  1. k-moe
    I went to get milk. It's weird how far away the grocery store is when I ride the Seca. A 15 minute trip took almost two hours.
  2. Xjrider92117
    Xjrider92117 Active Member
    San Jose Ca
    Forgot to put the battery on a charger when I went on vacation for 9 days. Got home today tried to start the bike. It started the second I hit the start button.
  3. hogfiddles
    Put a new rear tire on the 700, and got inspected.
  4. MarkV
    MarkV Member
    Vermont
    Reinstalled carb rack on latest project, 1981 SECA 750.
  5. ronmold
    ronmold New Member
    Minnesota metro
    All cleaned up for the new head gasket
  6. Takencareofbusiness
    Takencareofbusiness Member
    North Vancouver BC
    Installed the used stock exhaust system i bought a couple of weeks ago, got rid of the old worn out 4-1 system.
    What a difference in sound-sweet
    Rebuilt the petcock -thank you BigFitz with the forum posting.
    Included in that rebuild was that little plastic disc in the vacuum port.
    Now runs on RUN, and not PRI, and installed a new inline fuel filter.
    All parts ordered and delivered wickedly fast from Chacal.
    No other place to get parts
    Don't waste your time. Order from Len.
  7. jpacman
    jpacman Member
    East Central Vermont
    I added some LED lights to the rear. Blue that are just above the plate (always on) and two red below the plate that are wired to the brake light. Much more visible at night.
    Also fabbed up a light bar for the front and wired 2 larger LEDs to the accessory light switch. Almost don't use the high beam now. Rewired the accessory light to come on with the high beam.
    Put on a set of Bridgestone Battlax BT45 dual-compound tires before setting off for Canada on a 2000 mile camping trip. Great handling and good in the rain. Good center wear, too.
  8. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Absolutely nothing......enjoyed looking at it.....running perfect......lol
    Tyler Rubino and Johnius like this.
  9. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Rode in the rain.
    Realized that I no longer have apprehension about rain.
    Proper gear, awareness of different conditions and adjustment of driving tactics.
    On a related note- RainX is great . . . for rain, not so much for road spray.
  10. Johnius
    Johnius Member
    Detroit
    I rode it for the first time this year. Let's hear it for above freezing temps in Michigan! Filled the tires, checked the pre-load, replaced the battery. Next is getting the carburetors cleaned... where was that stickied post?
  11. jpacman
    jpacman Member
    Finished the conversion of my winter project 82 XJ750 into a "GS" dirt slinger. Rode it for the first time today around the farm road and sent rooster tails of mud into the melting snow banks. Amazing what a set of knobbies can do for traction! Custom rack made out of 3/4" steel square tube to carry ammo cans.
  12. Bigshankhank
    Bigshankhank Active Member
    Bastrop, TX
    Pics or it didn't happen!
  13. hogfiddles
    Absolutely nothing
  14. Joris
    Joris Member
    Eindhoven, NL
    I finally installed the new brake lines that I bought from Len last year.
    The existing lines were the originals from 10/80.
    First ride of the year. Temperture of 10 C.
  15. jpacman
    jpacman Member
    DSCN1099.JPG DSCN1101.JPG DSCN1103.JPG DSCN1109.JPG DSCN1110.JPG Oh ye of little faith! Three months of hard work and you won't take it on faith?!?
    Fine, here you go. It's not clean 'cause I was running it around the farm in the mud.
    Bear in mind that this started as a $300, non-running barn find. It was ugly to start with and neglected by POs.
    Stumplifter likes this.
  16. TheDuderino
    TheDuderino New Member
    Hope Mills, NC
    Checked out my local motorcycle graveyard and found a seca 650 gas tank and picked that up and some soft, sparkling and crack free set of carb boots for 75 bucks. The tank has light surface rust in a couple spots on the inside and 2 small fixable dents.
  17. DarinAdkins
    DarinAdkins Member
    Dallas,TX
    Hey Buddy mind telling which model is the motorcycle? coz I was actually looking to buy 1
  18. hogfiddles
    That's an xj750 Maxim
  19. bmarzka
    bmarzka Active Member
    Northwesten PA on Lake Erie
    Started up the Maxim for the first time this year. Just puttered around the yard. Now to check the valve clearance and get state inspection. Of course, that little sticker never stopped me from riding before.
