  1. pvtschultz
    pvtschultz Member
    Milwaukee, WI Area
    ^^^NICE^^^
    I replaced my fork seals last night. About 3 hours total time (had to make a hardware store run) total and wow. Thank you Chacal for the service. It is amazing how nice a bike rides when the forks actually have oil in them!
  2. SLKid
    SLKid Active Member
    Troy, Va (Charlottesville)
    Cant wait to get my forks done.... After I figure out !WTF! is wrong with her and why she wont start!!
    Oh, I chucked my helmet at my bike today.. at about 3:30am.. Need a new helmet..
    -Chris
  3. Pseudonym
    Pseudonym Member
    Took it for a spin! I love her when she's running :D
  4. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    Yesterday made a 240 Km run up the the lake. I hit reserve at 209 kms and filled it with 10 liters. Works out to 58 Imperial MPG. Best I can ever recall getting! Maybe all the carb work was worth it after all.
    Today changed oil and painted the exhaust pipe. New exhaust seals to go on with the pipe.
  5. PugUgly
    PugUgly New Member
    The City With No Pity
    Mad Bohemian, I love the look of that engine! What sort of paint did you use? I was thinking of using barbeque paint.. ?
    I replaced my spark plugs last night and got my headlight sorted out (except that it's pretty dim and needs replaced).. Going to be bondoing the tank and painting the bike soon.
  6. ZaGhost
    ZaGhost Member
    Dartmouth, Nova Scotia
    hehe, newenough.com has some clearance EXO 400 and 700s...
  7. jester_ns
    jester_ns New Member
    Nova Scotia, Canada
    >Ordered a front wheel from E-bay, swapped the rotors and tire and put it on the 85' 750 Maxim X. Much better. Also cleaned the brake calipers and drained the brake fluid, refilled and bled them. All good, but want to get the braided steel lines sometime soon, not as squishy a feel to the brake lever with them. (got some on my 86' 750 Maxim X). Cleaned and repacked the bearings etc. It's a smooth ride now. Took it for a spin, that's another story that I'm posting in the form of a question in the forums.
  8. mestnii
    mestnii Member
    San Francisco, CA
    Rode it!
    And changed the spark plug caps as the ones that were on their were from 85, and were out of spec for resistance.
  9. markie
    markie Member
    Suffolk, England
    Found pantyhose where the airfilter should be! Checked filter screen above petrol tap. Found that the "New battery" fitted by the previous owner only gives a few cranks before dying - well it does come from China!!!
    Rode it "Just to make sure it was ok" - that's what I tell the wife!
  10. fatman123
    fatman123 Member
    Winnipeg MB Canada
    stared at it and wondered how to get front shocks. havent even been able to ride it yet.
  11. chazmati
    chazmati Member
    Neenah, WI
    Finally got all my Maxim X valves into spec and put the cover back on with new gasket and bolt washers. Cleaned 3/4 carbs, hopefully finish the last one tonight.
    Next up, bench sync carbs, petcock rebuild and Dyna coil upgrade.
  12. Ternk
    Ternk Member
    Albuquerque, NM
    Oh that sounds depressing. In time, man, you will be having fun on it.
  13. RickCoMatic
    Routine:
    Oil and Filter.
    $27.00 in supplies.
    Funny how a Bike always seems to run better after the Oil Change.
  14. Ternk
    Ternk Member
    Albuquerque, NM
    Sounds like what I have to do to my bike: check valves, vacuum sync carbs, petcock rebuild.
  15. rhys
    rhys Member
    Columbia, MO
    Pulled the plugs from the 650 for the first time, even though I've had her for 2+ years now (yeah, yeah, I know). Found several things.
    Most interesting was the fact that I have everything. #1 was chocolate. #2 was sooty. #3 was white with a chocolate smear. #4 was really really white. This also explains the way the engine tends to race once warm, I think (lean 3 and 4).
    Those plugs were a $#^*!& to get out. If I had waited much longer, they might have corroded themselves permanently to the head. As it was, I damaged the wire-end (outside) electrodes getting them out, not that I cared.
    New plugs: $10 for all four. Mental note: Replace plugs annually.
