Valve Clearances xj550h - shims
Discussion in 'XJ Technical Chat' started by RCGolden, Dec 27, 2018.
  1. RCGolden
    RCGolden New Member
    Edmonton
    Evening all,
    I just did the clearances on the bike. Being this is the first time I’ve done this I wanted to double check.
    So based on what I figured out.
    All but #4 on the intake are ok. It needs to drop down a shim?
    On the exhaust
    V1,2,3 need to drop down a shim and v4 needs to drop down 2 sizes?
    Just want to make sure I am getting this correct.
  2. RCGolden
    RCGolden New Member
    Edmonton
    Ok, I double checked and if I’m reading correctly
    Intake changes to
    V1 - 265
    V2-255
    V3-245
    V4-260
    Exhaust changes to
    V1- 250
    V2-250
    V3- 245
    V4-255
    That’s if I’m reading the chart correctly in the post done by bigfitz52
  3. chacal
    You are 100% correct in your size determinations, and if you choose to swap shims around, then what you'll end up needing are:
    2 x 2.45mm shims
    1 x 2.50mm shim
    2 x 2.55mm shims
  4. RCGolden
    RCGolden New Member
    Edmonton
    Thank you kindly.
    I will see what I can locate here and get her buttoned up and do a compression test on it afterwards. Hopefully things will be good.
  5. chacal
    Okay, good luck with the project. And we do have all these shims in-stock if there is no local supply available.
