  1. chacal
    That might be some reflective "wheel rim" tape that someone applied.....easy enough to find on eBay, etc.
    FORK OIL: you can always mix "weights" (viscosity) oils of the same brand oil to get a "custom" weight suitable to your liking.
    PITTING: yes, about the only "fix" (besides re-chroming or replacement) is the epoxy solution, it works well if done correctly, and it would be a long time before epoxy is affected by oil.....the biggest challenge is getting the fork metal really, really clean enough for the epoxy to stick properly, and then getting the epoxy sanded to a truly round curvature. Takes time and quite a bit of patience!
    ksigurdsen and Uxbridge Brule like this.
  2. RideAlong420
    RideAlong420 Active Member
    USA
    My idea for this weekend is to take a wire wheel on my power tools to the rust (if it's really bad) or otherwise just wet sand it and epoxy.
    My wire wheel was pretty good with the brake pedal to remove the rust.
    It's all a short term fix anyway, since I want to upgrade the forks to dual rotors in the future anyway
  3. Brhatweed
    Brhatweed Well-Known Member
    Mora MN
    This is what I did to my Yamaha today...
  4. ScottFree
    ScottFree Active Member
    Northern Ill-Annoy
    Cross your fingers... I may have solved the problem of my #2 carb overflowing. I rummaged through my spare parts and replaced the aftermarket, metal-tip float needle (and its corresponding seat) with one of the 46-year-old original equipment ones I took out when rebuilding the carbs when I first started reviving this bike. Did the same in #1 because I thought that one was overflowing last October... though, given the way gasoline moves around, it might have actually been coming from #2 and just finding its way across the rack to #1. Set the levels in both carbs, took it out for a spin yesterday afternoon. The improvement was immediate: I could hear all four cylinders firing, a nice even howl rather than the very distinct parallel-twin sound it had been making. Rode it about 20 miles, pulled into my driveway... and it stalled and wouldn't restart. Finally I tried putting it on reserve, even though the trip meter said 80 miles. Started right up, ran fine. Flipped it back to "on" and within half a minute it was running on two cylinders and then stalling. Back to reserve... all four again.
    This morning I took it to the gas station and filled it up. 2.7 gallons, which (according to past fill-ups) means I was indeed out of the main supply and into the reserve. MPG worked out to something like 33.4, which is about 25% under what I typically see (mid-40s). Well, there was a lot of raw gas just going through unburned... Took the bike for a 70-mile ride. It ran... much better. It still doesn't want to idle properly (a synch will probably help with this) and undoubtedly needs some fine tuning. But... it is at least rideable again. And a fair amount of fun.
  5. ScottFree
    Northern Ill-Annoy
    Update to the above: I got in another 50 or so miles yesterday afternoon. Still rode great, and I was able to check fuel economy on the way back. It is somewhere between 45 and 50 mpg, depending on how much gas went on the outside of the tank, the hot engine, and the pavement at the Sofa King Bad Exxon Station, who had the clever idea of putting a spring on the "vapor recovery" nozzle's hold-on tab so that the thing doesn't shut off when you release the trigger.
    I think I need to replace the throttle cable. With the "Daytona" bars, the stock Maxim cable (for the buckhorns) is way too long, it's rusty, and even though I have the adjuster set all the way in, there is absolutely no slack in it. This may or may not be contributing to the erratic idle speed, but I think it's something I should replace before spending too much effort going into further adjustments that might just be frustrated. Am I correct that a cable for an XJ650RJ Seca would be a proper fit with the "standard Japanese bike" handlebars?
    I also need to do a better clutch adjustment, I think. 1-2 upshifts are a chore above 6000 rpm. 2-3 and beyond are no problem, but winding it out in first gear leads to a major battle to upshift. I copied the "Full Monty Clutch Adjustment" procedure and will try to do it next week. And while we're on the subject, is there any consensus on whether/which choice of oil delivers the smoothest shifting? There seems to be a consensus that the Royal Enfield Himalayan 450 likes Motul 7100, and my experience seems to match that. Or is the Yamaha like most UJMs, pretty indifferent to lubricant?
  6. Fuller56
    Fuller56 Well-Known Member
    ohhh, an oil thread! How fun. Me, I use 15W40 diesel oil for the protection the extra zinc gives the cams. But that reasoning comes from almost 300k miles on Kawasaki ZG1000's that have notoriously bad camshafts. It has worked well in my XJ's. About the time for an oil change (I do 3k miles) the shifting starts to get less easy, not hard but less easy. Fresh oil and generally better shifting. I figure it is just the XJ's way of asking for fresh oil and attention. Fresh oil is more important in my thinking than the weight or brand, within reason of course.
