  1. Wintersdark
    Wintersdark Well-Known Member
    Calgary, Alberta, Canada
    Very productive day! Finished up with the headers and collector, got the headers wrapped, changed exhaust gaskets, reinstalled the headers and collector.
    Painted my muffers, as they're pretty banged up and have lots of rust spots, as well as repaired my side covers and grab rail. Painted stuff is still in the basement though as it's decided to rain.
    Replaced a blown rear shock with a good one, so the suspension should be a lot nicer now.
    Did a bit of a test to see how the XJ sounds without mufflers....
    Aaaaand.... Now I don't know if I'm putting those mufflers back on, or just slapping on some baffled straight pipes. I love how that sounds and it's way quieter than I expected.
  2. Wintersdark
    Well, took it out for a spin today now the exhaust gasket rtv had some time to set.
    Sadly, "way quieter than I expected" only lasted until I had the engine under load. That 750 is loud when you wind it up without mufflers.
    So... yeah, while I'd be ok with "louder than it was", I'm less ok with "my neighbors will kill me." Sadly, this means the mufflers go back on today.
    Still gonna try some pipes with baffles, though... just definitely using baffles. I'd love to keep that deeper note without the volume.
  3. Craig B
    Craig B Active Member
    Ontario, Canada
    Once you have some pipes on there moving the sound behind you it wont seem so loud.
    I usually keep the rpm low until i am away from the neighbors then let her rip.
    Stumplifter likes this.
    Umm....the stock pipes are baffled. No packing in them at all.
  5. Wintersdark
    I don't have the stock mufflers. They look stock, but they're aftermarket slipons and in mediocre shape. I've got a stock pair downstairs on my other exhaust, but they've got rusty holes in the bottom.
    I'm not after loud, but I do like the lower note of the open collector. So, I'm going to try with a couple short but wider diameter pipes with baffles, to see what that sounds like.
  6. dowski68
    dowski68 Well-Known Member
    Medford, Oregon
    How about a longer video with those pipes off or the pair you have installed
    Everybody likes a little Audio PORN.
    Wintersdark likes this.
  7. Wintersdark
    will do with the now re-installed mufflers for comparison.
    Definitely will once I've got the new pipes as well.
  8. dowski68
    Medford, Oregon
    Synced carbs today-
    tried out the Gunson Color tune seemed as though I got more sparks from around the adapter then I did inside the cylinder. :(
    tried to adjust fuel mixture on the number 1 cylinder and messed that up. Anybody know how far to turn the fuel mixture screw out ? From the seated position ?
    I need a good place to start from_Sigh
    That is what I have done today beside riding to work and back.
  9. fiveofakind
    fiveofakind Well-Known Member
    San Diego, CA
    Start with 2 1/2 -turns out
  10. dowski68
    Medford, Oregon
    Is that a full turn as in one complete revolution 360 degrees of brass screw
    If that is correct mine are way off-number four cylinder was only a quarter turn from the seated position.
    UM maybe that is why I was getting such good MPG I was starving her of that premium fuel she likes so much.
    Thank You
  11. fiveofakind
    San Diego, CA
    Yes...full turns
  12. Rebem
    Rebem Member
    Perth, Western Australia
    Licensed it.
    Finally. :)
  13. dowski68
    Medford, Oregon
    Now it is time to put some miles on her! Enjoy the ride :D
    Rebem likes this.
  14. wgul
    wgul Active Member
    Boston
    Installed paper fuel line filter. It has a clear plastic case. (Briggs & Stratton ). Couldn't pull fuel line off petcock after much effort so I just cut the line at the right place with tank raised up about 5" and put the filter on. There is actually a fair amount of space under the tank for one of these filters. A bit larger than the usual filter used on these old yamahas.
  15. XJ550H
    paper may cause you problems you want a metal filter element I have the part number someplace,
    this link covers install and part number
    http://www.xjbikes.com/forums/threads/how-to-install-a-fuel-filter.6352/#post-208637
    Primeline part number 7-02357.
  16. wgul
    wgul Active Member
    Boston
    I'd like to hear more about the probs with paper filters. I've never had any issues. Thanks for the link.
