  1. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    If it's a bowl type dent, you can strip the tank, fill the dent in with bondo, and repaint.
    Easy!
  2. mav2
    mav2 Member
    charlottetown
    hey all had a good day today finally got the xj out of the shop, here are some pics..[​IMG]and here is a shot of my new ign switch[​IMG]
  3. tennsouthernbelle
    tennsouthernbelle Member
    Morristown, TN
    Yeah you make it sound that way, but you're talking to a chick that can't even paint her fingernails with out messing it up.
    Some day when I have money (read I have four kids so I'll never have money) I'll pay someone to fix it lol
  4. hardlucktx
    hardlucktx Member
    Allen Texas
    took the carbs off again and found out what size jets were in there found them to be stock. Took the pods off reinstalled the factory airbox. Resync'd
    and colortuned. runs great then but a new front tire on and found that it was missing the spacer and dust boot on the right side trying to track those down and shes ready to ride.
  5. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    Most women I know have no idea how to even ride a bike, much less keep it running. You've done a lot and should be proud of your success!
    3 years ago I'd never even been on a bike, much less know how to repair one it's always easier to let someone else repair your bike, but you don't get the same satisfaction. You can look at your bike from across the drive and say, I know you.
  6. maxhog650
    maxhog650 Member
    Boulder, Colorado
    Today I lost the key!! but yesterday i took it for a 140 mile trek around colorado topping oput at 14,230 ft. maxim 650 worked great
  7. MadMaxim85
    MadMaxim85 Member
    Lansing, MI
    Today I swapped my old worn out rubber boot for that crazy alternative a flexible coupling 1 1/2!! It works awesome! The best part is, I didn't have to pull the carbs off to put it on!
    I heated the part with a heat gun (read 1500v industrial hair dryer) until it was pliable, the slipped it into the recently vacated airbox hole. Tight fit! A little wd40 and I smoothed it into position.
    What would have cost me nearly $40 ended up costing me about 3.80+ tax.
    This site is AWeSOmE!!!!
  8. binnie_the_baby_maker
    binnie_the_baby_maker New Member
    I made everything far worse than it was by messing about with things i dont really understand!
  9. chacal
    Yeah, B can follow A like that.
    Do you work for the government?
    Would you consider a leadership position, say perhaps, at the White House, or the Treasury? How about Chairman of the Federal Reserve?
    You are very qualified for high-level management positions of almost any type........
  10. grutz
    grutz Member
    Akron, Ohio
    Re-wired most of it, after pushing it two miles to a friends house, cause it suddenly quit on the expressway....
  11. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    I had to do an emergency oil change to her tonight....
    Another victim of SSFVS ,, (Sudden Stuck Float Valve Syndrome)
    Ran fine for about 8 blocks or so, then sputtered and no power like you left the choke on or something.... Luckily it quit new a friends house....
    So left it there, called the wife and went to work..
    Showed up on the way home and ..yes I had more "oil" than I started with..
    Pulled the carbs, cleaned them up, re-installed ..ate, changed the oil...
    Seemed OK afterwards, carbs filled without any leaking ( had my hand in through the airbox feeling for overflow...) I guess tomorrow will tell...
    And after I treated her to new shoes too..... tsk..tsk....
    I did tag a big pothole yesterday... maybe jarred something????
  12. grutz
    grutz Member
    Akron, Ohio
    Laid it down...on my leg...no riding for a while...
  13. jarreddaughtry
    jarreddaughtry Member
    Smithfield, N.C.
    Finally finished going back to my factory setup. i went from stock to pods to stock. i threw those pods in the trash. they can make the trashcan run better than a bike.
  14. MN-Maxims
    MN-Maxims St. Paul Minnesota
    Saint Paul, MN
    I installed my new old stock luggage rack brackets and finished my MAC 4 into 2 exhaust on the 1100. She sounds sweet..........
    MN
  15. Gamuru
    Gamuru Guest
    Granite Falls, WA
    A trip in the morning had me scrutinizing both my and my wife's bike. I printed out the T-CLOCKs (.pdf) sheets and went down the list. A few things needed attention, but all-in-all everything seemed pretty good. Should be a fun adventure.
  16. tennsouthernbelle
    Morristown, TN
    I'm feeling a lot better so I decided to go take a good long look at the damage to my poor Seca. My 5 year old asked if my motorcycle was mad at me. I told her probably.
    I looked up how much it's going to cost me to fix him. Thought about selling him back to my brother. Then decided I really don't want to give up on him. If I have to I'll buy one part at a time. If it takes me three years I'll have that bike back on the road. You can be sure I'll have a jacket on!
  17. Gamuru
    Gamuru Guest
    Granite Falls, WA
    ^^^ Good! Glad to hear it!