  7. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Well, yesterday was quite nice so I decided to go fly fishing, then decided to take the X and save some gas and enjoy a ride. I put around 75 miles on it and hit two lakes. I almost forgot how hard you need to hold on when you wind it up to 10K on the tach in 2nd gear.
  8. Brhatweed
    Mora MN
    Something really fishy about that post...
    Uxbridge Brule and chacal like this.
  9. Fuller56
    Very nice. Did he get a ride home to (be) supper?
  10. Huntchuks
    East Rochester, NY
    Nope, she went back in the water like the others I caught.
  11. Brhatweed
    Mora MN
    Knew there was something fishy!
  12. RideAlong420
    USA
    Hrm...
    Now what? Had to hit her with some map gas to get to this point lol
    Edit: got both off. I'm slightly concerned about this middle chute thing, but the new hi performance bearings are in the freezer and I'll install those in a bit.
    Guessing I don't need moly grease since these bearings have seals on both sides?
    I have no idea how this inner tube connects, is it just pressure?
  13. RideAlong420
    USA
    Installing the new bearings with a 32mm/30mm impact seems like it might be cracking the metal
  14. RideAlong420
    USA
    We're finding the 15mm bearing remover tool is not expanding enough to try and remove the high performance bearing with the tool for the bearings. Basically because of that, we can't remove the bearing to try installing it again.
    We hit the bearing with the tool correctly for a minute, and pick up the tire and hit the rod and the whole 15mm piece comes off.
    Edit: we measured the distance of the race to see if it was installed uneven and best case it was .01mm off, so instead of trying to remove it, we installed it and it went in finally.
    Had to buy a harbor freight "bearing race and seal driver set" tho.
  15. RideAlong420
    USA
    Day two, I cannot get the left fork tube off
    However, the right fork tube, which is leaking, happens to come right off
    Edit: apparently complaining about the thing, is what helped to get the fork off? Yay
    Edit 2: this also doesn't look like the manual... Air pressurized??
    Edit 3: it doesn't unscrew, the whole thing inside seems to spin, and I can't press it down much
  16. RideAlong420
    USA
    I'm not really sure what to do at this point. I have the fork tip as seen above soaking in kroil but it doesn't want to come out
    Edit2: I moved on to the other fork and that air plug is removed without any effort. Figures. That's the one that's fine. I don't have a vice so I'm using the triple tree to hold the inner tube.
    Edit3: the left fork is disassembled, though I can't seem to get the oil seal out. Maybe I should just leave it there?
    Two hours later and I still can't get this dumb air stem removed
  17. RideAlong420
    USA
    Holy shit I got it!
    I had to apply tension to the spring seat and then use a wrench to forcibly keep the seat stationary
    Now I'm struggling with the oil seals in the forks, they do not want to come out. Tempted to just use my new Dremel and cut them out
    Edit: didn't need to cut them out, they just took a LOT more force with a flathead than I thought.
    Some rust inside, used the deburring tool to remove what rust I could find.
  18. RideAlong420
    USA
    Now that everything is disassembled, I've been wet sanding the inner tubes with 800 and 1000 grit and honestly, I don't think I need the epoxy. It's pretty smooth now
  19. Brhatweed
    Mora MN
    I remember my dad dealing with a scratch on the fork of his Triumph Bonneville years ago and he said it was a matter of getting the "channel" out of the metal and smoothing down enough so the lip of the seal could follow the surface. Guess it worked because it has not leaked in over 45 years that I know of, still has the bike to this day.
    I see I've received eight likes so far on my SECA 750 turning over 50,000 miles, I'm sure there are others who have passed this mark on the original motor. Thanks for the recognition, I'm hoping to post the odometer rolling over 75,000 at some point.
  20. RideAlong420
    USA
    Ok, here's the recap of everything I did to the bike this weekend (mechanically, in order) and some various observations:
    • Took off front tire, detaching the speedo cable first, then the tire, then the caliper (which was way easier to do, because the tension of the caliper felt like it really locked onto the front rotor). Note: (At this point the brakes felt very strong and responsive.) I then took off the fender. In retrospect, the manual says to take off the fender and the caliper and then the tire (iirc) which seems goofy and harder.
    • Removed both wheel bearings using 15mm spreader tool which was very useful in getting the originals out. The wheel bearings seemed to be undamaged, but they're likely 44 years old, and the tire came off, so may as well.
    • Removed both front forks off the triple tree. The left fork was not leaking, but the right fork was. The leaking fork came out of the triple tree by simply removing the tension of the bolts holding the inner fork tube. The non-leaking fork tube was stuck in the triple tree and had to be yanked with a lot more force than the right one, ironically. Saw some signs of rust on the inside of the triple tree, which is probably why it was "stuck".
