  1. 750E-II_29Rbloke
    South Cheshire, UK
    Pulled carbs and inlet stubs in the rain (horrible English drizzle!) to re-jet to correct spec & double check clean (should be, ran ok apart from air leak due to no inlet stub gaskets and bad airbox positioning)
    Removed sticky throttle cable to find lovely sharp frayed bit
    Just about to get on with carbs after cup of tea & bite to eat... (indoors this time, cosy in the sitting room :D )
    EDIT-: carbs all shiny and rejetted/needled and even re piston-springed after enormous help from chacal ascertaining which springs were the right length for 32mm carbs, thanks for that 8)
    All go as soon as I wake tomorrow (weather permitting) to find out what she sounds like with enough fuel in the mixture!
  2. jmilliken
    jmilliken Well-Known Member
    Dillsburg, PA
    ugh... float heights.... i had popped the bowls off to do a quick spray out while i did some other stuff. Somehow they managed to get messed up...
  3. smileyseca
    smileyseca New Member
    Colorado
    Well, this week I: Finally got it through my thick skull that pods are not going to be worth it. (I know, I know "dont bring up pods again newb!") Going to pull down the old airbox and joints and order a new filter.
    Cleaned the carbs and man did they need it. Got them back together. Cleaned up the headers for high heat paint and wrapping.
    This weekend will be getting the carbs back on, airbox hooked up right, new filter in, headers on, valver cover back on, some paint here and there (headers and H pipe) and the tank on with all fuel lines hooked up.
    Warm weather is a great motivator!
  4. moellear
    moellear Member
    Lima, Ohio
    put the forks with new seals back on the 550, installed the front wheel, and then took off the rear wheel. the 550 will get new sprockets and a drive-chain installed hopefully this weekend.
  5. 750E-II_29Rbloke
    South Cheshire, UK
    Nothing to the actual bike, it rained all day :(
    did finish putting piston springs & enrichment rail back on carbs though, plus out of boredom completely stripped the spare set & stored the parts ready for if/when they get used or moved on...
  6. MidniteMax
    MidniteMax Member
    Liberty SC
    Took only about a 25 mile ride on the Midnight while my 3 year old was napping and my wife was home.
    Ride was too short, but the bike really ran well. The weather was perfect and I would have liked to have ridden for hours.
  7. Moonrman
    Moonrman New Member
    TEXAS HILLCOUNTRY
    Surfed this site all day to make sure the next wrenches on my bike are needed and done correct! Ha ha
  8. Orange-n-Black
    Memphis Area
    Painted my tank, fenders and side pieces red metal flake.
  9. 750E-II_29Rbloke
    South Cheshire, UK
    That's such a beautiful colour... Not that I'm biased or anything :wink:
  10. SimonRef
    SimonRef Member
    Hull East Yorkshire UK
    Bead blasted and painted swing arm and bevel box ,waiting for swing arm bearings and wheel bearings to arrive,plastic welded lugs on some side panels bought from EBay.Roll on spring.
  11. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Mounted a 750 engine into my 650 seca frame.
  12. hogfiddles
    I looked at some of mine for a minute, then went out for several hours on the Polaris.
    Dave F
  13. Foolber
    Foolber Member
    In an Igloo, on Jupiter¿
    Rofl, i kinda did the same thing, told myself yesterday that i was gonna work on it today but i woke up and its snowing, hard....
  14. quebecois59
    Began fixing the wide-boards-wide-cracks floor of an old barn to make it suitable for wrenching on my XJ (and my other Yamahas); will have to put a big tarp 10 feet from the floor to catch water dropping from the roof (snow is melting)
  15. 750E-II_29Rbloke
    South Cheshire, UK
    And may it keep melting till it's gone, and not come back till winter :)
    Played about with intake stubs trying to correct air leak on #1. Feel It's going to need pulling apart again though.
    Checked TCI wiring to try identify pinouts on an iffy 650 loom in the phillipines!
  16. jpacman
    jpacman Member
    East Central Vermont
    It sure felt like spring around here! 55 and sunny!
    Solved fuel and battery warning light issues with resistors and jumpers. Reassembled everything, threw on my jacket and helmet, and hit the street for a 25 mile ride. The float bowl adjustments fixed the high idle issue when the engine was warm. Thanks to all who post helpful know-how.
    Oh man, that felt good to ride!!!
  17. johnnyx
    johnnyx Member
    london ont
    Reassembled everything after paint job was ready-just need fresh gas and i am gone riding-alittle worried about rust in gas tank though-was fine before paint-but now has alittle rust.11 degrees here-i want to ride.
