  1. Franz
    The bike is fine, new clutch is cheap and easy to do.
    hogfiddles likes this.
  2. Edward I Simmons
    Edward I Simmons New Member
    Oregon
    I already bought a new clutch set up, I was pretty upset and still on the side of the road with plans ruined waiting for a tow truck when I posted that. It didn't look very promising when I took the clutch cover off and found that my pressure plate had turned to gravel.
  3. SeanM706
    SeanM706 New Member
    Took apart the front end and gave my fork lowers a coat of black paint because the original clear was looking pretty bunk. Next week the tank and side covers go to the paint shop for as close to a factory black-red as they can get.
  4. Franz
    Fitted new starter clutch rollers and springs, primary chain and guide and a new cam chain today and assembled the crankcases.
    kosel likes this.
  5. SeanM706
    SeanM706 New Member
    Edward I Simmons and Rusty81 like this.
  6. hogfiddles
    I turned my silver 650rj into a red 650rj
    kosel, SeanM706 and Rusty81 like this.
  7. Rusty81
    Rusty81 Member
    Sarnia On, Canada
    Finally got my carbs back together! Was having issues with the throttle shaft seals. Took a lot of searching on here to find that they are not 11mm but #11 O-rings!! (5/16 ID x 7-16 OD x 1/16). The 11mm ones I tried made it way too tight.
    Used X-rings on the inside, #11 on the outside and the butterflies snap shut. Wet level set, carbs synced and off to the races.
    Going to do some plug chops to see where I need to go for jets as I’ve gone back to factory, but it’s working well. Thanks to all the gurus on here for your knowledge.
    Franz likes this.
  8. Franz
    What a spray can or other parts?
    SeanM706 likes this.
  9. Ken w
    Ken w New Member
    New York
    Headlight and gauges removed, tank off and drained, pipes dropped, front fender removed, by this time tomorrow engine will be on my bench
  10. hogfiddles
    Swapped all USA silver/blue parts to Canadian red parts
    SeanM706 and Franz like this.
  11. Jetfixer
    Resynched my carbs using my Morgan tune ,ran good and took it out ran the dog snot out of it. Pulled in garage and fuel was pouring out :eek: number 2 carb float bowl drain screw had backed out, lucky it did not ignite . All is well now.
  12. Littleone
    Littleone New Member
    Minnesota
    Was able to get it spark on all 4 plugs. Now moving on to the carbs... Any tips on cleaning without rebuilding?
  13. kosel
    MInneapolis, MN
    Yes. Don't. Unless you rebuilt them once yourself already, avoid the aggregation and do it while they're out. Seems like everyone that tries to just clean them has to has to rebuild them anyways.
    Jetfixer, Franz and Littleone like this.
  14. Don Wiggins
    Don Wiggins New Member
    San Antonio, Texas
    Timbox, Jetfixer, Rusty81 and 2 others like this.
  15. Franz
    I am rebuilding my carburettors and l think it is better to do this than risk running problems later. Do the work thoroughly and you should be rewarded with a reliable bike.
    Jetfixer and Littleone like this.
  16. Franz
    Home made clutch basket holding tool. Easy to make and does the job.
  17. Rusty81
    Rusty81 Member
    Sarnia On, Canada
    You’ll see a bunch of posts on here about people having to do their carbs multiple times to get it right. I’ve been that guy too. The more you fix right the first time they’re apart, the less you’ll have to worry about as you go along. And o rings and carb cleaner are not friends.
    Good luck moving forward!!
  18. Eric Hughes
    Eric Hughes Member
    North Carolina
    Rode it around illegally, cause sometimes that’s what you need to do, when your title is in limbo but you have a tag that might not prompt too many questions. New to me 82 650 runs great other than wanting to die at idle and a little hesitation when powering up for a hill. Time to tackle the carbs I reckon. Even with the hesitation it’s nice to have something to ride and I don’t know that I’m dedicated enough to get them clean and back on the bike in a day. Maybe I’ll check the valves first....
  19. Franz
    Yes valves first.
  20. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Couple of days ago replaced the speedometer back cover, the reset knob and clutch safety switch (courtesy of Mr. Fiddles).
    Yesterday installed a windshield. Smoked is still hardly visible.
    ksigurdsen and Rusty81 like this.