  18. RiderXJ
    RiderXJ Member
    Kimball,Michigan
    I finally finished the work on my 1100. It was a basket case when I picked it up back in January. It barely ran and the P/O used a rattle can to change the color. I still have a few small things to take care of but for the most part, it's road ready. I had to.....
    Rebuild the carbs and Sync
    Rebuild both master cyl.
    Rebuild all calipers.
    Install new fuse panel.
    Adjust valves.
    Find and recover a backrest.
    Recover the seat
    New tires.
    New Brakes
    Clutch cable
    Paint
    and clean polish all the aluminum
    I'm pretty happy the way it turned out..It was all worth every minute/hour I spent getting it together.
    I hope the link to the pics works.
  19. SecaRob
    SecaRob Member
    Cincinnati, Ohio
    Glad to hear you have not given up and are doing ok.
    Make a list of what it needs and report back to us. There are some incredible people on this board with oodles of extra parts lying around
  20. Ltdave
    Ltdave Member
    i participated in this thread long ago when i first found the forum and while ive done stuff, i never added to the thread...
    today i put new brake light bulbs in the 900rk, and wiped a lot of road dust off in preparation for tomorrows ride into work...
    man i hope its not raining tomorrow cause i need to ride!
    that is all...
  21. iwingameover
    iwingameover Active Member
    Got her on the road with all the parts on for the first time in 2 years..... Got her tuned in, hassled by the rent a cop for the parking lot I chose to ride in (was close to the tools) and rode about 50 miles.
  22. 85MaximXX
    85MaximXX Member
    S.W. michigan
    I took the windhshield off it is too hot to have it on. Wow I forgot how much wind that it blocks hehe.. It only took about 3 min to take it off and leave the mounts. I need to either practice or find a no tools way to pop it on and off and I know without it next time it rains I am going to be soaked. I love the feeling of the wind rushing over me tho instead of going around.
  23. hogfiddles
    >never thought id own THREE of these!
    Hey LtDave, nice to see you again! I didn't know you had an 83 900RK. I just got one a month ago or so. Check it out in my gallery. I never thought I'd own ONE of those.
    Wonder if I'll ever give up enough of these to own only THREE of these! heehee
  24. hardlucktx
    hardlucktx Member
    Allen Texas
    hadnt had time to post . but friday I put the collar in the front wheel that I discovered was missing and put alittle over 300 miles on her this weekend.Found a few minor things I need to address but at least shes back on the road after sitting for eight years. Thanks to all the folks on here and the help they provided.
  25. grutz
    grutz Member
    Akron, Ohio
    Two day post:
    Yesterday - Changed back tire, cleaned / inspected / adjusted rear brakes, rebuilt master cylinder, adjusted my handlebars forward a bit.
    Today - Rode to work. Nice.
  26. MN-Maxims
    Saint Paul, MN
    I took my spare set of the square handle bar risers and stripped the clear coat. Then wet sanded the grey dull corrosion off. Got them over to the buffer and let them have it. They both shine like chrome so I swapped them out on my #1 1100 and i dug through my parts boxes and found two of the black angle plugs to put in there. She looks even better now. Next on the list is to swap out the oil pan with one that has a good drain plug.
    Pictures to come soon.
    MN
  27. xyxj650
    xyxj650 Member
    Fergus Falls MN
    I put in my replacement stator fixed my rear tail light and took it for a little ride! Man am I happy I had the spare parts to fix it. I got a box of parts for 20-30 bucks and man that was well spent $ ! Just wish my wife would see it that way! lol
  28. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    New o-ring for the petcock selector lever. Five new valve shims installed. New valve cover gasket. Three stripped valve cover bolt holes! :x Three Heli-coils installed in the stripped holes. Valve cover back on and tightened to spec. :D New float valves and seats installed in the carbs. Carbs re-installed. Rode the bike and had to back the idle screw off. This actually took me several days.
  29. RiderXJ
    RiderXJ Member
    Kimball,Michigan
    I installed the 2 valve shims I was waiting for from Len. Thanks!! super fast shipping BTW. Re-synced the carbs. Adjusted the rear brake. Pedal seemed a bit low. Went for an exhilarating ride and smiled the whole time. Came back and put a nice coat of wax on the new paint.
  30. SQLGuy
    SQLGuy Well-Known Member
    Took about a 250 mile round-trip ride from Colorado Springs up to Breckenridge and back (24 and 9 on the way up), (9, 285, 470, 85, and 70 on the way back).
    Also checked my gas mileage for one leg, from Woodland Park to Breckenridge (about 90 miles). That's mostly between 7000 and 10000 feet elevation, lots of up and down, and averaging about 60 mph, and I got 43.7mpg. I'm pretty happy with that.