    Since I had the plugs out, I ran a compression test. 130-135 on all four cylinders. Builds up to max in about four revolutions. Looks like I've escaped a valve job for now.
    I'm working on the 750's carbs at the moment, so I'm thinking I should just adjust the 650's carbs in place (sync and mix). The anti-tamper caps are gone on the 650, so I have access to everything, and I have a four-barrel manometer (mercury and everything. No idea how to use it, but I have one! ;)
    More coming soon...
  16. Wyldman
    Wyldman Member
    Hmmmm well let's see. Adjusted setting on both front shocks. PO had one set on 1 and one set on 4. :^( Set 'em both on 4 cause I'm a big guy. :)
    Checked air pressure on front shocks. Supposed to be 5.7, PO had put 10psi.
    Pulled springs on automatic cam tensioner. Inner spring had been compressed and stayed that way. Stretched it back out and most of the annoying chain clatter is gone. Only hear it now when I'm going too slow for the gear I'm in.
    Fixed small grip problem. Duct tape does wonders and blends right in with the theme of the bike. :)
    Found bare wire and loose cable connections which were causing the intermittent "Warning" for the battery. Can't believe that the bare wire was over an 1" long! Surprised it didn't cause more problems. All good now.
    ReDyed the seat, it was starting to show some wear. It's proper black again now. :)
    Looked for 'nekkid pics of Mila Kunis and Laura Prepon an errrrrr oops My Bad wrong forum. :)
  17. rhys
    rhys Member
    Columbia, MO
    Got the bike all nice and warm and rode about 30 miles. Would have gone further, but Car Talk starts at 11:00. ;)
    Noticed that as the bike warmed up, I had almost zero engine braking. Not good. Front disc is definitely warped as well. One thing at a time.
    Did a plug chop as I pulled in and looked at the plugs. Rich, lean, rich, lean. Since I had the plugs off, I went ahead and ran a compression test. Bad news. Only 120-122psi in any cylinder. Ran the test with the TCI still plugged in, but managed not to fry it. (I have a spare, but still...)
    So it looks like there's a valve job in my future. Never done one, but I do know my valve cover gasket leaks, so at least it'll be a chance to fix that...
  18. SQLGuy
    SQLGuy Well-Known Member
    Well, not today, but over the weekend...
    Took it up to Woodland Park (about 8800 feet elevation) for a dyno session. Tuned WOT and some of the off-idle and ca 3.5K RPM areas. Much better ridability now, cold or warm, for puttering around and starting off from a stop.
    Also tweaked the idle stabilization settings, which seemed to help keep things right when sitting at idle for a long period of time.
    About the only thing left to do is check into the charging circuit a bit... seems not to be putting out as much at low RPMs as it used to.
  19. 650boy
    650boy Member
    AB, City Of Champions
    rode it to work for the first time :)
  20. SecaCowboy
    SecaCowboy New Member
    Haltom City, Texas
    Rode her to the court house and tranfered the title to my name and got current tags, then off to Mi Hacienda for lunch and then it's time to rider her to work.
    SC
  21. Scholz
    Scholz Member
    Canada
    Just for the fun of it I pulled the valve cover off and helicoiled the one stripped bolt and replaced all the rubber of the pinch donuts and pu a new valve gasket on......
  22. Ahks
    Ahks New Member
    Detroit Suburbia
    sandblasted the footrest brackets and my upper and lower triples.
    time to hurry up and sand down the side covers and tank for paint
  23. ZaGhost
    ZaGhost Member
    Ordered my new steering head bearings and fork seals....
    Today, plan to find a good mounting point for my new horn ..
    A couple of weeks back add in some soft saddle bags and made a tank bag from half of a $10 ATV tank bag and some old magnets from some scrapped hard drives :)
  24. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    I think I just bought a wet nitros kit this morning. I'll have to see if everything is there thats supposed to be but you know how that goes. $200.00 USD Full fogger kit for four carb engine. 8O I might have to put this on before winter. :) Lets see those 600 rockets run away from me now. :lol: only thing is I'll have some major rejetting to do again and it looks like I'll be enginering a timing retard box.
  25. ZaGhost
    ZaGhost Member
    So far today...
