  1. dkavanagh
    Rochester, NY
  2. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    That's looking good - will it be a single seater? Guess not with those pegs on. Some vmax cues I recognise from that era - front wheel style, footpegs, head "finned" casting. There were a few of these around ebay and so on in the UK, not so many now, perhaps it's for the best..
  3. hogfiddles
    No, standard build. The seats and backrest are new covers from xj4ever.
  4. Tim O
    Tim O Active Member
    Charlottesville, VA
    So I normally try to keep my Seca 100% Stock. But, the side panels are so oxidized in the "Black Area" they are pretty much silver all over and the black just looks dirty.
    Thoughts on the carbon fiber look?
    Jetfixer, NEEDtoRIDE, chacal and 4 others like this.
  5. jaxcob93
    jaxcob93 New Member
    Illinois
    Replaced front brake lines with braided steel and the rear shoes. The original Yamaha ones looked to have lots of wear left but they still went on the shelf as “in a pinch” parts. Tires are ordered and once those come in I’ll be riding more regularly and motivated to fix the Atari cms and get the carbs dialed in perfectly. She idles and moves just fine now, just a flat spot around 4K to work out
  6. Minimutly
    West Wales, uk
    This has made me think about my own frame up build. It's an xj900f, frame, engine and airbox. I have a 650 maxim tank which I like the look of, but it doesn't quite fit the frame. Is there another, wider at the base that might fit? I've compemplated splitting the tank and letting a wedge into it, but it seems a bit drastic.
    The rest of the bike is waiting for a suitable xj900 diversion, the plan being to rob wheels and forks off it. Yes it might be nice to have wire spoked wheels, but better suspension tyres and brakes are high on the agenda.
  7. hogfiddles
    I like that.... subtle. If there were more, j probably wouldn’t like it. But that is good——,do it on the sides of the tail cowl where that blackout is, too.
    Tim O likes this.
  8. hogfiddles
    This afternoon’s progress—- a few NOS parts that have never been out of the box.....and new seat covers from xj4ever
    jaxcob93 and Rusty81 like this.
  9. Jonathon Kent
    Jonathon Kent Member
    Rochester NY
    Yay for upstate!!! Not!!!! Dang snow
    xj6504lyfe likes this.
  10. Tim O
    Tim O Active Member
    Charlottesville, VA
    Thanks!
    I was thinking of that because it too is pretty "cloudy" and dirty looking.
    But, like you, I'm thinking too much of the stuff will make the bike look cheap... "From the 'hood" so to speak. :confused:
  11. xj6504lyfe
    xj6504lyfe Member
    Norwich ny
    Aaand now its 82 out.
    Rusty81 likes this.
  12. hogfiddles
    And under tornado warning
  13. Joris
    Joris Member
    Eindhoven, NL
    I decide to part out my XJ900F.
    A couple of weeks ago I had started to rebuild her after 10 years of standing still, but I found just too much expensive repairs.
    One of which was that the head was apparently warped so that exhaust gasses passed over the gasket to the opening of one of the studs.
    I will put an advert in the for sale section.
  14. Jetfixer
    Well the starter clutch is getting worse get bike hot and slips you have to try it several times and then catches been getting , I've been in denial well guess it is time...to swap out engine for the spare engine I've had for 2 years . Bought engine off Joe Eliff ( thanks Joe) all we know is bike it came from had 38k , I did a compression check all good 120 to 130psi ...I have. To check valves and going to pull oil pan to check for anything hinky . My goal is if engine is good , tear down original and replace starter clutch at some point.
  15. Joe White
    Joe White Member
    Keller, TX
    The vision is slowly coming into focus. The gas tank is NOS perfection. The fuse box is Georgia Jackal stock (thanks Len). The headlight & instruments are flea bay specials
    Franz, Rusty81 and Minimutly like this.
  16. chacal
    Looking good Joe! But........what is that on the ignition key?
    XJ550H likes this.
  17. Joe White
    Joe White Member
    Keller, TX
    It’s just a raggedy piece of leather, it came with the bike. Near as I can tell, when the PO wasn’t busy hacking away at superficial components, like fuse boxes or brake master cylinders and in between the monthly crashes, then he entertained himself by attaching his motorcycle key (with the leather fob) to a twenty foot chain and dragging it around Texas on every caliche road he could find. Based on fob wear, I’d say it has at least 50,000 miles under its belt. When I brought the bike home, that raggedy piece of leather was the best looking part of the bike.
    chacal likes this.
  18. Jonathon Kent
    Rochester NY
    Got my master cylinder rebuild from Len, tore the master cylinder apart. Got it rebuilt. Did a bleed from the bottom end of the system. Forced fluid from the bleeder screw all the way to master cylinder. Wow what a difference; to have brakes again. And of course the moment I had brakes again the moment came very quickly when a solid apply came... fricking old lady didn’t see me over her steering wheel. Just made me appreciate having rebuilt the master cylinder myself and having bled the system. However I got the bike nice and hot on the back roads; fun fact that I learned about my bike it can hit 60 mph in second gear!!!! That was awesome and the engine screams for more! I love my 650. And to all who have done small write ups of registering bikes through the Vermont dmv. Thank you; this took a while to get cleared but my Harley sportster is finally registered to me from a passing relative and they, along with myself were very worried that the bike would get caught up in the legal system to pay medical bills.
    Simmy likes this.
  19. Jonathon Kent
    Rochester NY
    Got myself and the old lady on the 650 today and rode to Dansville. Which is about an hour long ride. Cruised at nearly 80 mph for a good long while. That bike pulls like crazy!
  20. SQLGuy
    SQLGuy Well-Known Member
    Removed the oil cooler adapter plate so I could add an O-ring to it (had sealed it with Yamabond, but that didn't seem to be quite good enough). Made a tool to cut the groove in it and started cutting it in the lathe... got the groove about halfway done, but had other things I needed to do. Will try to finish and reassemble it tomorrow.
