Weird slow weave at 30+ mph
Discussion in 'XJ Technical Chat' started by spinalator, Jul 23, 2008.
  1. spinalator
    spinalator Member
    Regina, CANADA
    More on the handling issues, I changed my head bearings and now have weird handling issues. The thing has a slow weave or oscillation at speed and steers heavy and weird at slow speeds. Think it is a wheel alignment or a bearing torque issue?
  2. MaximumX
    MaximumX Member
    Ottawa, Canada
    I'd give the front wheel alignment a quick check by eyeballing down the forks. I had an issue where the forks were out of true by a hair, caused by improper reinstallation of the front wheel and what I assume was some frigging around with the triple-clamps. When I inspected closely, I noticed that the triple-clamps were slightly tweaked and caused the forks to come out of true and messed up the alignment of the front wheel. It wasn't enough to be obvious but when I rode it just "felt" like the bars weren't pointing straight-up. Turned out they weren't.
    If that checks out okay, then definitely have a look at the bearing torque.
  3. bigfitz52
    Low-speed weave usually the result of too tight steering head bearings. See RickCoMatic and MiCarl's post in the "high speed stability" thread that's active right now, Rick explains how to check them.
  4. spinalator
    spinalator Member
    Regina, CANADA
    Thanks for the ideas, I will check both these items again.
  5. Alive
    Alive Active Member
    Queensland, Australia
    I know what it is... Your tripping again arn't you :lol:
    I had something like this.... Turned out to be the steering lock tab on the frame was bent and catching on the back of the ignition.... Drove me nuts for ages until I found it ;)
  6. spinalator
    spinalator Member
    Regina, CANADA
    I have not licked toads or chewed tree fungus in many years, but I think the carb solvents may contribute to my cerebral instability.
    It is amazing how wacky little things can influence handling, or lack thereof.
