What tool to remove spark plugs on 750 Maxim X?
Discussion in 'XJ Technical Chat' started by TMark, Jul 24, 2023.
  1. TMark
    TMark New Member
    Dayton, OH
    The spark plug socket I have does not fit around the plug inside the sleeve. Does it require a special socket or tool?
  2. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Did you get the original tool kit with the bike? It would have the correct tool which can be used with a ratchet and socket to turn it.
  3. Simmy
    If I remember correctly it is an 18 mm spark plug socket.
  4. TMark
    TMark New Member
    Dayton, OH
    I did not think to look in there. I always think of those tools as what one would use on the side of the road. However, I did end up trying a ¾” socket that worked. Challenging to get a ratchet that would work on the two inside plugs. Thanks for your reply.
  5. TMark
    TMark New Member
    Dayton, OH
    I tried an 18 mm but was too small. Someone else said 21 mm but I don’t have a 21 mm. I tried ¾” and that worked. Thanks for the reply.
    chris123 likes this.
  6. chacal
    3/4" = 19mm
