what story do my spark plugs tell you???
Discussion in 'XJ Technical Chat' started by etg29, Mar 23, 2009.
  1. ZsoltK
    ZsoltK Member
    Hungary
    Sushi, just a bit of correction. You don't need to run at "high speed". You can run at any speed it doesn't matter. The important thing is the RPM and throttle position. For example, if you can find a decent hill you can check for WOT (Wide Open Throttle) in first or second gear.
  2. TheHound
    TheHound Active Member
    Scotia, NY
    As was said earlier the plug chop only shows you what's happening in the cylinder when you hit the kill switch.
    So depending on what rpm you are tuning for dictates when you hit the kill switch.
  3. XJMAN
    XJMAN New Member
    hi guys i have a 1982 maxim xj650 number 1 cylinder plugs is a dark brown real dark almost black looks way to rich looking plugs 2 thru 4 are a cocoa color but only on about have the plug insulator tip any ideas what the problem could be on number 1 plug i think 2 thru 4 are running properly
  4. TIMEtoRIDE
    XJMAN, (welcome) try turning the Pilot screw in 1/8 th turn, on just that carb, then drive easy for 2 miles, then re-check the plug.
    Tweak it a few times. Post your results.