  20. k-moe
    The two copper washers that I forgot to order came in the mail today, so I spent my time after dinner torquing the head nuts down properly. Cams go in tomorrow, with this year's riding to commence by the weekend. I might even make some time to write things up and post them. The frame repair came out great, and I needed a smaller peice of patch than I thought I would (sorry no pics were taken during the repair process as my time was short).
  21. FtUp
    FtUp Well-Known Member
    pacific northwest
    I dreamt about mine...
    I also got my new front brake pads for the 750. still waiting for other parts.
    FU
  22. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    ignored it... hoping snow will go away!
  23. hogfiddles
    Started the 700.....started right up. Gotta wait til snow is gone and roads are clean before I'm willing to go out for a spin.
  24. k-moe
    I did the final buttoning up of the engine after ensuring that oil was flowing to the head sufficiently. Then I put all the other stuff back on and fired her up! She's running almost as good as new; I just need to do a runing carb synch and she's good to go. (note to self: do not mistake the #1 synch screw for the #1 intake boot clamp screw).
    My wife said that everything would be sure to work perfectly since it's been thunderstorming all day.
  25. hogfiddles
    Oops! Lol
  26. chekers97
    chekers97 New Member
    Somerset
    Installed the two shims to bring the valve clearances into spec and fitted the frame to the engine. Started some of the re-assembly.
  27. k-moe
    I went for a very enjoyable 14 mile ride. No oil leaks, no ticking from the primary chain; it was absolutely worth the four months of downtime.
  28. hogfiddles
    Woke up the 700 today.... Started right up, but found a leaking.... maybe i should say running.....petcock. Good thing I have an extra fuel shutoff valve! Time to get a rebuild kit.
    Started the 900, too.... First touch, started right up
  29. Kennyhartman
    Kennyhartman Member
    northwest ohio
    Checked valve clearances for the second time since I bought it, ordering gaskets from chacal
  30. JaiFer
    JaiFer Member
    Northern Ontario
    TShirt weather today, Running sync, color tune, Vroom Vroom
  31. FtUp
    pacific northwest
    I finally got the parts I needed to finish up the front brake rebuild on my 750. then I fabbed up some front turn signal mounts, reinstalled the mufflers with their new rubber isolators. buttoned up a couple other loose ends and it's almost ready for the road.
    FU
  32. FtUp
    pacific northwest
    today I bled the front brakes and actually rode it up and down the street. then I swapped it out in the garage with the 550. now I can start tearing the front end off the 550 and start the radian wheel/front fork swap.
    FU
  33. k-moe
    Whoo HOO!!!!! Onward with the riding.
  34. NEEDtoRIDE
    NEEDtoRIDE Member
    Raleigh, NC
    Went on my first decently long trip of the year this past weekend! A little short of 800 miles from friday afternoon to sunday afternoon, with about 450 being western Virgina mountain twisties. If anyone is every around Tazewell,VA, do yourself a favor and hit the 33-mile Back of the Dragon, IMHO it is better than the Tail. Time for an oil change and back to the mountains in 22 days![​IMG]
  35. Stumplifter
    near Irma, WI
    Last Sunday, checked valve clearances, corrected #1 Intake, put carbs back on, went to roll bike out of garage - front brakes locked up. Pulled apart caliper, cleaned, reassembled. Pulled master cylinder, cleaned (that realllllyyyy tiny hole appeared to be plugged:eek: ) reassembled. Bled breaks, found that putting a real long clear tube on the bleeder and sucking on it works really good.
    Went for a quick ride . . . Think my funky hanging rpm thing is still around. Borrowing Morgan Carbtune to verify running synch.
  36. jpacman
    jpacman Member
    Sprung for my own Colortune plug and tuned the dirt project bike. Then balanced the carbs with a homemade rig using baby bottles and ATF. Worked great and runs very smoothly now. Starts with the touch of the starter button without hesitation and settles into a nice 1100 rpm idle when it's warm.
