What is this switch for?
Discussion in 'XJ Technical Chat' started by 650MAX, May 20, 2019.
  1. 650MAX
    650MAX Member
    Denton Tx
    Small toggle switch just below the speedometer...
  2. MaximusXJ650
    MaximusXJ650 Member
    West Yorkshire
    I'm interested in this, mine doesn't have it! I wonder if it is for something to do with heated grips?
  3. jayrodoh
    jayrodoh YimYam
    Cleveland
    Definitely not factory, are there wires running to it?
  4. 650MAX
    650MAX Member
    Denton Tx
    I don't think it's heated grips since I already took those ugly grips off and there weren't any wires running to them. I thought it was factory at first since the mount looks like a stock piece, but after a closer look I see that the wires are neatly wrapped in black electrical tape rather than the nicer black tubing used by Yamaha. They are kind of extra long and make a big loop on their way to entering the back of the headlight bucket. I also have a green wire coming out of the headlight bucket that used to run to the air horns that I removed, so I guess I need to get in there and sort out someone's mess.
  5. chacal
    Welcome to the dreaded POS......the Previous-Owner Syndrome.
    650MAX and Lodewijk like this.
  6. 650MAX
    650MAX Member
    Denton Tx
    Switch removed! It was the red wire tied into the green headlight wire?? Seems very strange...
  7. Baker6x6
    Baker6x6 Member
    Winston Salem, NC
    Likely.. someone may have had a set of driving lights installed. They are running (whatever?) off the low-beam circuit.
    chacal and k-moe like this.