    • Planned to upgrade the brake lines and both stem bearings, decided to do that another time.
    • Reinstalled two "hi-performance wheel bearings" in the front, but when things looked like it got stuck, we tried using the 15mm wheel bearing spreader tool, and realized that the spreader wasn't actually spreading and when we would lift the tire to pound the long bar so the wheel bearing would be removed, we realized the spreader tool and rod would just, fall out as if it didn't do anything. I should have measured the inside race with a caliper to see how the dimensions differ, but based on the behavior, I have reason to believe that removing the "hi-performance wheel bearings" in the future is going to require a 14mm tool instead of a 15. the 15mm absolutely goes inside the inner race, it just doesn't expand, and thus, the tool doesn't work on them.
    • Added https://www.oreillyauto.com/detail/...-wheel-bearing-grease/mp02/90374?q=red+grease to the outside of the wheel bearings. These ones are enclosed, with no way to open them up without potentially damaging them, so I just added some on top amongst the pins (seen above in images)
    • Added same grease to speedometer hub. The manual says white lithium? which I guess is just slightly less dense? than this. I suppose it should be fine.
    • Disassembled both forks, finding that the leaking fork, has an air pressure valve, which was a pain to remove. The non-leaking fork pressure valve was not a pain to remove, because of course.
    • Using the damping tool, and a hex wrench, I was very easily able to remove the inner tube from the outer tube on both forks. I did not need to apply more than an arm strength amount of pressure to do this, and frankly, not even that much.
    • Cleaned the inner tubes with the long plastic wire brush tool, and wet sanded both inner tubes (which had some slight surface pitting but nothing drastically deep) with 800 and 1000 grit sandpaper). I also used the deburring tool on the top Inner part of the inner fork tubes, where there was some pitting that was a little worse. This is in the area where the inner tube plug sits.
    • Cleaned some rusty stuff and debris from the top of the Outer fork tubes. The Lower fork tube circlip was rusty on both.
    • Damping rod plastic washer was fine, but replaced it anyway
    • Oring on inner tube plug was fine, but replaced it anyway
    • Did not replace the inner air valve the kit came with, as I have no idea how to get inside the schrader valve to replace it. rubber oring seals on the outside of the valve seemed fine
    • Both old oil seals have a spring along the underbody, in a star pattern (as if the spring has gotten has gotten twisted every half inch?). The new oil seals do not have this issue, the spring along the inner fork seal is a circle.
    • Installed oil seals with the oil seal driver tool, very handy!
    • Replaced lower bolts with new ones, even though the old ones seemed fine
    • Replaced lower crush? washer, even though old washer seemed fine.
    • Replaced drain screws, as one was a bit stripped from previous owner. Lower drain seems to have a plastic non-removable insert? Put the drain o-rings from the kit on top of the plastic around the drain screw cause I couldn't figure out how to remove them. There were no drain o-rings to begin with, on either fork.
    • Reinstalled spring (making sure to put the denser part of the spring on top, as the manual says)
    • Reinstalled spring seat and spacer
    • Used graduated cylinder to try and fill 278ml worth of 10w fork oil, but the graduated cylinder has two measurements on it, and one of the measurements starts lower than the other. I think I got about 275ml or so, but I am really not sure, because the cylinder wasn't very accurate.
    • I got a tool that was supposed to be used to "take the top off" extra oil as to not overfill, but I couldn't find a good instruction on how to use it, so I gave up and moved on.
    • Added some fork oil to the top of the oil seal and circlip, and moved the inner tube up and down to make sure it was lubricated and to prevent further potential debris, per manual
    • Added fork tube dust seal, using the aforementioned oil seal driver tool, because that was a pain to get on there without it.
    • Added Gaiter (accordion) boots to the lower part of the front forks to prevent further damage
    • Installed both forks into the triple tree (as I have no vice) got another person to press down with a flat screwdriver on the top plug cap, after I installed the spacer, and installed the circlip afterwards. Having a second pair of hands for this specific step is a godsend, because it is a massive enormous pain in the ass to do yourself. Can I do it? Yes. Do I ever want to do this again? No!!
    • Reinstalled the pressure valve on top of both forks, and attempted to add some pressure to each fork, but Yamaha says don't add more than 17psi or you will risk ruining the fork seals. The internet and the manual seems to suggest around 5.7 psi, within 1.4psi of each other. I have absolutely no idea how this is possible. I have a ryobi inflater that I use for my car and I use it for the tires of the bike, it's relatively simple and accurate. Filling often shows digitally several PSI, and when you stop filling it will give you a readout of the current PSI before you remove the latch (which always loses some PSI from having done so). The smallest blip of this gun brought me easily to 11.5psi, allegedly. I did this on the other one, and it's about 9.5psi or so. That's about as close as I can get without easily blasting over the extremely small range. This was done with no tire on the front end, fully suspended. Me and the gf went to the store to try and find a regular bike inflater (you remember the old step to pump ones? Though you can use your arms if you're feeling strong) but even those seem to go up to like a hundred psi. What tool should I be using for this??
