  1. Bighappy
    Bighappy Member
    Kingston, Ontario
    Finally found and installed a new (to me) windscreen. Last one broke last fall when the bike blew over in a wind storm.
  2. peganit2
    peganit2 Member
    Davison Mi
    Sanded the DOT numbers and letters off my 81' 650 Maxim's taillight lense and reflectors and polished them.
    Nice but subtle detail.
  3. k-moe
    I rode the snot out of it. Pre-trip shakedown runs are fun :)
  4. wink1018
    wink1018 Active Member
    Muncy, Pennsylvania
    Valves are now in spec. Spare carb rack all tore apart and getting clean.
    More to come when parts arrive!
  5. RiceBiker
    RiceBiker Member
    San Leandro, CA
    Etched and coated inside of gas tank. Eastwood 3 part. Good shit!
    82 xj650 maxim
  6. k-moe
    Any properly sized round Molex extractor should remove those teminal pins.
  7. Andyam6
    Andyam6 Member
    UK, Beds
    Spent 3 hours polishing the scratches out of my headlight lens with cerium oxide..... joy
  8. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Well I finish up today. Spend the last 3 weeks taking care of some issues. First was my exhaust gaskets. Got new ones. Rode. Then my starter went out. Got a rebuild from chacal since mine was past rebuilding. First ride after that my front shocks went out no return after I hit a bump in the road. Rebuild. Second ride after that had a problem with my chain. No problem new chain and sprockets. Put it all back together and my rear brake arm and rear brake cam threads were all stripped. That's not good chacal again saved me. And while I was at it some new shoes. Took here out for a short ride and everything seems to be working pretty good.
    O ya lots and lots of cleaning and polishing.
    Still have lots to do but it's on the road again.
  9. BruceB
    BruceB Active Member
    Isle of 8 Flags, Florida
    voom...voom......vrrooomm.........voom....voom....
    haha old school rules.....
    voom....voom
  10. peganit2
    peganit2 Member
    Davison Mi
    Giving the color a last attempt before I farm it out. The tins in Sonic Blue.
    If I get the little air box side covers good, I'll give the rest a go. I put another coat of primer on, hope to be able to wet sand them with a degree of success tomorrow!
    ZERO acceptability so far in prime.
  11. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    Finally did carbtune and colortune on the carbs. Changing main fuel jet from 120 to 122 was the best thing I've done for the bike. I'm running 4 to 1 exhaust and was having to turn the air/fuel mixture needles way out to get a good setting. Now I don't have to do that!!!
  12. Dedbolt
    Dedbolt New Member
    Rio Rancho, NM
    Put in a fuse box from Chacal and fixed my blinkers yesterday. Now to start rebuilding the brakes. Have new SS lines, pads, rear caliper rebuild kit and a new front master cylinder. Waiting on the front caliper rebuild kits. Any tips on the brake rebuild?
  13. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Put new rear tire on, Dunlop D404.
    Remembered to write down milage! :)
    Regreased splines, shaft and rear brake pivot points. Reset rear brake pedal free play.
    Torqued axle bolt, but at 77 ft/lbs the castle didn't align with the cotter pin hole . ended up just over 80 ft/lbs. not a concern - right? :?
  14. peganit2
    peganit2 Member
    Davison Mi
    None at all. It has to be done.
  15. k-moe
    I finally stopped procrastinating and installed a Turbo Seca oil cooler on my Seca 750.
  16. k-moe
    Next time back the nut off instead of tightening it further. Stripped threads are no fun to fix.
  17. Stumplifter
    near Irma, WI
    Replaced broken clutch cable and also replaced choke cable (it's 33 years old as well).
    Plan on letting these settle/ stretch in before replacing the 33 year old throttle cable. Don't want too many variables to worry about; understandably the choke is only a concern during cold starting.
  18. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    I was busy working on my car all week, but today it started raining at 4am and hasn't let up since. So off to the shed I went to work on the bike! Nothing major today, just the front wheel bearings. The old ones were feeling a little knotchy, so I can't wait until the rain lets up to go for a ride!
    Oh yeah, the bike did strand me last week. A guy in a white Camry cut me off on the highway, so after braking and getting his attention, I went to downshift, only to hear and feel the POP! of the clutch cable breaking. A couple expletives later, I rolled the bike into a dry cleaner parking lot (10pm) and got my roommate to pick me up so I could grab my spare cable and a couple wrenches. So it came to pass that Smack swapped out a clutch cable in the dark in a sketchy part of town.
