get one soon and then start getting the valves back into spec.
    Any suggestions on what i can do about the bolt hole?
  2. desmotom
    desmotom Active Member
    Canada MB
    Is the bolt in the hole?? If it is you can try and walk it out with a pick.
  3. discostu_001
    so the broken bolt is on one of the inner rocker clamps; No idea if thats an expensive fix or a get out of jail free card... Pic shows front left clamp, but it's front the right one..
  4. XJ550H
    Lightcs1776 likes this.
  5. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    If you can back it out with a pic then if you remove the other bolt the top part of the cam bearing should come off leaving the bole exposed. If so, a vice grip wrench should do the trick.
  6. discostu_001
    This is the part that is broken, I'll head to the wrecker tomorrow to see if i can find a replacement..
    I measured all the shims today as well using the zip tie method - super easy.
  7. tabaka45
    Brunswick, Georgia
    Ugly. Hope you can find a replacement. Chacal may have one.
  8. dkavanagh
    Rochester, NY
    fwiw, if the cam bearing caps are anything like on cars, it must fit precisely, and not all are the same. If Yamaha was really good, they'd all be the same, so others should chime in. I just know that the bearing caps must match the head as those are bored out together.
    Toomanybikes likes this.
  9. Toomanybikes
    Tsawwassen bc
    Just finished my annual valve adjust and 5 of 8 out. Must have been a little rough on the old girl this summer.
    Yikes after midnight ... Go to bed now
    Ps no broken bolts
  10. Toomanybikes
    Tsawwassen bc
    Yes they are made as a set at factory
    But any used one and some plastic gauge will tell you if it will work. Soon as you torque down the cap you will find out if it will work.
    Failing that a replacement cap could be line bored to spec.
    But good luck finding one that doesn't have a head with it , no wrecker is going to sell you just one cap unless he has a junk head laying around.
  11. chacal
    Only if it was too small/not enuf clearance to begin with........
  12. jayrodoh
    jayrodoh YimYam
    Cleveland
    I don't know about the 900 motor but on the 650 the cap near the chain sprockets does not hold the cam in place and is simply for the valve cover bolt. It's hard to tell from the pic of you holding it in place but it kind of looks like its not really a cam cap and could be replaced with one from another head without worrying about it damaging the cam.
  13. Toomanybikes
    Tsawwassen bc
    As with any bearing cap, they can be cut down at mating surface and then resized.
  14. discostu_001
    so after closer inspection when I had stopped cursing the bike, I figured it was just a bracket to bolt the cam cover on.
    I spoke with a few wreckers who weren't keen on parting out a cylinder head so I just improvised a bit and ground a bit of the thread off the top of the bracket to give me enough clearance to put a spring loaded nut on the inside of the cam cover. So far it seems to be fine...
    Stumplifter likes this.
  15. sybe
    sybe Active Member
    NYC - Brooklyn
    i have a few of those i can send to you. I bought a xj750 head for parts. I have two of those caps. and @jayrodoh is right. It doesnt touch the cam. so no bearing issues.
    Message me with you address. i'll ship it out to you in two weeks. Along with the package i owe Jay!
    discostu_001 likes this.
  16. k-moe
    All the cam journals were ground to the same dimension, and all the cam bearings were machined to the same dimension (the cams run directly on the head casting, no shells). The only thing that will prevent swapping parts is excessive wear. SOP for (most) motorcycles.
  17. discostu_001
    Thanks mate, I'm in Melbourne so that will be a fair effort. It's okay for the moment but appreciate the offer.