    • Reinstalled front fender
    • Reinstalled caliper, applying anti-seize to the back of the retaining clip that "retains" the top part of the brake pads, and applying anti-seize to the back of the brake pads, where the piston touches the brake pads. (I know to do this on my car, so I figure the same behavior applies here).
    • Reinstalled the pin and clip that holds the brakes in place
    • Reinstalled front tire, with enormous difficulty. Apparently, the middle axle rod has a spacer that goes between the right fork and the wheel hub, and getting the whole thing properly on there is a massive pain in the ass.
    We then lowered the bike off the center stand (we used floor jacks on the frame while it was on the middle stand to secure it upright) and tested it. the front forks felt like they were a bit soft, but I have no idea if this is because there's not quite enough oil in it, and my measurements are off, or, if this is because this is what 10w fork oil behaves like, or if the air pressure is wrong. I don't think I installed the spring backwards, they certainly were resistant enough to hand pressure, but hand strength is different than bike weight. I had my gf test the forks by sitting on the bike and manually pressing the forks in, which looked like they compressed a lot to me (unsure if it was more apparent by the gaiter boots squishing, or if it's normal). They just seem like they're softer than before, before it leaked anyways. The previous technician didn't work on the front forks, so I have no idea when the last time this was done. I also have no idea what the existing fork oil was in this, other than it was ruby red. I have no idea how much air pressure was in these, but I'm guessing probably close to 20 based on how long it took to drain each pressure valve. I'm guessing it had 15w oil instead of 10w, but I have no idea. Eventually the gf seemed satisfied with the front forks, though they, by comparison, are extremely soft compared to her 2025 CB750 Hornet.
    More importantly, it appears that the front brakes are now extremely soft. I had her take the bike up and down the hill, and the rear brakes are working well, but the front brakes are not working very well. They work, but they are engaging very slowly, as if there is air in the lines, is my guess. I very specifically did not remove anything with the brake lines, except to remove the caliper and just had it rest on the "crash guard" all weekend, so that it wouldn't hang on its own cable. The technician said that he rebuilt the front brake caliper (back in october), so that has been done (though there is some rust and corrosion on the caliper piston, and in a few places). The only thing I can think of here, is the "twisting" of the caliper did so in a way that perhaps there was some air added to the brake lines, though I did not detect any leaks of brake fluid anywhere. Thankfully, I have replacement brake lines and crush washer, and bleeder valve, and union bolts, so I can do that next weekend and hope that solves it?
    Finally, I dialed back the idle speed mixture screw, and started the bike again, and let her run for a minute or two, and then took a laser thermometer to the headers. If the left most (while sitting on the bike) is cylinder 1, and the right is 4, then these were the approximate temperatures of the headers from left to right: 250, 450, 350, 450. Meaning, Cylinders 1 and 3 are running rather cold to the rest of the system. I replaced already all spark plugs and caps with brand new ones (5k caps, resistorless plugs). Could the ignition coils be going bad?
    That's a long post but let me know if I did a stupid or what I'm missing here, or if I did a good job for having never done forks before (wheel bearings I've done before, technically. I wish I had a dang press for wheel bearings in the future)
  21. Uxbridge Brule
    Uxbridge Brule Active Member
    Uxbridge Ont
    Didn't do much to the XJ but got the Wr250f started and off the table to make room for the XJ.
  22. Huntchuks
    East Rochester, NY
    Not much time before the carb clinic.
  23. ScottFree
    Northern Ill-Annoy
    Yesterday I took my Yamaha for a ride, a bit under 100 miles and a stop for ice cream. It was generally pleasant (the ice cream was great). The bike ran on all four cylinders and delivered 46.7 mpg despite strong headwinds much of the day. It pulls nicely to red line, and aside from having no low-end grunt (compared to my 95-inch Stage II Harley and my 450cc Royal Enfield Himalayan) it was lots of fun to jump on the throttle. I need to pay some attention to the chassis; while it's overall stable (I can deliberately shove a bar at 65 mph and after a couple wiggles it damps out nicely), it still feels a little more flexible than I'd like. I suspect it's time to have a look at the swingarm bearings, which have never (to my knowledge) been re-greased or adjusted.