  19. quebecois59
    I broke my clutch cable in an attempt to lubricate it, the bike being in my shed. Better there than on the road.
    I finished rebuilding rebuiding my front forks last week and my MC yesterday. Calipers are the next step. It should be road worthy by the end of August...
  20. hogfiddles
    Psst..... Len has 'em now;). I know-- I sent him my original so that he could make reproductions, and he told me the other day that they are done:) ask him about them, and let him know I told you about them:). Btw, I sent you a different text message earlier today --- did you get it? If so, text back.... If not, pm me.
    Dave fox
  21. Polock
    did some Gun-Kote a spare set of carb bodies..........pictures when their out of the oven
  22. Fuller56
    Fuller56 Well-Known Member
    Finished the install of tapered steering head bearings. Funny how those little, tiny notches can feel so deep on the old, ball bearing races. All better now. Ride a bit, adjust again and be all ready for Jack Cole's Covered Bridge Vintage Ride in Walton, NY in a few weeks.
  23. BruceB
    hmmm...got on it, turned the key to on, hit the starter button, bike idling at 1100 rpm with no choke needed. Put on helmet and took her for about a hundred mile drive up and down the coastal A1A on the east side of Florida. Bike performed flawlessly and ran like a finely tuned machine. Stopped off in Flagler and the bike drew much attention. One guy asked if I owned the bike from new and I said no, only for about a year and a half. Felt good to see all the Rolex Riders slobber over an old XJ. He asked who do the restoration, and I told him the Wizards of XJBikes with the help of Chacal of XJ4Ever. He looked a bit confused, but I explained it to him.
    Advice? It is only cheap when the receiver ignores it. But then again, you can never help anyone who won't help themselves first.
    Time for the pool...and the beer....see ya guys
  24. tmrastatter
    tmrastatter Member
    East of Cleveland Ohio
    My fj600 is finally on the road, brand new tires too, so off I went for a hot lap around the township.
    TR
  25. PilotSmack
    Calgary, Canada
    Bike didn't wanna start today. Instant expletives. Didnt take long to determine she wasn't getting spark. Coils showed no resistance. Took them off the rack, both are basically cracked in half. Luckily, my neighbour works for an auto shop so I got a wicked deal on a couple Dynacoils.
    Waiting (im)patiently for them to arrive, I replaced the rear wheel bearings, swapped sprockets, new chain, mounted my new BT45. The weather is beautiful, and my anguish is immeasurable.
  26. engraverwilliam
    engraverwilliam Member
    Baldwin Hills, South Los Angeles
    New Grips.
  27. sanglasmick
    sanglasmick Member
    Wexford, Ireland
    Rode it.
    Enjoyed it.
    Looked at it.
    Rode it again.
    Enjoyed it again.
  28. hogfiddles
    Pilot, Did you check the fuses, and did you check your battery?
    Dave F
  29. dmccoach
    dmccoach Member
    NE PA
    I had to repaint my bike... (not due to a dump or crash)... The paint shop suggested and I agreed to a color from the "Jaguar collection" and it is called a Pearl Yellow - pic of a Jag in the color chosen also seen below... I know "yellow" is an unusual (if never used) color for these bikes, but I very much like the result:
    (No badges yet - can't decide yet)
  30. engraverwilliam
    Wow DM that is nice.
    I've been considering going laser Blue.
    But for it to look right, I think the fenders would need to be painted as well and I don't thing I am ready to do that yet.
  31. dmccoach
    dmccoach Member
    NE PA
  32. big_rob420
    big_rob420 Member
    cameron, NC
    i kicked it in the ass and told it to work... didn't listen as usual
  33. ingie1062005
    ingie1062005 New Member
    Armstrong B.C. Canada
    Actually I did this a few days ago , I've just been too upset to talk about it.
    My Clutch basket exploded the other day. I would attach a pic but I can't seem to get that working right now.
    Gotta run!
    Catch up later!
  34. peganit2
    peganit2 Member
    Davison Mi
    I wet sanded the rear wheel inner drive cover in prep for a better coat of paint. I was gonna let the slightly more rough surface slide on something no one else will EVER get that close to but....