  18. mmcgee
    mmcgee Member
    This weekend i checked the stator brushes and discovered one is drastically short. This could very well be the cause of my bike stalling out uphill. Found a replacement stator unit on ebay. Hopefully it will arrive this week.
    I wrapped the headers and reinstalled the exhaust system. Looks good. Real good. I also lowered the shocks.
    I removed both fenders and scraped off the ridiculous racing stripes someone had added. I also ripped out a stupid glow light someone added under the rear fender.
    I've just about finished painting the side panels. The system I'm using is a cheap but works for now. Tomorrow I'll start painting the tank and fenders.
    I also checked the final drive oil. All seems well.
  19. johnnyx
    johnnyx Member
    london ont
    Got in a ride today-oooohhh tat felt good-bike is running like a charm and looks great with the new paint job-oh i wish i lived somewhere where its warm all year.
  20. Krafty
    Krafty Member
    Point Clark ON
    Warmed up the bike and was tempted to give it a ride but I need to do a couple more things to the front brakes and the 300 feet of sloppy dirt road between my garage and dry pavement kept it inside today.
  21. moellear
    moellear Member
    Lima, Ohio
    Calculated miles I rode on the XJ550 maxim from date of purchase through December 31st, 2012 last year: almost 3700 miles from approximately July through late November when the bike was road-worthy. (Yes I do keep of mileage everytime I fill gas tank I write down mileage and record on spreadsheet saved on my desktop.)
    Also today I assembled new drive chain with new 16T front sprocket and 47t rear sprocket. Mounted rear wheel with new drum shoes and made sure she shined up real good with Mothers polish. Busy day for me but love working out in the barn with such terrific weather. Can't wait to ride the thing when the weather stays cooperative. It didn't bother me that others were riding today; salty roads and weathers' gonna turn cold again anyhow...
  22. husky
    husky Member
    england
    i finished work tonight at 5,whent straight into garage,
    turned the wifes 700 maxim over, ie started her up,
    carried on cleaning my maxim 550 up, wont be a minter,as she had a hard life, and our weather is crap in the uk,
    so last 2 hours, i was sorting out the wireing,on my new toy, my maxim 550 hardtail chop
  23. mmcgee
    mmcgee Member
    Today I replaced the fasteners on the wrap on my pipes. It was utility wire, but that didn't look good. Now it's a solid metal band.
    Stripped the paint of the rear fender. I put a clear coat on the gas tank, but got impatient and screwed it up. So I re-sanded and primed it again along with the rear fender.
    Painting them black tomorrow.
  24. 750E-II_29Rbloke
    South Cheshire, UK
    Unfortunately nothing, as my sleep problems cropped up again & I ended up sleeping through Tuesday until about an hour ago (02.45am here)
    With any luck I'll still be up later in the morning now though, ready & raring to tear off the 1977 front tyre (!), polish the wheel up & fit the nice new rubber :lol:
  25. Foolber
    Foolber Member
    went and got some valve shims!!! with my super cool awesome local shop discount :p i got 6 of em for $25
  26. Mike82mxm
    Mike82mxm Member
    Ste,Annes,Manitoba,Canada
    The shop I work in and where the bike is sitting caught fire so I cant work on it right now wich sucks cause i have bunch of new parts here (at home) for it to go back together.AND SPRING IS COMING.could be 4 months before i get to it.I know you cant swear on here so use your imaginations.
  27. 750E-II_29Rbloke
    South Cheshire, UK
    damn, hope the bike wasn't too bad? :(
    Got spanky new front tyre and fitted, warmed bike up with a quick spin round the corner & grabbed the sync gauges & YICS tool.
    Looks like my bench sync (using the lesser practiced visual technique looking at a bright light shining through pistonless bodies) was pretty spot on 8) so much so that I didn't quite believe it & had to throw it all out to check the YICS was blocked properly! Thought she ran pretty smooth from the get go, that'd be why... :lol:
    Well happy now, well on the way to having a lovely bike all sorted for spring :D
  28. Mike82mxm
    Mike82mxm Member
    No the bike was on the far side in the shop didnt get hurt at all.Its just locked in a burnt shop that i cant get too :cry:
  29. 750E-II_29Rbloke
    South Cheshire, UK
    Small mercies, huh :)
    Frustrating though having parts to fit & no access. Do they know how the fire started? And how come 4 months, suspected arson or something? :cry: that's waaaay long....
