Wanted Various Parts - 1981 XJ650 Maxim - Ignition Module
Discussion in 'For Sale, Trade/Swap, Wanted' started by seph2004, Mar 3, 2017.
  1. seph2004
    seph2004 New Member
    Andover, MN
    I need an ignition module for an 81 XJ650. Mine no longer works.
    Let me know if you have one and how much.
  2. davy
    davy Member
    canada
    I have one from an 81, 750, I don't know if they are the same.
  3. Toomanybikes
    Tsawwassen bc
    What is the code number on the box?
  4. 750MaximSeattle
    750MaximSeattle Active Member
    Seattle, WA
  5. seph2004
    seph2004 New Member
    Andover, MN
    I will have to track down the numbers on the box, I haven't ventured out in the garage.
    I am compiling a larger list of parts soon as I need a lot. I keep wanting to get to the bike to finish it up but other projects keep hitting the list.
    The engine I have is non-YICS.
  6. seph2004
    seph2004 New Member
    Andover, MN
    Here's my list of what I need:
    Bar Switch Assembly (Clutch Side) 24-2058
    Bar Switch Assembly (Brake Side) 24-2059
    Throttle Cable 51-3511
    Clutch Cable 51-6502
    Fuel Tank Badge 65-6502
    Front Fender Mount Bolts 66-7883
    Signal lamp flasher relay 10-1172
    Clutch Switch 12-0013
    Ignition Coil 4 Ohm 17-6805
    LED Charging System Gauge 24-2660
    Starter Relay 24-6526
    Condenser Pack 26-5114
    Power Relay 32-7515
    Brake Pads 29-3522
    Front Master Cylinder 08-0255
    Igniter
    I know I can get this from MikesXS, but I need to see if I can source used parts to get this bike going.
    Toomanybikes likes this.
  7. Toomanybikes
    Tsawwassen bc
    Have almost all of this in stock . Have 2 non Yics bikes in stock for parts. Or do you want new bits ?
  8. seph2004
    seph2004 New Member
    Andover, MN
    I am OK with old parts, I just need pricing on stuff so I can start getting the bike going. It's spring it's warm and I want to finish it.
  9. Busted Knuckles
    Busted Knuckles Member
    North
    All from an 82 XJ650 Seca:
    clutch packs and assembly
    flywheel? assembly
    side covers are spoke for
    engine case bolts; oil filter cover thing spoken for
    coil packs (is that the name of these?)
    the timing plate and the wiring
    front fairing
    I also have a set of 650 jugs.
    everything is name your price +shipping
    I'm mailing out tomorrow or Tuesday:
    Side Covers
    TCI
    Airbox
    Oil Filter Cover
    Everything else is up for grabs
  10. Toomanybikes
    Tsawwassen bc
    Will put a list together and pm you
  11. seph2004
    seph2004 New Member
    Andover, MN
    I haven't finished the bike after all these years, but the only things I need are:
    Igniter
    Head Gasket for non-yics 80-81, where there are only 2 bolts on the cam chain area instead of the typical 4 bolts on most engines. This seems to be the hardest thing to track down.
  12. hogfiddles
  13. Gary Potter
    Gary Potter Member
    Manassas, Virginia
    Hello,
    I have a TCI for a 81 xj650 Maxim.
    Gary Potter
  14. hogfiddles
