What is that sound....?
Discussion in 'XJ Technical Chat' started by JazzFish, Aug 8, 2020.
  1. JazzFish
    JazzFish New Member
    Canada
    I thought I'd give my bike some TLC today and took it to the car wash (Good idea? Bad?). I sprayed it down with the pressure hose and just got it everywhere to remove bugs, etc.
    Once I finished the bike wouldn't ignite. It had the regular sounds of trying to start up. Tried some starter fluid a few times to no avail. The bike backfired a few times. Tried to kick start it; didn't work. Waited around an hour and tried to start again. It worked!
    But on the way home I was in first gear basically the whole time and I couldn't get the engine to rev. Here it is in my garage. I have not got the slightest clue what is going on here. Hoping for some answers and remedies!
    ignition coils got soaked by pressure washer.
    that sound may be misfiring cylinders.
    turn out the lights and see if you have sparks coming from the plug wires
    you really shouldent use a pressure washer on a motorcycle never know where it will force water into
    cgutz and raskal like this.
  3. raskal
    raskal Active Member
    Abbotsford B.C. Canada
    Bad idea.
    You got water onto the electrics. My hopelessly uneducated guess would be a cracked coil or spark plug wire.
    I would let the bike dry a good long time and see if it sounds better.
  4. Franz
    Dry out the plug caps, coils and HT leads with an old hair dryer if you can get one just keep it away from fuel. I used to do that with my 750 Honda.
  5. JazzFish
    JazzFish New Member
    Canada
    Thanks for the responses: I now know not to use a pressure washer. I've seen bikes come out of the car wash before and just assumed it's a good thing.
    On another note: On other rainy days, something similar happens. Would this mean I have a leak somewhere that I should be having a leak?
    I'm just going to leave the bike to dry for a few days before I do anything with it.
  6. XJ550H
    you have an electron leak through the sparkplug wires or coils. check them out for cracks which can be filled in and the wires can be spliced to replace them.
  7. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I had the same problem on my XJ700. After it dried out it ran normally. However, I found that if I used a hose and ran some water on the plug wire and cap I could duplicate the problem. I let everything dry out and then removed all the plug caps and coated them with dielectric grease inside and out. Never had a problem since and that was a little over a year ago or longer.
    https://www.farmandfleet.com/blog/w...une-up,elements out of electrical connections.
    Timbox and Franz like this.
  8. Ben Hinz
    Ben Hinz Member
    Southeastern Wisconsin
    I also had an issue with my 82 650 not running properly when wet. Turned out I had two big cracks on both the coil housings. Filled those in with some epoxy and haven't had the issue since.
  9. k-moe
    Hopefully you didn't also get water into the wheel bearings or any of the case seals that have a low clamping force (like the valve cover gasket).
    Pressure washers are not motorcycle friendly.
  10. Franz
    Better with a bucket of water and detergent and wash the bike down with a sponge or soft brush to get all the dirt off. That's what I do.
    cgutz likes this.
  11. k-moe
    Or just wait for the rain. That's what I do :oops:
    SpearChucker likes this.
  12. Franz
    I don't have to wait long for rain in Scotland :D.
    SpearChucker and k-moe like this.
  13. Franz
    Billy Connolly said in Scotland we can get four seasons in one day :D.
  14. k-moe
    Just like Oregon. I still remember the occasional new snow in June up on the mountain.
  15. Franz
    Yes l looked at the big storm in Kansas some wild weather in the states .
