  1. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Fat front tire and skinny rear tires?
    Franz likes this.
  2. Franz
    Still three wheels, just joking.
  3. Jetfixer
    Sad day last night I sold the Johnny Cash bike, it has been fun but I guess it was time to move it on . Still have my favorite yellow seca . Might buy another project some time , but I don't think winter will give up 32 degrees for a high . I still have a maxim bobber I'm trying to get to run right for another guy , but it is to damn cold to mess with .
  4. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    Might be sad day for you, but you rebuilt (or built) something that wasn't going anywhere otherwise - turned it into cash. Result I'd say.
    Jetfixer likes this.
  5. Jetfixer
    For a change I bought something cheap and made a profit , not as much as I would have but still gives me a good amount so that is positive. Looking at bikes for sale locally, he got a bargain many without titles, not running, or needs work. Lol . Might have found another project 83 Maxim disassembled for 650$ hmm .
  6. ksigurdsen
    ksigurdsen Member
    Wellington, FL
    I ran across a new old stock brake master cylinder and a pair of caliper rebuild kits on Ebay so the hydraulics on the front brakes are like new again. Also, I made an adapter plate for the master cylinder and was able to use my Motion Products power bleeder to fill the system. It worked great.
  7. hogfiddles
    You’re still gonna stick around though, right??
  8. dwcopple
    dwcopple Active Member
    bay city, michigan
  9. Jetfixer
    Yep still have my yellow seca, found a maxim that is fully disassembled I might buy, I'm jealous of all the bikes you have :D
  10. hogfiddles
    Well, if you ever need another xj, you know where are a few;)
  11. Huntchuks
    East Rochester, NY
    OK, yesterday was nice so I finished assembling the cams on the engine on the Maxim X, and checked clearances again. I found a couple that still needed changing around and when I was removing the cam caps, one of the hollow dowels flipped out of the hole and disappeared down the chain well! Oh great! Got out the endoscope and finally located the part. No way to rescue it though. I needed a small magnet on something flexible because the frame directly above blocks a straight down access and also I needed to be able to adjust angles as I go. I finally came up with a scriber with a magnet on one end with the scriber tip removed and solder inserted. It took a long time using both the scope and magnet but I finally retrieved the dowel.
    Franz, hogfiddles and chacal like this.
  12. hogfiddles
    I think that’s why the emphasis on stuffing a rag into the cam-chain well is so often mentioned......
    Glad you got it out
    ksigurdsen likes this.
  13. dwcopple
    bay city, michigan
    Ordered front tire, grips, and new gas cap. Extended some wiring to rearrange unit locations. Reinstalled the rear bodywork and tossed the seat on for a pic.
  14. hogfiddles
    Getting there:)
  15. Dan Gardner
    Minneapolis, MN
    Paint!
    ksigurdsen, hogfiddles and Jetfixer like this.
  16. dwcopple
    bay city, michigan
    Made frame covers out of electric knock out covers, pulled my front wheel for a new tire this week, cleaned and painted the front caliper bracket, and installed new grips.
    WhiteArthur likes this.
  17. dwcopple
    bay city, michigan
    Then went back and masked off and painted the caliper semi gloss black
  18. Jetfixer
    Put on my Vista cruise control, will make riding a little more pleasant .
  19. Eric Hughes
    Eric Hughes Member
    North Carolina
    Did a little pre-season walk around. Last year we did a ride where a car pulled out to beat the line of bikes, which as you can guess caused a mess. The bike behind me went down and slid into my rear wheel. Noticed today that it did connect a bit more than my tire. Guess it is time for a new push rod, might as well do brakes and rear wheel bearings too. I don't really trust just straightening it out.
  20. Huntchuks
    East Rochester, NY
    Straighten out that rod. The bend will not affect any future performance. Remember, it is pulling, not pushing. No strength loss.
  21. Jetfixer
    ^^^+1 as stated by Huntchuks straiten rod out .
  22. Eric Hughes
    Eric Hughes Member
    North Carolina
    Good to know thanks. Still need to do the pads and bearings probably. checked them last year and they weren't delaminating but a bit worn and the bearing have probably never been done.
  23. Eric Hughes
    Eric Hughes Member
    North Carolina
    There is no easy way to get that off the bike. That I can see anyway. Really don't want to remove the swing arm to get to it, geez.
  24. Franz
    Can you put a tube over the brake lever rod to straighten it on the bike. Just put tape on the threads to protect them first.
    Huntchuks likes this.
  25. dwcopple
    bay city, michigan
    Got a new tire put on, wheel cleaned up and black paint touched up "good enough"
    Franz and Dan Gardner like this.
  26. dwcopple
    bay city, michigan
    Installed wheel and front fender, gas tank, seat, etc. Rear brake rod is FUBAR'd so I went and got a bolt to weld on the rod to fix the adjuster. Should be able to ride tomorrow at some point. 20220409_122643.jpg 20220409_132749.jpg 20220409_133107.jpg
    Uxbridge Brule and Jetfixer like this.
