Wanted - Master Cylinder assy. For 83 XJ550
Discussion in 'For Sale, Trade/Swap, Wanted' started by fightfires13, May 25, 2008.
  1. fightfires13
    fightfires13 New Member
    Winchester, VA
    I have recently purchased my first motorcycle, a 1983 Maxim 550. It has obviously been sitting for a few years to say the least. Within a week it has been cleaned up, been running for the first time in 5 years, and some other small repairs. I am in desperate need of a new master cylinder assembly. The one I have cannot be rebuilt it is completely trashed. I am a little low on money right now but if anyone has a master assembly that isn't too awfully expensive I would love to take it off of there hands. I appreciate all the help I can get with this resurrection!!!
  2. chacal
    Here you go!
    HCP3461 OEM complete Master Cylinder Assembly, brand new unit perfectly replaces your original. Comes with cover, diaphram, and piston assembly, ready to install. Hand lever, brake light switch, and mounting hardware is not included. Fits all XJ550 models.
    $ 104.00
    HCP3461GCU OEM complete Master Cylinder Assembly, good used condition, WILL NEED COMPLETE REBUILDING!. Hand lever, brake light switch, and mounting hardware is not included. Fluid sight "window" is cloudy. Fits all XJ550 models.
    $ 29.00
    HCP3034 OEM front master cylinder Reservoir Diaphram, brand new accordian style rubber diaphram fits and seals as original. Fits all original XJ550 all models, XJ650 Maxim and Midnight Maxims, and XJ1100 front master cylinders. Each:
    $ 8.00
    HCP3030 OEM front Master Cylinder Rebuild Kit, for all XJ550 models.
    $ 54.00
    HCP1694 Aftermarket front Master Cylinder Rebuild Kit, for all XJ550 models.
    $ 32.00
    HCP1074 Front brake master cylinder Glass Fluid Level Sight Window, correct size and thickness crystal-clear mineral glass. Each:
    $ 5.95
    HCP3120 Aftermarket black Gasket Maker, 3.8 ounce squeeze tube. Enough to do about ten thousand sight glasses! But it's the smallest size offered. I'm sure it works well in other applications. Each:
    $ 5.50