    But... the problem of idle remains. If I turn the idle speed knob up enough for it to not gradually slow down and stall, it will not return to idle after it's run at a higher speed. If I turn the idle speed down to the point where it returns to idle quickly after revving faster, it slows down and stalls unless I blip the throttle every ten seconds or so. Sigh. I got out my trusty vacuum gauges and went through the synch ritual again, but this did not help; if anything it seemed to be a little worse afterward.
    So the bike feels like it's this far from running really well, but the definition of "this far" still eludes me. For now, I have set the idle knob down low enough that it returns to idle pretty quickly after I close the throttle (and then slows down and stalls), as this is preferable to the thing hanging at a higher speed. So what would cause it to not idle? When I cleaned the carbs I paid special attention to the idle-related passages, and the at least seemed to be clear. I have also looked for any signs of vacuum leaks, but so far found nothing. It is frustrating.
    Oh yeah, and on the "minor annoyances" list, no matter how aggressively I tighten the nut, the tach cable works its way loose at the engine end every 300 miles or so. I am about ready to add "tighten tach cable" to the pre-ride checklist, as it's a lot more pleasant to maneuver a pliers in there and tighten the thing before the engine's hot!
    RideAlong420 and Brhatweed like this.
  24. Brhatweed
    Mora MN
    So far I've managed to get just over 100 miles on my SECA this season... long stretches of 45F windy weather keeps me off the saddle and unfortunately it looks like we're gonna be in for a somewhat cooler than average summer in cabin country. Today looks and feels more like late October than early May with a temp of 43F and those low autumn looking clouds as of noon with a stiff NW wind pushing 25 MPH on the gusts. We're looking at overnight temps in the 30s before we warm into the low 60's for the weekend... we'll see. I'm small town with lots of rural roads and open farmland so the winds get really strong and miserable.
  25. Huntchuks
    East Rochester, NY
    Yeah, yesterday was mild (temperature), so I grabbed my fly fishing gear and headed to two lakes. Some of the wind gusts almost threw me off the bike! Also, casting a fly was pretty hard to do.
  26. Fuller56
    I picked up an organ donor '81 XJ750 Seca. The young fellow I got it from had put a lot of time and effort into it but from what I received I don't think it will see the road again. The engine is well disassembled but really nicely cleaned, on the outside, not so much internally. Maybe this is the opportunity to build the big bore XJ I have been thinking of, the jugs are off and cleaned...... Thanks for the inspiration @Simmy. No title and to NY DMV that is a death sentence. We shall see.
    Brhatweed likes this.
  27. Brhatweed
    Mora MN
    What did I do to my Yamaha... put some more miles on and used it to spank another HD Sportster.
  28. Brhatweed
    Mora MN
    Okay... So this weekend was a interstate run to IL to visit with some old friends I used to work with at Motorola. Bike ran flawlessly the entire run averaging about 30 MPG running 70-75 the entire run with only a backpack and duffel bag strapped to the seat. Not the best bike for a marathon run at my age but a break every 150 or so miles helped.
  29. ksigurdsen
    ksigurdsen Member
    Wellington, FL
    In years past, I commuted between Charlotte NC and Richmond VA on my XJ750K via I-85. Those stops to refill the tank were needed both for rider and machine.
  30. Brhatweed
    Mora MN
    Shortly after HS I spent some time on the road, back then I had a 1980 Honda CBX Sport and a lot on my mind so with a big wad of cash in my pocket and some basics in duffel bags I hit the back roads and lived on gas station grub. I won't say the honda was more comfortable but having just turned 18 and with only 160 pounds on that saddle it was easier, got the bike a few years earlier for almost nothing as the previous owner got frustrated with the 6 carburetors... they were a handful no doubt but for $400 I was up for the challenge. Now coming on 57 and 220 pounds it takes a while to sort myself out after a marathon run, at least the 4 carburetors don't need much attention and the SECA gets about the same mileage.
  31. Huntchuks
    East Rochester, NY
    I saw one of those at the DGR. Was beautiful.
  32. Brhatweed
    Mora MN
    A fun bike no doubt but the guy I got it from wasn't much into maintenance so at 5 years old it was a little rough around the edges. Mine had the black tank & panels but the aluminum had a lot of corrosion and inner frame was caked with dirty chain lube but for $400 the summer of 85 I wasn't complaining. Totally naked with an aftermarket 6-into-1 exhaust he painted flat black that looked like a bundle of pissed off snakes getting shoved thru the back of a funnel and a bad case of road rash on the front, there was also a rash on the right hand side of the crash bar and muffler where he had a mild lay down at some point. For some reason he pulled all the wiring out of the side cover I suppose attempting to remove the airbox and replace it with this custom halo style open element filter and also broke the nipple off the rear brake reservoir.