    Finally got the registration and plates from the DMV (after nearly 7 friggin' weeks!!!) and went for a ride before all the mud dried from the back roads of Central Vermont. Handles great in the slop. It's heavy but tracks the front wheel and is easy to keep moving in the muck (2nd gear and wind it up!). It's really dirty but I'm happy with the results.
  37. ChrisRomello
    ChrisRomello Member
    PSJ, Florida
    Adjusted the engine timing on my 650, swapped out a few shims to put in spec, reinstalled exhaust and carbs.
  38. XXWoodmanXX
    XXWoodmanXX Member
    Delaware, oh
    - Ordered TruGel batt.
    - Ordered Colortune 14mm set (umph!)
    - rebuilt/cleaned carbs thoroughly; idles/runs soooo much better
    - replaced aging coils with '97 Suzuki Katana coils; runs excellent!
  39. cutlass79500
    lawrenceville georgia
    Pulled the non dented no inside rust tank off my seca 750 along with the 4-1 best 100 bucks i ever spent on a parts bike
  40. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Valve shims and a compression test. 120 /120 / 130 / 130. Also ordered a Carbtune. The anxious waiting begins!
  41. k-moe
    Not so much to, as for...
    It didn't all get done today either. I have around 20 hours of labor and think-time into the project so far. I figure on another 10 to 15 until it is finished and road-ready. My one self-imposed constraint was to use scrap wherever I could. There's no sense in stockpiling it forever, and I need to make room for an old lathe.
    ecologito likes this.
  42. jpacman
    jpacman Member
    Installed a used, stock fleaBay exhaust system that the seller insisted came off an XJ750. HA!!! Should have known better.
    The headers were fine but the center collector mount bolt was 1/2" too far forward and the can mounts were 3/4" too far back. I removed the center mount hardware, left the rubber, and fitted a big washer on top, a new bolt from the bottom, and double nuts to lock it in place. Then I drilled new holes in the can mounts and threw in the stock bolts. Sounds nice and I swear it runs better.
  43. jpacman
    jpacman Member
    It's going to rain today so it's steering head bearing day. Yay!
    If all goes well, maybe I'll do both bikes......
  44. ecologito
    ecologito Well-Known Member
    NASCAR Country, NC
    Bought a can of carb cleaner and parts are getting dipped for a good cleaning on the 550 seca.
  45. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    Rode to work. After working I rode home...varoom, varoom!
    Gary H.
  46. k-moe
    I made the mistake of stopping at a dealership today. The Super Tenere' fits me pretty well, and they have a 2013 for $4000 off MSRP. Luckily I'm in Ohio or I'd have written a check already.
    So today was another for instead of a to.
    I bought a set of soft tiedown loops, and did not buy a new motorcycle.
  47. jpacman
    jpacman Member
    Great fortitude and control! I, too, loved the Super Tenere' and I rode one. Maybe when I'm done bashing the XJ through the New England woods......
    Did the steering head bearings in both XJs and took the dirt conversion out for a test ride. Holy crap! What a difference! No shake at any speed. Look, ma, no hands! Tightened it a bit after a good 200 mile slog in the mountains.
  48. Toomanybikes
    Tsawwassen bc
    Walked past the fleet on way to big invitational ball tournament .... Ok maybe next weekend ...sigh
    But we are in finals tomorrow beer garden, ladies with short shorts and oh yea did I mention BEER !
    And more BEER
    And if we win we get a cheesy trophy and we win BEER
    Ps the waiting list to get into the tournament is about 5 years
  49. MattiThundrrr
    "My drinking team has a baseball problem."
    Luis likes this.
  50. Toomanybikes
    Tsawwassen bc
    Yes we do to but it's not really about ball it more seeing old friends and having a good time
    A bunch just went home we play early tomorrow ( it's a holiday weekend) we have played 4 games already and we hurting minimum 2 games possibly 5 if we go all the way!!
    But our team does party year round
    How does that new song go ....
    It's all about the beer bout the beer bout the beer!