  31. MNdave
    MNdave New Member
    Maplewood, MN
    Well I thought I would try to see why the bike wouldn’t run. I pulled off the gas, tank drained it out. I did this 3 times, every time putting a little bit of new gas in the tank and by the end I had about a quarter cup of dirt and junk the came out of the tank. Then I replaced my fuel shut off valve with a new one cause the old one was bad. And then I primed it, pressed the start button and she fired right up. But now it don’t want to idle :x .
  32. frankenbike
    frankenbike New Member
    michigan
    today I mounted and balanced a new back tire, then rode rode and then rode some more :D
  33. ethanch
    ethanch Member
    Spokane, WA
    I replaced my Seca cable to master cylinder front brakes with a full-on master cylinder to steel braided lines, I just cut the brake lever ears off the control handle; removed everything stock from the lever down to the anti-dive, disc sanded the removal area smooth and gave the bare aluminum a nice paint job. It looks really nice and works great!!
  34. Carvall
    Carvall Member
    Seattle
    Two weeks ago I got a 82 XJ750 for $6O bucks. I have been since cleaning the carbs and and the bike in general. I took the bike for a 100 mile ride yesterday and it is teh best deal ever. The Bike is solid and the engine can't get better. Syncing is the best you can on your carb tunning. I am looking forward to color tune it.
  35. RangerG
    RangerG Member
    Took the bike on a 90 mile coffee run. Went to a neighboring town and had coffee with some fellow workers. Bike is finally running the way it should. Carbs were off twice for all new seals, o-rings, float valves and seats and valves are all in spec now. Sync is done. Plugs all look good. Less than a month til my next 3,000 mile ride.
  36. ZaGhost
    ZaGhost Member
    An XJ for $60 ... why can't I ever find these deals :/
  37. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    True story!! Man I wish i knew more bikers
  38. b0bv1la
    b0bv1la Member
    Mid Ohio
    After having to go through all my wiring with a turn signal issue I figured I would get rid of those oversized eyesores on my bike and follow some of the advice on turn signals on here. Replaced rear lights and installed a new flasher unit and everything works better than before
  39. b0bv1la
    b0bv1la Member
    Mid Ohio
    Also after hunting hi and low for some way to stretch out on this bike (I'm 6'1") I figured out a way to put some Hillbilly Hiway Pegs on the xj without spending a fortune. These will be replaced someday with forward controls but for now these are really comfortable.
  40. johntc
    johntc Member
    South Dakota
    Not bad and they look like they still fulfill thier function of being seen by others. Personally, I'm willing to put up with the "oversize eyesores" in return for their great visibility but to each is own.
  41. b0bv1la
    b0bv1la Member
    Mid Ohio
    Oh i agree to each his own but the new lights are brighter and after switching the flasher relay the blink rate seems a little quicker. They are still highly visible and safety was definitely on my mind when i changed them.
  42. Pseudonym
    Pseudonym Member
    Kicked it. That's what I did to my bike today.
  43. SLKid
    SLKid Active Member
    Added new RED LEDs to my bike. She looks sick nasty
  44. jarreddaughtry
    Smithfield, N.C.
    polishing,waxing, and more polishing. Oh yeah, and riding.
  45. Pseudonym
    Pseudonym Member
    Set it down.....WITH MY BOOT! stupid bike...
  46. Screamin_TE
    Screamin_TE New Member
    Newcastle, Australia
    removed vital engine components to diagnose the "not turning over at all" issue.........found it too.
  47. Pseudonym
    Pseudonym Member
    what was it?
  48. Pacocase
    Pacocase Member
    MD
    Oh let's see... I fixed the ignition and removed the left engine cover so I could see if it will start. It did. Now that I know I'm not wasting my time, it's off with the bars, destroyed headlight and bracket, and gauges. I painted up a boneyard engine cover from a 650 Maxim to make it look like it belongs on a Seca. I'll post pics soon. Maybe I should start a thread.
    Anybody have an extra 650 Seca tank or can recommend a reputable place in the greater DC area where I could get mine repaired?
  49. tennsouthernbelle
    Morristown, TN
    I told you it would start, it was running just fine when I ran it into the bushes :p
    This sucks... perfect riding weather and no bike..
  50. Mad_Bohemian
    Mad_Bohemian Active Member
    Ravenna MI
    Got the engine painted....after my little week long detour called 'broken intake studs! 8O
    Now all I need is to order the gaskets from Chacal to put her together and back in the bike :)
    Here's what it looked like for the silver paint ...creative masking :D
    Then I made a cardboard shield that went around the jugs at the base to paint the top half black...
    the end result...