    Everyone thought I was gonna kill myself on that thing, it was big & intimidating and I was afraid of it at first but that eventually turned into respect until I got stoopid a few years later drag racing a buddy on his Ninja in an industrial park and had to lay it down when a semi pulled out, things got really ugly and I hung up the helmet for a good long while after that. Bike ended up at Sportwheels in Jordan.
    So today I pulled my SECA starter apart for a clean & lube, rear bearing was starting to howl and I didn't want it getting beat up. For as much riding as I do this bike has been one of the most reliable, oil changes and occasional attention is about all I've had to do. Same battery now for the past three years and only adding water, new front brake pads & stainless lines from Chacal and tires last summer. Now my dads Norton on the other hand... where should I start?
    Huntchuks and Dave in Ireland like this.
  33. Brhatweed
    Mora MN
    ...and the hits just keep on comin'.
    After I went thru the starter motor I decided today would be a great time to check things over, yeah the motor needs some help. First thing was a vacuum check to see where the carbs were at, nothing too bad but #3 was running a little low on the numbers so I decided to investigate further. Feelers out and check the valves, everyone is on the tight end of spec but not holding any valves open so I have time to shim shop. Pull the plugs and take a look, #1 and #2 running a bit rich, #3 just showing slight rich but still tan and #4 was good. Next was the compression gauge and that's when the truth came out.
    Compression numbers are 6 puffs on 100 degree or so warm jugs, oil was a 5cc shot of Lawn Boy 2-stroke measured with a syringe so I didn't bump up the compression ratio.
    #1 dry: 145 oil: 195
    #2 dry: 140 oil: 180
    #3 dry: 90 oil: 160 (yes 90 after two checks and ten puffs)
    #4 dry: 140 oil: 175
    Yeah this boy needs a set of rings something bad. It runs and starts easy, quarter mile times are way off the mark at 14.16 @ 95.83 topping out at 105.79 before letting off but it didn't feel like there was much more to go. I'm using the Dragger app with the phone cradle mounted to the bike and the numbers feel right from experience but not what I expected.
    I looked in the bores with a scope and can see clean halos around the pistons with the #3 being the worst, bike used a full quart of 10W40 conventional going to Rockford IL and back so I'd say it's time.
  34. RideAlong420
    USA
    How many miles are on that engine?
  35. Brhatweed
    Mora MN
    Over 50,000 and from what I can tell it's never been opened past the cam cover.
  36. Brhatweed
    Mora MN
    Changed out the main jets this afternoon going from 124's down to 120's and set the floats, going to do a run around lake Mille Lacs to check the MPGs and get some fresh color on the plugs. Will post the results.
  37. Brhatweed
    Mora MN
    Okay so the 120 jets put the MPG's back in the mid-40s running an average of 52 MPH on a 115 mile test run, everything was going well until I hit the US 169 detour and turned around. Not a big deal really and I got the info I was after... unremarkable except for a lack of dead zone between 5000 to 7000 RPM and the engine response definitely felt much sharper rolling on the throttle however after 7000 there was a marked lean surge and full throttle breakup. A quick check of the plugs shows most the carbon has burnt off but I need a much longer run to get some good color, tonight would have been perfect for this as the temps are reasonable and the humidity is low.
    If you're not familiar with Mille Lacs it's a large inland lake known for its walleye that spans about 14 miles at its widest point and a depth of about 40-some feet with hundreds of cabins around it. Today had a north wind and when I started the ride around the lake it was 63F in Isle all the way to US 169 and the low 80's by the time I hit Garrison, I could really feel a difference in engine performance with the change in air temp. Garrison is on the northwest corner of the lake along MN state highway 18 and one of the last stops before Brainerd MN... in the winter we call it Brrrrainerd.
    I might go with #122 main jets in the near future as the 120's are a little too lean to run much beyond say 60 MPH
  38. ScottFree
    Northern Ill-Annoy
    What did I do to my Yamaha today, or more precisely yesterday? I rode it 150 miles, with an "official" purpose of picking up some parts for my Himalayan. While I was at the shop, I recalled that the Yam was overdue for an oil change (based on time, not miles), so I picked up a filter (which, to my surprise, the shop had in stock) and changed the oil when I got home. I am still delighted with how easy this process is (at least if you assume draining the little bit of oil that's in the middle gear section isn't really essential). Compared with my Harley (drain plug buried, spin-on oil filter on its side above the voltage regulator, guaranteeing a mess, and three different lubricants to change) or my Himalayan (remove skid plate, remove two awkwardly located plugs, clean two mesh screens, change a dozen o-rings, tape a piece of plastic bag to the side of the motor to catch the oil that dribbles from the filter cover), changing oil and filter on the XJ is a piece of cake. Somebody at Yamaha actually thought about the owner!