  17. MattiThundrrr
    MattiThundrrr Not a guru
    America's friendly hat
    Paper filter is too restrictive. It won't allow enough fuel through to feed four hungry carbs. It can cause your bike to "run out of gas" even with a full tank.
  18. Plug
    Plug Active Member
    Missouri
    Picked up my 2nd XJ!!!!!!!!!! XJ 750 Seca...........my wife is now thoroughly pissed that there are two bikes in the garage.
  19. XJ550H
    the prime line filter is 4 cylinder motorcycle rated at least it says that on the package
    wgul likes this.
  20. XJ550H
    wait until the third one shows up
  21. Paul Howells
    Paul Howells Active Member
    Victoria, BC
    I've got one of the good ones! My wife even suggested building a structure in the driveway to keep my bikes out of the rain. Unbelievable.
    tcoop likes this.
  22. Wintersdark
    I got #2 and #3 at the same time.... That went poorly.
    TheCrazyGnat likes this.
  23. cgutz
    cgutz Well-Known Member
    SE South Dakota
    Finally solved my "creaky" front brake. After new SS lines, redoing the caliper pistons, bleeding the line this spring, the brake worked. However, it was "creaky" in that it was "notchy" when I squeezed the brake lever. Thinking it was caused by sticky caliper piston, I took the caliper apart about 5 times trying to figure out what was wrong. I was about ready to spring for a couple hundred bucks to buy a refurb caliper from Len.
    Early this week, I finally realized, "Duh" - the "creaky sound" as coming from the lever/master cylinder area, not the caliper. Turns out the piston underneath the master cylinder needed a shot of lube. I remember I had accidently dribbled brake fluid down the side of the master cylinder. It probably got in there and was causing stickiness. A shot of lubricant on the lever pivot point and into the master cylinder piston (not sure if that is the correct term - it is where the lever adjustment screw presses into the master cylinder) and the front brakes are once again silky smooth.
    Sometimes the problem area isn't where we think it is. The fun of diagnosing.
  24. cgutz
    SE South Dakota
    My Colortune did the same thing. Try some black tape or shrink wrap around the end of the adapter and porcelon. That was actually the "fix" that Gunson told me to do via email.
  25. fiveofakind
    San Diego, CA
    Just tell her that one of them is for her
    tcoop and Jetfixer like this.
  26. MattiThundrrr
    My wife is encouraging me to buy another bike... she wants the Rebel for herself. She's almost as frustrated as me at how hard it is to find a 650 Seca.
  27. wgul
    wgul Active Member
    Boston
    Hmm. . Haven't run into that problem
  28. Simmy
  29. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    2 out of the 3 pics showing shocks have the old shocks on, looks like he didn't completely break the rack.
    IF I had money to play with I would offer $800
    - I am as cheap as dirt
    OOOPS - MODERATOR should move this and previous message to Craigslist in HangOut Lounge
  30. Wintersdark
    Took the old girl to a local upholstery shop to price seat recovery as mines tearing.
    With a full recover and foam modification (getting rid of the hump in the middle so I can sit back further) it'll be $125 CDN, and take a day. Seems pretty reasonable to me.
    Hopefully next week I can have it done.
    Jetfixer likes this.
  31. MattiThundrrr
    It doesn't look like it is going to happen this year. In September I'll be getting a couple of surgical procedures which will put me on disability for a while. Money will be tight, and the riding season will most likely be over. Until next year, I'll just bitch and complain.
  32. Dadoseven
    Dadoseven Active Member
    Omaha
    Rebuilt and re-assembled Anti-Dive actuating piston assembly housing, thanks to parts from XJ4EVER.
    Was a little worried about bleeding brakes again based upon previous experience. Got it done!
  33. dowski68
    Medford, Oregon
    Looking forward to the day I have more then one XJ in the stable.
    Chitwood likes this.
  34. turpentyne
    turpentyne Active Member
    Desert SW
    Today, I put the rebuilt master cylinder back on, and my new braided stainless brake lines - most of the way. I'm stuck waiting for next paycheck to buy caliper rebuild kits. I'll spend the time kicking myself in the keister for not using the brake lever to push those pucks out. But... another weekend closer to gettin' her on the road!