    Replaced the steering head bearngs with tapered one... was easier than I thought... biggest pain is getting everything removed so you can get at the trees
    so far so good...
    Fork seals are next, just finished lunch, and now going to view a used set of forks that may have unpitted tubes... here's hoping......
    Noticed the front brake pads are getting worn, will need replacing for next season, enough wear left to finsh out the year fine
  26. helmet
    helmet Member
    On 2 wheels... just lost my hat.
    just replaced my speedo gear!
    I started driving around after I put it on and it seemed like it was fast, but I pulled out my gps on my phone and compared speeds. it was dead on
  27. yamahamaxim85
    yamahamaxim85 Member
    england
    well hear in the uk, we have to have an m o t on our bikes, to make sure they are roadworthy, ive recentlly bought it in bits, but its now got a 4 into laser exhaust system and some k n n air filters and a new tyre, its now got a new mot,,,
  28. ZaGhost
    ZaGhost Member
    OK got the tubes were pitted, in some places a bit worse than mine, but the travel area is completely free... got them cleaned up and installed new seals and a 15W oil (over the 10 last time). Still need to reconnect the wiring and put my headlight back on, hopefully a good test run tomorrow.
    Guy i got the forks from also gave me a reflector to replace my broken one and a stock chain guard so I can replace my homebrew cookie sheet one :)
  29. fatman123
    fatman123 Member
    Winnipeg MB Canada
    the other day, replaced old head bearing with tappered new one. also new battery and new sparks.
  30. FastMaxim82
    FastMaxim82 Member
    Tarentum, north of pittsburgh, pa
    took the maxim for a short ride, trying to edge her over 40,000 on this motor just need 15 measly miles then i'll swap out to the other one. started wiring the fuse box into the triple all while yelling at two kids smoking a cigar answering the phone and eventually forgot what it was i had the seat off the triple for to start with. oh ya. . . the fuse box. ya back to doing that.
  31. helmet
    helmet Member
    Fast, that sounds like me when I am working on mine.
    throw in "looking for tools I had laid out for the job" and you have my day
    my kids always grab my tools to "work" on their bikes
  32. FastMaxim82
    FastMaxim82 Member
    all in all i spent november thru july doing chain and sprockets and fork seals and a tune up to my maxim. wife's view of time spent was 9 months. actual time working where something was accomplished, probably just around 3 to 4 hours, lol. it never ends i drive an 81 buick ride the 82 maxim and now a 77 xs 750. gotta fix one to get to work the next day. o well tho, the maxim's head gasket seems to have cured itself for now, this winter i'll swap motors which has 16,000 then it should be good for a while mechanically speaking any how.
  33. wgb308
    wgb308 New Member
    Virginia
    I wrapped up a month long carburetor rebuild project.
    I color-tuned today until I was Bunsen Blue in the face, but it was worth it. Tune-Sync-Tune-Sync…
    Everything tuned out smooth and responsive. :D
  34. bvpoot
    bvpoot New Member
    Rocky Mountains
    Took apart the factory fairing (1981 XJ750 Seca) so I could lose all screws and springs and other hardware way down into its nooks and crannys so I could replace the bulb in my headlight inside the fairing.
    I cleaned the real glass cover of the fairing cover for the headlight, got it all together except one broken trim screw. Tested the new lamp, all worked great, except I forgot to clean the front of the headlight inside the fairing. So now I have to look at the gook and grime through the clean glass of the fairing's headlight.
    Also successfully passed the state motorcycle driving test. Also started to clean the rusted and grubby chrome exhaust pipes -- great condition, just never cleaned or polished.
    Also applied "Back to Black" to black plastic surfaces of the bike and fairing. Looking better every day.
    Also tried to take a ride up Continental Divide in street clothes and half helmet, when it started to rain and spit. Ten miles up the mountain I tucked tail and retreated. Rain felt like BBs. To heck with it.
    Then wifey said I was spending too much time in the garage so I had to come in.
    All in all, a good day...
  35. Cooter
    Cooter Member
    Chi-Caw-Go
    Darn near rode the wheels off the thing.
    Pulled the windscreen off and sourced some capscrews to remount the handlebars on Friday.