  27. XJ550H
    pull the inner fender to get access. if you undo the adjuster bolt it should pull out of the lever
    you could pull the lever off just mark its position on the shaft
  28. dwcopple
    bay city, michigan
    20220410_131019.jpg 20220410_131033.jpg Rode it today. Whew! Needs massive carb tuning. Plugs are black after 2 mins. Brake rod fix was a bust so need to locate one ASAP.
    Andy F and Jetfixer like this.
  29. XJ550H
    What did you do to repair brake rod?
    your hub lever is way off of where it should be
  30. dkavanagh
    Rochester, NY
    I knew something looked "off" in the rear... literally, the shocks are "off"!
  31. Jetfixer
    Temperature was better today rode two miles to gas station , was no fun gusts to 25 miles an hour the bridge over the lake was litterly almost blown over . So now have full tank first fill up on the year .
  32. dwcopple
    bay city, michigan
    Cut off the bent part and welded on threaded M6x1.0 rod. It actually works now as I redid it but also won an ebay auction for a used rod too. The lever is way off, yes. I watched some vids on adjustment last night and will try again.
  33. dwcopple
    bay city, michigan
    It's a monoshock design. It's there...
  34. Noahsxj
    Noahsxj Active Member
    SW Missouri
    Today 1 year ago I picked up something I thought I would wrench on for a few hours and probably lose interest in 5ABC0346-8452-43A3-96B8-5278706DCAA3.jpeg 4B3C7A58-59C2-403E-A740-889B4518F424.jpeg 17F2DB66-8F27-4615-B0F7-1A72B72BF9AF.jpeg
    ..& then I found these forums.
  35. XJ550H
    Noahsxj and Jetfixer like this.
  36. Huntchuks
    East Rochester, NY
    So, I replaced the final shim, reassembled the cams with all 40 screws, reassembled the chain tensioner and checked clearances again. Now I have 4 that are slightly out of spec large gap wise. One more time, maybe Wednesday. Oh well, gotta love all the screws!
  37. Timbox
    Have a old XS400 given to me, got the carbs cleaned and back on. Had a AUX gas tank on her and checked the oil lever. Had oil all the way up...I should have known better. Started the bike and noticed a little liquid coming out of the crank vent, as it was not connected to the air box. Well, the RPM's went up and the crank case must have been full of gas and oil...that was a hell of a mess....lol.
    Drained the old oil/gas mix, new oil and the little 400 runs very well. Lots of work to do on the bike yet to include clutch adjustment. Free so had to take it.
  38. dwcopple
    bay city, michigan
    Stuck floats are awesome!
    chacal likes this.
  39. Huntchuks
    East Rochester, NY
    Finished my carb jig.
    Franz and Noahsxj like this.
  40. Andy F
    Andy F New Member
    California
    Opened up my carburetors for the first time and found the float valves were rusted solid and there were no pull clips attached to the floats.
  41. Huntchuks
    East Rochester, NY
    Wow, but that will be only the beginning of your issues. May as well start the complete disassembly for cleaning and repair right now.
  42. Jetfixer
    Some float needles do not have clips .
    Andy F likes this.
  43. Andy F
    Andy F New Member
    California
    Turns out replacements I bought with clips were not only wrong, but they don't fit.
  44. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Nothing high tech...frustratingly trying to strip old paint off the frame. Used the hardware store gel type stripper which hardly even makes a dent in it. Ordered some Aircraft Remover and hoping it will work as well as the videos I watched.
  45. Dan Gardner
    Minneapolis, MN
    Methylene chloride can still be used for "commercial" purposes. You might be able to find a shop to do it for you. Or maybe you start a business in your garage, who am I to say? Or media blast it. It's a tough job without methylene chloride.
  46. Roast644
    WASHINGTON
    Good to know! A quick search says you can get it from McMaster Carr unless you live in a handful of states that don't allow it. I'm going to attempt the Aircraft Remover and then probably media blast, but it's good to have a backup plan. Also waiting to get a replacement VIN tag before I totally destroy the original.
  47. dwcopple
    bay city, michigan
    Sold my Maxim400 yesterday for a healthy profit.
    Timbox likes this.
  48. cgutz
    cgutz Well-Known Member
    SE South Dakota
    The question for me today is what have I NOT done with my XJ550. It has been so cold and crappy weather in the midwest, I still haven't got my XJ out from the back of the garage and got it running yet.
    Often I am driving in February from time to time. Not this year.....
  49. Jetfixer
    Area around Chicago weather has sucked only rode a few times and it has been windy on top of cold . Although they claim 70's by Saturday fingers crossed and hopefully no 35 miles an hour wind gusts .
    cgutz likes this.
  50. Jetfixer
    I finally did this got a RTV casting kit and resin and made a copy of the dash pad emblem the Unobtainium made two one is thin the other is thicker , just needs painted , I'm very happy how it turned out. This looks great covering the screws .