    ...Annnnd grumbling after spotting more damage from the bike being dropped at some point. The throttle handle is cracked up right at the endcap. I didn't see it when inspecting. I have a feeling the guy put a dab of glue or something in there to hold it down, and it finally melted away in the Arizona heat, for me to see. That's ok... in a couple paychecks or so, my loss will be Chacal's gain! ;)
    Dadoseven likes this.
  35. Plug
    Plug Active Member
    Missouri
    Got the carbs into church for the next 4 days, and got all my valves in spec on the 750 Seca.......
  36. Dadoseven
    Omaha
    Investigated cause of non-returning shift lever. Replaced the shift lever return spring and the shift torsion spring; although neither was broken.? Replaced anyway.
    Maybe something wasn't installed properly? Couldn't tell for sure because the return spring mechanism and pawl came out with the cover.
    While I had the cover off, thought it would be the perfect time to polish it up:
    Also of note, there wasn't a gasket present on the cover; just some gasket sealant. Was this normal from the factory?
    wgul, dowski68 and Jetfixer like this.
  37. XJ550H
  38. Dadoseven
    Omaha
  39. XJ550H
    not weird just PO syndrome
    Wintersdark and Dadoseven like this.
  40. Dadoseven
    Omaha
    Replaced side case and new gasket after replacing shift lever return and torsion springs yesterday.
    Took it out for a test ride... shifts beautifully! and.... no oil leaks from case.
    With a previous post by someone else that has a recalibrated speedometer (labels over the numbers) in mind, strapped my phone on using a speed checker app. Everything up to 55 is just about right on.
    Rooster53 likes this.
  41. Jetfixer
    Went to go to a buddies house , bike had sat for a few days cranked a few times it hit and died ...cranked and starter stuck even with iginition off :( finally quit . Tried it again and bike started. Took off bike ran fine went to buddies house worked on his KZ1000 CSR got it running , while there worked on another guys 78 Honda 750 . My buddy is trading a couple of dirt bikes for an 82 XJ1100 Maxim ...I'm jealous :rolleyes: ..rode way out in the sticks was a good day.
    wgul and Dadoseven like this.
  42. MattiThundrrr
    Funny how one good ride can overrule all the negatives...
  43. dowski68
    Medford, Oregon
    2017-08-14 19.33.10.jpg Enjoying the ride my friends.
    Another mile stone accomplished.
    Actually I have a few goals
    One-Enjoy the Ride!
    Two-All ways utilize the entire tire to get my monies worth :)
    Three-Put as many miles on as possible.
  44. fiveofakind
    San Diego, CA
    Dow,
    Have you had the bike all 68k ?
  45. Joe34
    Joe34 Active Member
    Halifax nova scotia
    Mine is getting a tune up. So can't wait to get back on it. Guess the carbs were pretty dirty. Can't wait to try it out.
  46. wgul
    wgul Active Member
    Boston
    Changed the rear hypoid gear oil. I don't think the previous owner had ever changed it.
  47. Plug
    Plug Active Member
    Missouri
    Got the carbs back on the 750, synced it, went for a 20 mile ride.......runs like a scalded dog! Came back and installed my 5.6k resistor to turn my battery warning off. Good day, my new bike is done!
    Jetfixer, Stumplifter and Dadoseven like this.
  48. Wintersdark
    5.6kohm you say? Where are you installing that? I'd love to be down to just one annoying CMS complaint (TAIL).
  49. Plug
    Plug Active Member
    Missouri
    I put it between the positive terminal on the battery and the white red stripe wire. Rooster53 has a good write up on it here. He calculated that the 5.6k will trip the warning at about 11v, so it will still give you a heads up if something is wrong in the charging circuit.
  50. dowski68
    Medford, Oregon
    I would like to say yes but no. I am the third owner.
    Original owner bought the bike brand new and logged on about 42,000 before he sold her to a young kid who only rode it for one season here in Southern Oregon. Got a DUI and needed the money so I picked her up for 1300.00 with 44,000 thousand.
    I have had her for close to five years now and put 24,000 on myself.
    This is also my first motorcycle I have ever owned.
    I also have had to rebuild the top end due to lack of valve maintenance from Previous owner. 44,000 miles past the recommended valve adjustment. Other then that no problems other then tires LOL.