  30. Mike82mxm
    Mike82mxm Member
    started with a spark from a welder found its way to a thinner barrel.The shop needs new roof and all the equipment there must have been an angel watching over the bike cause that's the only thing that didn't get hurt.It was me welding.Small shop everything is so close to everything else was bound to happen.The bike was sitting far side of the shop under a tarp waiting for a new neutral light switch.
  31. Mike82mxm
    Mike82mxm Member
    :cry: Nothing worse knowing you have a bike and all you can do is watch the snow melt and ya have soo much to do to it before you can ride :cry:
  32. 750E-II_29Rbloke
    South Cheshire, UK
    Feel for ya bud, not a nice position to be in that :(
    At least the bike is alright though, and possible you'll be able to get some work done sooner. I don't know if anyone in your area is a member here, if I was I'd be straight round to lend a hand cleaning up (easy to say when I'm on the other side of the world, but the forum's done so much for me it'd only be fair to pay it on if I could...)
  33. Mike82mxm
    Mike82mxm Member
    Thanks for the offer 750E-II_29Rbloke I sure wish there were more people like you and all the people on this site out there.The shop was insured and they are working on it right now>I know I will be riding this summer just have to wait a few days longer than I would like to but ya cant change the past just what happens in the future. :D :wink:
  34. lowlifexj
    lowlifexj Member
    Grand Haven,MI
    today i Ordered new intake boots, gaskets, and fuel cap gasket.(from Len of course!) i think five years of trying the latest fix; innertubes, RTV, ect.,ect. is enough messing around..Now i'm off to my local yami shop to get engine oil, and filter and fork oil. Tonight will include a full tooth brush cleaning and touching up any paint chips. i already "race prepped the carbs" full tear down and slide bore polish..when the weather breaks here in Michigan i want to be ready for the first time in ten years :lol:
  35. smileyseca
    Colorado
    rebuilt my master cylinder and replaced the glass. Hopefully everything works right and holds up. won't know until i get my new brake lines in and the new pistons for my calipers.
  36. k-moe
    I RODE it!!! :D
    Just a few comfort issues to settle....like getting the windscreen adjusted so there's no helmet buffeting.
  37. husky
    husky Member
    england
    rebuilt the front brake master cylinder,and calliper, and sorted my cush drive rubbers out on my maxim 550 chop, id love to find some forward pegs,as shes a very small bike,
  38. ElkHavenSeca
    ElkHavenSeca Active Member
    Sedro woolley wa
    I put on my new bell helmet and just rode it for 45 min after 3 months of working on it !!!
  39. ElkHavenSeca
    Sedro woolley wa
    Awesome lowlife
  40. Foolber
    Foolber Member
    Put my airbox in (it cracked as i thought it would, but not to bad) put the starter on and the boots in the box. Put the battery holder/box in. Cleaned the intake manifold mating surfaces. And finally put my horns back on! Then sat and wondered were these 4 bolts i found came off of and if i missed something, turns out they are for the backrest :) ....which i dont use lol
  41. ElkHavenSeca
    Sedro woolley wa
    Awesome foolber got to like extra fasteners
  42. Foolber
    Foolber Member
    put my intake manifolds on (used Yamabond 4 instead of the paper gaskets), and re-taped the wiring for my fuel tank sensor, and letting the rear gear oil drain. shes getting closer!!!!!!
  43. ElkHavenSeca
    Sedro woolley wa
    Sweet , all i did is ride my seca straight into a big hail cloud !!
  44. Foolber
    Foolber Member
    finished up my tank, new petcock and re-wrapped the wires and put new connectors on them also. just put fuel in and no leaks so far (fingers crossed) only wondering about the gasket for the fuel gauge thing simce i broke the original seal ya know :(
  45. ElkHavenSeca
    Sedro woolley wa
  46. meich75
    meich75 New Member
    NC
    I rolled them off the trailer and into the garage. Let the rebuilding begin!
  47. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Wednesday I took rear wheel/new tire to local shop for mount/balance. Came home and put it back on. Also bought a bottle of 10W fork oil to add to the bottle I had and drained/refilled my forks. Bled front brake.
    Gary
  48. Bighappy
    Bighappy Member
    Kingston, Ontario
    Installed new brake and clutch levers, oil and filter change. Working on the not starting issue.....
  49. 750E-II_29Rbloke
    South Cheshire, UK
    Hey bighappy, just posted in your other thread, have you primed the float bowls? If it was tipped over & the fuel went into the oil the float bowls could now be empty causing your no-start
  50. ElkHavenSeca
    Sedro woolley wa
    drove 600 miles to pick up a parts bike , got home and rode my seca around the hood for a few ...now i will rest
