  1. Dadoseven
    Dadoseven Active Member
    Omaha
    Rebuilt / reinstalled the Master Cylinder. Man that MC is a b!-(h to get at! Especially with the fairing mounting hardware in the way.
    Replaced all of the brake lines (still originals) with SS braided.
  2. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    I am gonna have to upgrade myself to the SS braded lines as well.
    I was just messing around with a 6inch polishing wheel on my bench grinder with the exhaust-very nice
    Glanced over and seen my horns and gave them a quick cleaning- That's when I noticed that one of the mounting brackets is broke and 1/2 of it is missing :(
    Gonna be hard to find a replacement being as its an XJX doesn't even look close to the others that I have seen
    when in doubt reach out to chacal
    :D
  3. The Bingles
    The Bingles New Member
    Ipswich
    Removing shock absorbers and replacing with twin tubes.
  4. Dadoseven
    Omaha
    Today I got the brakes bled from my MC / new brake lines installation yesterday
  5. Dadoseven
    Omaha
    After successfully bleeding, my calipers stick. They are easy enough to get free by loosening the caliper bolts or tapping lightly on the outside of each caliper, and I imagine pushing the caliper piston back in a bit. Looks like a caliper rebuild is in the works; which was already on my list.
  6. k-moe
    After months of waiting, and waiting, and being sick, and more sick, and waiting, and waiting..........
    I put a new headlight bulb in.
    I also started it up, brought the engine to temp, and did the safety checks so I can go riding later in the week.
  7. dowski68
    Medford, Oregon
    Today I got a surprise in the mail-A new left hand horn assembly-or new to me at least. Being as I have never had a horn that worked, ok the horn worked one time and then the button or spring broke and hasn't worked since. Good as time as any to get a replacement. Probably should of gotten one years ago for safety reasons. Another lesson to be learned.
  8. Franz
    Stripping carburetors and sealing the exhaust system.
  9. k-moe
    I RODE today!!!!
    After SO many months of winter cold/illness/workload, and now RIDING!!!!!
    I don't think I've ever shared my post-winter wake-up routine.
    1. Unhook the battery tender.
    2. Set the petocock to prime.
    3. Turn the ignition switch to ON
    4.Open the enrichment plungers (choke)
    5. Press the start button.
    6. SMILE at the real vroom-vroom noises :)
    Bmgalena and TheCrazyGnat like this.
  10. dowski68
    Medford, Oregon
    Looks like everybody is getting things ready for the spring and summer time !:)
    Lightcs1776 likes this.
  11. Bmgalena
    Bmgalena Member
    Joplin
    Real vroom vroom noises are always better. The girlfriend thinks im crazy when i sit on the bike and make the noises with my mouth...
    rocs82650, Lightcs1776, Franz and 2 others like this.
  12. dowski68
    Medford, Oregon
    Got an e-mail yesterday stating that my valve shims are on there way. Hurray hopefully the wrist pins and rings will be here by Monday. Taking the week off from work. Also waxed the side covers of my bike earlier.
  13. TheCrazyGnat
    Central PA
    Installed the spin on oil filter kit, got a running sync done on the bike. It's not completely dialed in, but I just wanted to be able to get out and change the battery because that light came on while I was syncing. It started to rain, hopefully I can do the color tune and another sync tomorrow.
    smeagol21b likes this.
  14. Lightcs1776
    Lightcs1776 Active Member
    Upstate NY
    My wife thinks I am crazy whether I am making noises or not. Grin.
  15. Bmgalena
    Bmgalena Member
    Joplin
    Does the spin on oil filter kit make it easier to change. As of now i have to pull my 4into1 exaust to have enough room to change the filter
  16. XJ550H
    yes the spin on filter is smaller than the stock filter housing
  17. TheCrazyGnat
    Central PA
    Even with the stock exhaust I believe it is easier to change, if only by a little bit. My biggest draw was, honestly, the ease of finding filters and the potential extra filtering capacity.
  18. Lightcs1776
    Upstate NY
    Although it won't be anytime soon, can these be used with the oil cooler?
  19. k-moe
    Yes. The spin-on adapter plate sandwiches the oil cooler adaptor between itself and the engine case. You do still need the special union bolt for mounting the oil cooler adapter.
  20. k-moe
    And if you use a mini-filter there is more room yet.
    Bmgalena likes this.
  21. Bmgalena
    Bmgalena Member
    Joplin
    Well thats something that is happing next oil change
  22. Tim O
    Tim O Active Member
    Charlottesville, VA
    My bike thinks it's crazy when I sit on my wife and make vroom vroom noises :)
    Dadoseven and Bmgalena like this.
  23. Tim O
    Tim O Active Member
    Charlottesville, VA
    Oh... and today I went for an hour ride then started taking my exhaust apart for the new to me pipes I just got.
    Happy that the pipe ring lug nuts are coming right off easy...
    Dadoseven likes this.
  24. XJ550H
    started my note book and inspection to my new arrival today XJ 750K.
    did inventory needs correct handle bars no security chain and it has after market mirrors .
    disconnected solinoid connector (remove temptation to try to start)
    oil check ok level.
    added a&a to the cylinders. laughed at the decripid fuse box and its repair.
    ohmed out the ignition system cap found a 10K cap on one wire (5k normal)
    tested voltage at fuse and tci no tci voltage.
    pulled Right control cleaned lubed now have my 12 volts at tci.
    run switch was filthy, starter button was just as bad.
    When I first turned the key on head light came on right away. there is no head light relay in the 83 750 maxim. What yamaha did surprised me. 2 extra wires on the starter button. when button out lights on, press button light off for starting. that is a lot of current for that little contact plate.
    now to clean the left side control
    next up ignition key cleaning
    wire harness check and clean.
    then Into the motor for shim check and compression test
    Stumplifter and Dadoseven like this.
