wanting to change the spedo dials from us to uk spek
Discussion in 'XJ Technical Chat' started by andy willi, May 25, 2019.
  1. andy willi
    andy willi Member
    doncaster UK
    hi i have an xj 550 seca usa bike and the speedo is red after 55mph as it is a usa bike i want a uk dial can anyone help me out with where to get the uk dial .
    andy
  2. Toomanybikes
    Tsawwassen bc
    a Canadian spec speedo would be the simplest fix. Someone here may have one
  3. andy willi
    andy willi Member
    doncaster UK
    do you know if there is anyone who reproduces them
    andy
  4. Toomanybikes
    Tsawwassen bc
    No but I have seen a company that does reproduction face plates in the UK
  5. k-moe
    But then he'd be reading those tiny numbers for MPH.
    I suppose it would make things better for a trip to France though.
    A combo of the Canadian spec speedo, and a faceplate with MPH in the large font would be nice.
    Transplanting a newer speedometer in is a good option too.
    seca-550-150mph-speedo-retrofit-details-w-pics.22823
  6. Craig B
    Craig B Active Member
    Ontario, Canada
    Are you looking for just the faceplate in kilometers?
    If so I now have a spare.
  7. XJ550H
  8. k-moe
    That won't help him. The US spec speedometer's full sweep is to 55 MPH. Switching faceplates will just show him going a lot slower than he actually is going.
  9. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    I'm in the same boat, I've bought a US spec xj650 but I've located and have a set of UK speedos. Just need to figure out how to install them... this may be a silly question but the lower speed on the us speedo wont limit the bike will it?
  10. k-moe
    There is no limiter on the machine, speed RPM or otherwise.
    Actually there is an RPM limiter. Valve float, followed by a dropped valve.
    The speed limiter is aerodynamic, and cuts-in at around redline in 5th gear.
  11. a100man
    a100man Well-Known Member
    Bedford, UK
  12. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    So I actually have a UK speedo sat in the garage.
    I've got a US import xj650 maxim, what wiring changes are needed to install the UK speedo?
    So what will happen when the bike hits 80? Will it keep climbing past this (if the bike will manage) or will it stop?
  13. k-moe
    No wiring changes to install the speedometer.
    When it hits 80 what?
    80 Mph? Standard US freeway cruising speed in many parts of the country. The engine will be turning at about 6,500 RPM, and will do so all day long for as many days as you care to.
    Redline on the engine is 9,500 RPM. Top speed is around 120 MPH in 5th gear for your Maxim, so you won't quite hit redline there.
    The engine can reliably pull to 12,000 RPM for short bursts (though it's not recommended), but pushing it beyond that is asking for a very shortened valvetrain life (as in valves float, hit the pistons, and fail in a spectacularly un-fun manner).
    All the limiters I mentioned are physical. Nothing electronic limits the engine from operator error causing damage to it.
  14. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Sorry I should have been clearer, yes MPH
    Standard cruise speed over here is 70mph, anything over is illegal! I may look into swapping the speedo over then if no wiring changes are needed... is it possible (although I imagine illegal) to change the miles setting on the speedo to match what mine currently reads?
    My speedo reads 20k but the UK one is reading 37k
  15. k-moe
    Very possible (you'll see once the speedometer is open. gaps. width. pull and turn).
    It's legal to do in the U.S. if you have a shop take care of it and file the correct paperwork. Probably true in the U.K as well.
    I shall say no more about how my replacement odometer just happened to match the miles on the original.
    MaximusXJ650 likes this.
  16. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    You clearly had it done correctly ;)
  17. XJ550H
    it should be no problem unless it is done to defraud.
    when I register my bikes in US I am not even asked for mileage because of the speedos being changed/replaced all the time. KBB does not even use miles in giving values
  18. a100man
    Bedford, UK
  19. k-moe
    That's the sticky part. Proving intent (or lack therof) can become quite expensive. Thankfully the XJ series is not collectable enough to garner that level of legal scrutiny.
  20. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    Yes I know, I was stating that I already had one - I figured that it was easier to add into the comments that create a duplicate thread asking the same question