  35. PilotSmack
    Calgary, Canada
    Yeah Dave, the fuses were the first thing I thought. I upgraded them all to the blade type over the winter, and they were all fine. Battery was next on my list, but it showed 12.8V, so I figured that wasn't it. No kinks in the fuel lines, but I smelled gas. Pulled a plug, held it to the block, nothing. Pulled the rest, nothing. Figured it was either my TCI or the coils. Tested the coils with a multimeter, both their primary and secondary resistances were waaay out. Pulled them off the bike and saw massive fissures running up both cases.
  36. Expat_Brit
    Expat_Brit New Member
    Mansfield, MA
    Posted here and then went to ride my Kawasaki :)
  37. tinnian
    tinnian New Member
    Converse, TX
    Ran a couple of gallons of exhaust fluid through her, then did the same with my ZRX.
  38. Fongdingo
    Fongdingo Member
    Charlottesville VA
    Ran my fully broken apart carbs threw a bath of parts cleaner, then boil then back in cleaner then a good scrub and rinse. Now to put them back together.
  39. Studeman
    Studeman Member
    Winston Salem, NC
    Over the last 2 months I have rebuilt, stripped and painted my saddlebags. They had been off the bike for about 2-years. I pulled my hair out for the last 2 weeks trying to find the mounting hardware I removed. Came across them yesterday while looking for something completely different (my glass-polishing kit). Got them assembled and mounted to the bike.
    Ray
  40. Rsk_141
    Rsk_141 Member
    Scotland
    Cleaned up Cam Cover / Painted It!
    Not sure how to post pics so placed photo in gallery!
  41. wink1018
    Muncy, Pennsylvania
    In the middle of rebuilding carb set #3. Nothing better than having spare racks of carbs.... Just in case
  42. PilotSmack
    Calgary, Canada
    Put the dynas on last week, but it's been too hot to resync/colortune lately. I was up early this morning, went for a 85k ride, came home, synced and tuned, just before the rain clouds rolled in.
    Aaand now, breakfast :)
  43. peganit2
    peganit2 Member
    Davison Mi
    Decided to chince on my factory master cylinder and attempt to repair it. It all depends on the bore.
    We'll see. Started the soak in Berrymans.
  44. Ground-Hugger
    Synced the carbs on my Venture also replaced the coils with HONDA coil over plug (COP) coils from a 07 Honda CBR 1000!! Runs fantastic!!
  45. jpacman
    jpacman Member
    East Central Vermont
    Tube handlebars and risers; custom seat foam and new cover (by me); stock mirrors; new front brake master cylinder (to fit new bars), front light bar and low-wattage lights; removed heavy license plate holder and replaced with aluminum square stock; fabricated longer rear turn signal brackets so my soft luggage wouldn't hang on rear signals; painted tank, side covers and grab rail Mazda blue (almost the color of the website header); new clutch and throttle cables; Bridgestone Battlax BT-45 front and rear (sport touring tire that, astonishingly, comes in our sizes); new Barnett clutch.
    By removing and replacing parts, I've saved over 15 lbs. and plan on putting more parts on a "diet". She ain't stock no more!
  46. PilotSmack
    Calgary, Canada
    I'm loving the BT-45s. Hope you do too!!
    Threw the saddlebags and windshield on. Road trippin for the weekend. Leaving early tomorrow. All fluids checked, chain lubed, battery tendered. Wish me luck!
  47. RiceBiker
    RiceBiker Member
    San Leandro, CA
    new exhaust gaskets, drilled out my old pilot jets from #40 (.4mm) to now #45 (.45)mm and will add another vinyl washer to main jet needles. Running lean up to 1/2 throttle. Still no battery charge. New brushes on stator. Gonna try flow chart now.
    82 650 maxim
  48. PilotSmack
    Calgary, Canada
    Yup, that happened. Was on a 600k trip, at 590 I heard a weird noise, but it was familiar because one of my exhaust flanges was loose last week. So I kept riding anyway, figuring I'd just tighten it up when I got to my destination. I know, I know, big mistake, lesson learned. Luckily, there was a wrecker a few hours away who had the missing parts from an 81, He put them on the bus that night, and I had parts first thing in the morning. Big, big, big standing ovation to New Life Cycles in Williams Lake, for those in western Canada.
  49. peganit2
    peganit2 Member
    Davison Mi
    Not sure I'm believing what I understand :!: :!:
  50. Tcorbitt0608
    Tcorbitt0608 Member
    Guyton, Ga
    got on it and rode it to work, you wouldn't believe how hard it is to turn that thing into my work parking lot.... it just wants to keep going lol
