What is this seal for?
Discussion in 'XJ Technical Chat' started by Sean Howe, Oct 18, 2019.
  1. Sean Howe
    Sean Howe New Member
    Iowa, USA
    I recently purchased a non-running 81 xj750 seca. Still having high-idle issues after a deep cleaning.
    For my mixture screws, I have the screw, a spring, and a flat washer. I am attaching a picture. should these have an oring and pictured in the attachment?
    thank you!
  2. Simmy
    the o-ring goes in 1st to seal, then the washer, then the spring then the screw.
    The washer keeps the spring from cutting into the o-ring. Make sure your old o-rings are extracted from the carbs.
