What did I ruin? Electrical work, saw an arc.....Brake light wont work now.
Discussion in 'XJ Technical Chat' started by Phil B, May 9, 2021.
  1. Phil B
    Phil B Member
    Calgary, Alberta, Canada
    Okay.....deep breath....I was trying to set up a new LED brake light. Was testing with some gator clips, got clumsy and saw a small electrical arc. Now the brake light doesn't work. Running light works fine, but nothing when i mash the foot/rear brake.
    Just trying to understand exactly what I have ruined, and what must be done to get it sorted...
    Damin! I'm so close, i've been through this whole bike and was so close to the end until i made this stupid mistake.
    Thanks for looking, any advice will be appreciated.
  2. StahlMaster
    StahlMaster Active Member
    Southgate, Michigan
    Check the fuse?
    k-moe and Phil B like this.
  3. Phil B
    Phil B Member
    Issue resolved...case close!
    Thought it would be worse for some reason....anyhow, thanks !
  4. StahlMaster
    Southgate, Michigan
    In the 36 years I've owned my XJ650J Maxim I've done that several times. That's why it's important to have the correct amp fuses in the fuse box. It doesn't take much to blow them but it's better then replacing burnt wires or worse.
  5. Brent NZ
    Brent NZ Active Member
    Tauranga, New Zealand
    No matter how bad it is it could always be worse. I was installing a new battery in my car, was tightening the positive terminal with a socket & slipped. The socket handle contacted the power steering unit and instantly blew a hole in the power steering hose lines. That was not a good start to the day.
  6. XJ550H
    oddly enough but the tail light runs off of main fuse and even though it is the same bulb the brake light runs off of the signal fuse
  7. k-moe
    It's not that odd. The tail light is required to be illuminated whenever the ignition is on. The brake light does not, and is considered to be part of the signaling devices. Same bulb, but two purposes, so two seperate circuits.
  8. tj.
    tj. Active Member
    Canada
    I think it has more to do with the parking function. In "P" tail light on.
  9. k-moe
    That too. Though IIRC the federal statute in the U.S. does specify that the taillight be illuminated whenever the ignition is on. The parking function could be powered by the signal circuit by bypassing the brake switches (though that would be silly and cost more to produce). Two laws, one circuit.
    tj. likes this.
  10. tj.
    tj. Active Member
    Canada
    Makes sense. If you loose your brake light you still have a tail light...especially at night.
  11. XJ550H
    if you look at switch block you will see when in on position it still connects to L (blue) wire for tail light. park is second way to turn on tail light
    tj. likes this.
