Valve shim measuring...
Discussion in 'XJ Technical Chat' started by amiel1157, Oct 31, 2020.
  1. amiel1157
    amiel1157 Member
    Philippines
    Hi.. sorry if this has been asked before.
    whats the correct way in measuring clearance of shims is the cam lobe just pointing upward or is it suppose to be “inline” with the valve being measured? Im getting different readings and obviously confused :(
  3. bensalf
    bensalf Well-Known Member
    yorkshire ,england
    cam lobe should be pointing away from the shim, so you're measuring the greatest gap, then the engine is turned to measure the others that wer'nt pointing away.
    stu
    amiel1157 likes this.