    Anyway, the ride... 150 miles. Ran mostly 45-65 mph, though I wicked it up to over 80 to pass a slowpoke in a truck at one point. A little bit of gravel, as many curves as I can find in this part of IL. I found my improved "booster seat" is good for about 50-60 miles before I have to get off and walk around a bit. Better than the stock cruiser seat, but I still keep thinking I've got a spare Harley cop bike saddle in the garage... those things are the absolute bomb for all-day comfort, which is why I have them on my Road King and my Himalayan. I have no doubt I could install one, possibly even on a spring mounting, on the XJ.
    Other things I noticed: I need to snug the steering head bearings a bit. I installed tapered rollers a couple years ago, and they seem to require the occasional slight turn of the adjuster. My suspicion is that I didn't bottom the races completely in the neck (I'm talking a couple thousandths) and as time passes the races are finally getting all the way in. I also need to clean, re-grease and adjust the swingarm bearings, as this has never been done.
    I also noticed that the rear brake shoes, replaced about 1500 miles ago with EBC items, seem to be finally bedding in and making the brake more than just decorative.
    And, of course, there is the issue of the idle, which I mostly chose to ignore yesterday. The bike runs fine everywhere but idle. Once it's off the initial enrichment, it slows down and stalls over a period of several seconds. I notice that if I stop after a run at road speed (over 45 mph), it sits around 2000 rpm for one or two seconds, then slows to about 1100 for a few more seconds, then slowly drops until it gets down to about 750 and stalls. If I turn the idle-speed knob under the carbs to make it idle at 1100, it will not return to idle after the throttle's opened. For the time being, I have chosen to just live with this and "blip" the throttle if I'm at a stop for more than a few seconds. I notice that when I blip it up to 2000 rpm at a stop, it doesn't hang there but rather drops back to 1100 very quickly--unlike what it does if I come to a stop from running at road speed.
    I have two hypotheses about the idle problem (I have already pretty much eliminated the idea of a vacuum leak following many experiments with WD-40/carb cleaner around throttle shaft seals, intake boots, etc.). The first is that perhaps one of the vacuum pistons is not dropping as quickly as it should. This might explain why the idle hangs and then drops when I stop. When I checked them, I found that all four do drop, but the #2 did not make the same satisfying "thunk" that the other three did. Is there a trick to lubricating, polishing, or doing something else to make sure the pistons move completely free? I also wonder if there is some kind of obstruction in the passage between the throat and the vacuum chamber. The second hypothesis is based on the "theory of operation" section of my Harley manuals (neither Yamaha nor Haynes try to explain how the CV carbs actually work, but my Harley factory books had many pages on how the Kehin CV40H--which IMO might be one of the best carbs ever made--functions). It appears that idle and small throttle openings are entirely controlled by the slow jet, mixture screw, and the ports above the throttle blade and below the mixture screw. The pistons, main jet, and needle don't get involved till the bike is moving along. If so, my problem could be some kind of restriction in the idle circuit of one or more carbs, forcing said carb(s) to be synchronized such that the piston system is involved in supplying fuel at idle... and at such very small movements, that system is likely to demonstrate instabilities. So... another visit to the Church of Clean, perhaps, paying particular attention to the idle circuits.
    It's a little frustrating. I really like the way this bike works. It's smooth, it has more than enough power for my purpose, it's light enough, compact, easy to live with, and fun to ride. I might consider getting rid of one of my other bikes to make room in the garage, if only I could get the carbs dialed in... and maybe get a bigger gas tank. Even at 48.3 mpg (yesterday's measurement) that tank empties pretty quickly. I've looked for an XJ750 tank a couple times, but so far had no luck finding one that wasn't over-priced scrap metal.
  39. RideAlong420
    USA
    I picked one up from ebay the other day that looked good. Got it in and there is a decent amount of varnish and rust but I believe it should be fixable, if I can get it to my friend's house and block off the ports and let it sit for a week while the vinegar does it's job. I'm really starting to hate living in an apartment, and I wanna move into a shared house that has garage access for this bike.
    I have a 82 xj650 and I feel like the tank empties way too quickly as well for my liking. I topped it off, before I had taken the carbs off, with ethanol-free gas and drove it around for maybe an hour and a half (maybe 20-30 miles?) and I look in the tank and I'm like "where'd all my gas go lol"
    It's a cute 3.4g but I'd certainly throw an xj1100 sized tank if I could, or increase the gas mileage somehow?? Probably not possible. 5 gallon tank is probably the minimum I'd want for a bike with this kinda mpg.