  36. pirok
    pirok Member
    Aarhus, Denmark
    Well, today it has 50 km on the clock (+ 100000 km) so i changed the engine oil and cleaned it up so it was clean and shiny. Listen to the sound from the engine and it still was the nicest rock and roll. Noticed that i have to change tires at the end of the season. Think i will go for a ride today the weather is nice and sunny.
    No more thinking I'll go NOW ...
  37. chazmati
    chazmati Member
    Neenah, WI
    Finished a sync with my new 2-bottle sync tool. Bought the X in June and have now completed valve shims, carb cleaning, Dyna-coil conversion, Colortune and sync. But it was raining today... tomorrow we ride.
  38. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Took my first highway ride. I think I'll wait a little longer before doing it again. :)
  39. lopezfr2
    lopezfr2 Member
    Point Loma, San Diego, CA
    well i WAS going to swap out the handlebars with the ones i ordered today, but the fracking post office lost the box so now i'll probably have to end up buying another one since it wasnt insured by the guy who sent it.
  40. eman1974
    eman1974 Member
    Halifax, NS, Canada
    Dropped it for the first time. Broke the right hand mirror clean off!
  41. ride-on
    ride-on New Member
    Brazil, In.
    Just finished changing out the speedo and tach unit, hope it works. Still trying to figure out how to fabricate or modify my KG luggage rack to fit on my xj 1100 with out making it look like I did the work??? It still is raining in Indiana, so back to the drawing board. Ride-On
  42. pirok
    pirok Member
    Aarhus, Denmark
    The season is at it's end. I've rode 7000km this summer! I thought if I were realy good I would ride 4000 km - so maybe I like to ride on that thing. Cleaned it and changed the oil when I got back from a ride this beautiful sunny sunday in October, but it was a bit cold though.
  43. yardape
    yardape New Member
    utah
    climbed on and rode it in to work, looked like rain but the bike gets better mileage so to heck with it
  44. ride-on
    ride-on New Member
    Brazil, In.
    Well the wife and I decided to go for a ride without the windshield and with half helmets. Back to the house to install the windshield, with the half helmets the wind like to lifted my head off. Had to install the windshield after putting on the new (old) gauges, speedo works but now the tach doesn't, well maybe bad connection or have to us the old tach. Windshield installed and it starts to rain, I guess we was not supposed to ride. Can the old tach be swapped into the other cluster without alot of detail?? Ride-ON
  45. maximike
    maximike Member
    Portland, OR, USA
    Put it back together after cleaning and lubing speedo (again). While I was at it, I did the battery warning bypass, running the wire that used to go into the battery cell(it ended in a cut wire under the seat, I found out) to the tail light wire, with 2k Ohms of resistor. That got rid of the "batt" warning. My red flashing light had never worked, I assumed it had been disabled, I was gonna fix that too, but turned out bulb was just loose. So now, no warnings on computer, warning light works, like if the stand is down, or whatever, and hopefully speedo won't start making that noise again. Also would be nice if it were accurate, but I'm not holding my breath.
  46. Chunga836
    Chunga836 New Member
    MA, U.S.
    Yesterday:
    -New Friction Plates in the Clutch
    -New springs as well
    Today:
    -Fixed electrical issues with a quick clean down of connectors
    -Plan on freezing my butt off in the 33 degree weather for a ride.
    -Make a list on what I need to do to get my baby shining (Now that it works, it has to look good)
  47. ZaGhost
    ZaGhost Member
    Woohoo, thread is alive again....
    Nothing ,much lately, carbs cleaned, and carb hats painted with faux chrome
    Look pretty good....
  48. KrS14
    KrS14 Active Member
    St Marys, Ontario
    Took the TCI off and re-soldered all points in it. Just to be sure the 26 year old solder wasn't bad lol
  49. dfknoll
    dfknoll Member
    Frankenmuth, Michigan
    Well i didnt do this today but i havent had time in the past to weeks to talk about it because of college.
    -New headlight
    -New blade type fusebox
    -Rewired connections to fusebox
    -Cleaned every electrical connection of corrosion i could easily reach and put on a healthy coating of die electric grease and electrical tape
  50. huckersteve
    huckersteve Member
    Seattle, WA
    Handlebar Swap!! Pics up in XJ Mods..
