1. Dec 26, 2024: XJBikes.com server migration work has been is completed. Thank you for your patience. SnoSheriff
  1. k-moe
    I’m late posting by almost two hours, but I loaded onto a trailer.
    Drove 900 miles today
    Scurvy, chris123, Franz and 1 other person like this.
  3. Minimutly
    Minimutly Well-Known Member
    West Wales, uk
    You ralise that bike will be making a strange bodoom boodoomp noise don't you?
    I do. Though it's not the potato-potato sound of that one brand.
    It's a bike that I refurbished 10 years ago for a friend, and it's coming back to me as a gift.
  5. Minimutly
    West Wales, uk
    Talking of unusual sounding bikes, I’m tempted to look into making a Big Bang xj engine, imagine Yamahas 4 cylinder sounding like a rasping parallel twin, with 12,000 rpm available..
  6. Simmy
    custom camshaft?
  7. Minimutly
    West Wales, uk
    Indeed, maybe a cut and shut, if indeed they are forgings. If they’re chilled cast then no chance. Would also need to be a 900 head I think.
  8. Roast644
    Roast644 Well-Known Member
    WASHINGTON
    Took a long, lazy ride this morning and rebuilt the forks when I got home. They needed it pretty desperately, with hardly any oil left in either.
  9. Minimutly
    West Wales, uk
    It’s odd how after a while riding you get to “tune in” to little (or not so little) things that need doing - I got my front brake performing really well, then thought I felt a little “skewering” from the front end under braking. Decided to rebuild the forks - well the seals were knacked but there was oil in there, however, one of the mudguard mount bolts had been sheared off. Given this is a fork brace I wouldn’t be surprised if this was what I was feeling.
    k-moe and Roast644 like this.
  10. nablats
    nablats Member
    whitby
    1981 xj650 4KO (uk) full rebuild. Finished valve clearance check, fired her up, didn`t sound too awful, but not quite right. Plugs examined, 1,2, look ok, 4 was a bit sooty, 3 was wet. I tested the coils on the bench before reassembly, and they checked out ok. Spark does look weak on 3, but 1,2 and 4 plugs also similar, no fat blue sparks evident at all. I am prepared to accept the 42 year old coils/leads are goosed, are there any other suggestions please?
  11. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Make sure the caps are screwed into the wires good. You might try nipping off 1/8 - 1/4 in. and screw the caps back on.
    Timbox and nablats like this.
  12. Franz
    You can fit Honda CB750 coils if you want to change them. There is a thread on the forum @Jetfixer did.
    k-moe, Timbox, chris123 and 2 others like this.
  13. Minimutly
    West Wales, uk
    No fat blue sparks ever came out of the Yamaha coils - that’s just how they are.
    k-moe, Jetfixer, Franz and 1 other person like this.
  14. nablats
    nablats Member
    whitby
    Thanks guys, we`re getting there!
  15. Roast644
    WASHINGTON
    Good little ride up to Mt St Helen's today. This is the east side at the Windy Ridge viewpoint. The final 16 miles up the hill are a bike dream...great road, incredible scenery, fun twists. If you're around SW Washington, definitely put it on your list.
    It was an eclectic trio of bikes on the trip with a Road Glide, a Tiger and my old XJ. The bike did great today, other than my tach quit working...Hopefully just a parted cable.
    212 miles total trip. Good time.
  16. Roast644
    WASHINGTON
    A while back I wondered why all my main wiring connections hung below the headlight bucket, but figured out shortly after that I had an aftermarket bucket without enough room inside. I found an original bucket in good shape and swapped that in today. Nice to have the wiring contained, although I really preferred the bulb retaining method on the aftermarket unit which was a simple twist lock on the trim ring.
  17. Wildabeast
    Wildabeast New Member
    Texas
    Finally got my carbs exploded open for a full rebuild. Without an ultrasonic this is gonna be a chore… 85E86AEF-30FE-45CB-B810-122226DA75F3.jpeg
    Andrew Nichols, chris123 and Jetfixer like this.
  18. Jetfixer
    Get a one gallon container of Berrymans carb cleaner from Autozone it has a small bucket inside dip each carb body in it for about an hour, take it out wash carb body in some hot dish soap Dawn is what I use , and let it dry blowing with an air compressor helps to .
    chris123 and Franz like this.
  19. Jetfixer
    Bummed it has been monsoon season here , today was nice BUT I had to work and had to work late even though I work from home was not in my plans . Finished for the day , aired up my tires on my truck and decided better check tires on bike they were low on the rear tire aired up and went for a short ride ohh wanted to go for a longer ride . Every weekend I plan to go it has rained or I've had to do something else , fall is going to be here soon so riding season will be ending .
    Huntchuks and Roast644 like this.
  20. Roast644
    WASHINGTON
    Took a ride to a bike swap meet today. Didn't really know what to expect, and turned out to be pretty much old Harley, Indian, etc. Stuff that has just never struck my fancy. I'll take a Japanese bike anyday. But, it was a beautiful day for a ride.
    Jetfixer and ksigurdsen like this.