  25. dowski68
    Medford, Oregon
    got the shims for my bike or at least until I opened them up and realized that they sent me the shims for a shim over bucket style. What a freaking let down! Oh well par for the course I suppose.
  26. Timbox
    On the FJ1200, washed her up, warmed her up and ran her down the road. On the Xj700X, got it all back together and then found the coolant leak...still a good day.
  27. rocs82650
    rocs82650 Well-Known Member
    Middle Tennessee
    First ride! Felt good.
    Gary H.
    Stumplifter likes this.
  28. PilotSmack
    PilotSmack Active Member
    Calgary, Canada
    Parts showed up. Put the carbs together following church, installed the new ignition and diode kit, ran it. Seemed fine, it was pretty wet outside but hey, when you wanna ride, you wanna ride. Short little test run, everything seemed okay. Going to sync, colortune and sync again when the weather is a bit better.
  29. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Not par if you order from Len.
    cgutz and TheCrazyGnat like this.
  30. Franz
    Going to check the fuel levels today with the U tube principle before I put them back on the bike.
  31. Franz
    Be looking better when I get the forks and engine cases polished for summer. The picture below is how the bike looked before I started tidying her up. It is an ongoing process.
  32. Franz
  33. Franz
    I had to sort out the electrics, fitted a replacement wiring harness, painted frame, cleaned carburetors, sealed hole in exhaust under engine. Still have to fit the replacement neutral switch (than will be fun) check the valve clearances, new oil and filter, change fork oil and springs, and change the oil in the rear driveshaft housing. I also stripped the calipers and cleaned them, and bled front and back brakes.
  34. Andy555
    Andy555 Active Member
    Slovenia
    I first with alittel sweat make it that front dork of suzuki goes strait on on my xy and then i repainted that fork.tomorow is another day,hhehhehe
  35. hogfiddles
    I think I'm crazy when my bike sits on my wife and makes vroom vroom noises.....
  36. dowski68
    Medford, Oregon
    Indeed my friend, just pony up the funds and be done with it !
  37. Andy555
    Slovenia
    Hy i'd like to take out that lock for front fork.but i dont know how ,anybody can halp? DSC_0297.JPG
  38. Stumplifter
    near Irma, WI
    Dowski, you have been a member for more than 3 years, you should know better.
    Great customer service, endorsed by many members, intelligent, coupled with other members horror stories of wrong parts/returns headaches and delayed riding. Why wouldn't you order from XJ4Ever?
    Trust and believe I am an extremely frugal tight wad - some of the stuff does cost a little more, but that extra cost buys piece of mind. For me that is priceless, given the society we live in has lowered its standards so far that consumers are "ok" with shrugging their shoulders and saying: "Par for the course".
  39. dowski68
    Medford, Oregon
    Your are absolutely correct- Piece of mind is more important-I am going to contact Chacal here shortly to get what I need correctly the first time.
    Thanks for reminding it of what it used to be like back in the day before all this commercialization destroyed are core values! That is one thing that I try very hard to teach my grand children
    Do what you say, say what you mean
    Makes life a lot easier no BS and if there is it goes away rather quickly.
    As of right now the sun is taunting me, why you not riding Bro ?
    Cause I tried to save a buck and it bit me in the ASS!:eek:
  40. dowski68
    Medford, Oregon
    Ok all shims ordered-
    Also got a e-mail about my wrist pins and rings should be here by the 4th of April.
    Hopefully all parts will be here at the same time-ish.
    Looking forward to getting to use my carb sync contraption LOL
    followed by the color tune gizmo. o_O
  41. Bmgalena
    Bmgalena Member
    Joplin
    Today i finally got the brushes for my starter and..... Success!!! It works great!! Feel super proud, its the first time ive ever rebuilt a starter so thats a new skill o have:). Tomorrow put it on the bike and start it to see how shes running. Just to be sure the starter should spin counter clockwise looking from the back correct?
    MattiThundrrr, Stumplifter and k-moe like this.
  42. k-moe
    Correct.
  43. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    Motor is together, now will it start? Keep them fingers crossed. Seca Motor 4.jpeg Seca Motor4.jpeg Seca Motor3.jpeg Seca Motor 2.jpeg Seca motor.jpeg
  44. k-moe
    It will not start. The starter lead is missing, along with the gas tank. :p
  45. Crimson9mm
    Crimson9mm New Member
    Tonawanda ny
    found a mechanic whos personal ride is a 83 seca and does all the local harley dealers carb work.....best part hes going to do a full run through for free just because he wants to see another xj back on the road(and if it does need any parts in the carbs im going straight to chacal) also wondering where i should go for other parts? any tips appreciated.
    dowski68, hogfiddles and Stumplifter like this.
  46. dowski68
    Medford, Oregon
    Chacal has the most parts that I know of along with an intimate knowledge of the XJ series-He is your best bet may be a little higher but you et what you need the first time you order. I 've learned that lesson !
    Stumplifter and hogfiddles like this.
  47. hogfiddles
    Maybe we should start an "I told you so" forum
    k-moe, Crimson9mm and TheCrazyGnat like this.
  48. dowski68
    Medford, Oregon
    Indeed I AM sure that I am not the only one who would qualify.
    Crimson9mm likes this.
  49. Crimson9mm
    Tonawanda ny
    He actually said that's where he got his last kit from too. but hes not a "forum" kind of guy i guess.
  50. Stumplifter
    near Irma, WI
    I did the wrong thing once.
    Lost riding time and lost my patience. :oops:
