What Should You NOT Do to Your Yamaha Today?
Discussion in 'Hangout Lounge' started by PSteele, Jul 30, 2010.
  1. tjb2of3
    tjb2of3 Member
    Charlotte, NC
    You should not be in a rush to go out riding after adjusting valve clearances, put the tank back on, forget to reconnect the fuel lines, ride halfway out of the neighborhood, think you're out of gas, switch to prime, and then notice a puddle forming at your feet.
    I'm not proud.
  2. andrewlong
    andrewlong Member
    Cumming, GA
    You should NOT sand or buff in any way the ends of the ceramic resistor rod located in the spark plug boot in a futile attempt to get better contact.
    Knowledge +1 *sigh*
  3. Metal_Bob
    Metal_Bob Active Member
    Bourbonnais, IL
    Thanks for the removal trick :)
  4. hogfiddles
    You shot not forget to put the bowl drain screws back in the bowls before completely installing the rack and having everything hooked up to the substitute tank for syncing. Especially when the fourth bowl is a replacement bowl that has the drain screw facing the wrong way to begin with.
  5. chacal
    This is actually turning into one of the most useful threads on this site......... :D
  6. schooter
    you should not not beat the living snot out of some punk kid that tried to steal your pride and joy bike which has lots of labor and love into it... what a douche
  7. luvmy40
    luvmy40 Member
    Y-Town, OH
    You should not yell at the fata$$ toothless beeyatch that is leaning on your XJ at the gas pump before you realize the her cousin/boyfriend s 6'5", 340lb and right behind you!
  8. luvmy40
    luvmy40 Member
    Y-Town, OH
  9. Militant_Buddhist
    Militant_Buddhist Member
    Redmond, WA
    You should not, after getting a new rear tire mounted, tighten the axle bolt and bend the last cotter pin in your collection into the castle nut BEFORE rotating the brake plate into place and attaching the stay.
    You should NOT, after filling the tank at the station, mount your bike and feed your right foot unwittingly through an odd loop in the gas nozzle hose onto the peg and attempt to ride off like that. I can honestly say I've never done that on my XJ.
  10. mwhite74
    mwhite74 Member
    Ohhh, love the double-neg! Two wrongs don't make a right... But three lefts do!
  11. YVRxj650
    YVRxj650 Member
    Vancouver, BC
    You should not rid yourself of it. Even at the height of your frustrations.
    You will regret it, and you may not get it back.
  12. mhhpartner
    mhhpartner Member
    Louisiana, USA
    You should NOT have such an unhealthy fear of stripping the aluminum threads of your oil drain plug hole that you don't tighten the plug securely enough and it vibrates loose on the interstate (unbeknownst to you), dumps your oil, and seizes your engine.
    You should NOT then overcompensate when tightening the drain plug on your replacement engine and strip the threads, so that you are forever stuck with an unsightly oversized drain plug from O'Reilly's sticking out the bottom of your beautiful XJ that drips oil unless the perfect amount of Teflon tape is applied and the stars are aligned.
    You SHOULD buy a good torque wrench when you first get your XJ and do it what we like to call - the right way.
  13. Ground-Hugger
    Ground-Hugger Member
    Near Port Dover Ontario
    You should not stop at a light and forget to put your feet down on the road. 34 years of riding and my brother still cant get coordinated.
  14. pillowmaster50
    pillowmaster50 Member
    You should not stand up when your seat isnt latched.
  15. ken007
    ken007 Member
    Brisbane, Australia
    you shouldnt try and put a hot spark plug back in with a socket and 1/2"ratchet to save burning your fingers,you may strip your thread.didnt do it today,but we wont talk about yesterday,i even invented swear words.
  16. waldo
    waldo Member
    San Jose, Ca. 95125
    No one should ever let their bike run in neutral to warm up, on the side-stand, in their own driveway, facing down the ever so slightest grade, especially when their buddy and his wife just pulled in on their brand new Harley. Ya one shouldn't really do that it could be real embarrassing.
  17. clipperskipper
    clipperskipper Member
    Cape Cod, MA
    Forget to turn the fuel cock on before proceeding out of the driveway!!!
  18. bobberaha
    bobberaha Member
    Kentland IN
    Never open the visor on your helmet at highway speed to let a bee out of it.
  19. frankenbiker
    frankenbiker Member
    gobles michigan
    you should not fill the bike with new oil without putting the oil filter back on
  20. pillowmaster50
    Never over tighten your tripple tree clamps!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! *SNAP!*... "O, i hate breaking bolts... ill have to go to the hardware store tomorrow and pick up anoth...er...aaaaarrrrrrrrrggggggggggg!!!!" IM SO SICK OF WAITING FOR PACKAGES!!!!!!!!!!!!!!!!! had to pick up dirty ol' ebay item 380074893516 and mine was so much nicer, too!
    knew i shoulda used the torque wrench!!
    may my old triple rest in pieces. may have even shed a tear.
