What's the best way to clean the inside of a master cylinder?
Discussion in 'XJ Technical Chat' started by BigT, Jun 17, 2017.
  1. BigT
    BigT Active Member
    Airville, Pa
    My master cylinder is full of this chalky white residue, I have been going at it with a small screwdriver but not making much of a difference. Any suggestions?
  2. chacal
    Glass-bead blasting!
    BigT likes this.
  3. Jetfixer
    I have used a dremel with a brass wire brush and lots of brake cleaner .Brass will not mar surface, do not use a steel brush.
    k-moe and BigT like this.
    Work smarter, not harder.
    Fill it with brake fluid and let it soak. That will help to free up the crud, then you can use a bit of scrubbing pad to clean it out.
    BigT likes this.