  40. Brhatweed
    Mora MN
    With the stock 120 main jets in my 750 seca I get about 40 on the highway running 60-65, but with the 124s this dropped into the 30s and mid 20s on the interstate burning the 88 octane nonsense. Only once have I touched the magic 50 mpg.
    Riding the bike fuel economy isn't high on my priority list and I'm about to see how it runs with 100LL AvGas on a set of 122 mains.
  41. Miixxa
    Miixxa Member
    Finland
    What I did today (and every day for the last week) was try to diagnose the extremely rich running XJ750S 11M Eurospec
    These Hitachi HSC33's with eurospec emission ports at the enrichment circuit are a freaking pain to adjust.
    Today I finally took the whole carb rack apart and took them to church properly. I suspected some unmetered fuel was seeping past the jets, so I replaced the washers and made sure they seal properly.
    During the process I found out my issue might be the enrichment plungers leaking, as the wells of them all have some scoring on the bottom. I did go through the enrichment needles with a 2000grit soft pad until completely smooth and tried to clean up the wells with the same stuff and soft conical grinding bit. Replaced all o-rings on the carbs but didn't have those proprietary shaft seals at hand nor am I worried about those since I'm having excess fuel entering the system and no intake leaks.
    Threw the whole rack back onto the bike and...no change. Extremely rough running and popping at idle which gets slightly better when i plug up the breathers on the enrichment circuit = leads me to believe that's the culprit for my issues..
    Any idea how to get those enrichment needles to seal properly again?
  42. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
    I had one of those bikes when i was a London despatch rider and it did my head in because it felt like the bike was surging at motorway speeds.
    Anyway, took the carbs to a mate of mine who blocked off those extra breather tubes coming from the carbs and the bike ran good as gold after that.
    Maybe give that a try.
  43. Miixxa
    Miixxa Member
    Finland
    Yup, I've blocked those vents against the recommendations online because it's clearly ripping air from there.
    Since thise have been blocked it's now drowning in gas, so i need to block off the petrol too or go get some lapping compound and get to work with the choke plungers. Might try temporarily adding o-rings or some sort of round rubber gaskets under the plungers to figure out if it is the choke that's quite literally choking the bike at the moment...
  44. co.dirtbiker
    co.dirtbiker Active Member
    Colorado, USA
    Finally got around to giving the 750 Seca a much-deserved oil change, as well as starting it for the first time in probably more than a year. Literally had to wipe the cobwebs off to get to the filter. The battery was a little weak, so I ended up having to give it a boost, but as soon as I did that, it fired right up.
    I still have some more work to do before I put it back on the road though. Overdue for a brake fluid change, and really, I need to rebuild the calipers too. One of them is dragging and wearing out pads. I had also bought some jets to swap out a couple years ago in hopes I could eliminate the flat spot off the bottom, so I'm interested to try those out.
    Still debating on whether I take the 750 or the 900 to the Top of the Rockies Rally this year. Probably leaning towards the 900 again. It does better at the higher altitudes.
  45. Brhatweed
    Mora MN
    So what did I do to my Yammie today... chased another Yammie that was on a trailer going thru town this afternoon, a VERY nice Maxim with what looked like bright colors on the tank. Couldn't get close enough with all the traffic but if you went north on MN Hwy 65 thru Mora just after one Wednesday afternoon I'd like to hear back from ya. Yes that was ME coming up from behind until I got cut off by the DQ & McDonalds.
  46. Huntchuks
    East Rochester, NY
    Yesterday I rode (Maxim X) to my son's place where my red XJ700 airhead was stored all winter. The bike was between his two bikes and all three were covered with a tarp during the winter months. Wind blew the tarp, causing all three to tip over on top of each other. This broke my clutch lever and screwed with the orientation and positions of both mirrors and the left side controls. I finally took my replacement lever over and replaced it. Adjusted the controls and mirrors, took the battery off the maintainer, set the petcock to prime, cranked a bunch of times and it finally fired up. A test ride went well, had to stop and add air to the tires which were around 25 psi, rediscovered that the bike can go like a bat outta you know what!
  47. Mark A. Miller
    Mark A. Miller New Member
    Michigan USA
    Yesterday I started cleaning up and restoring my Seca 900. Hasn’t been started since 1997
    Wish me luck!
  48. Brhatweed
    Mora MN
    You're in the right place for the restoration. Welcome
  49. Ribo
    Ribo Prefectionist
    Dave in Ireland likes this.
  50. Dan Gardner
    Minneapolis, MN
    #rescued
    Rooster53, Brhatweed and ksigurdsen like this.
