What's the one motorcycle of all time you wouldn't mind having?
Discussion in 'Hangout Lounge' started by Mechanic1978, Jul 6, 2021.
  1. Mechanic1978
    Mechanic1978 Active Member
    NOYB
    I absolutely love resto mods, and full customs and especially one of a kind machines. So when I cam across this article last year, and again yesterday the story captured my mind, but the bike it was about absolutely blew me away, being a hand built only one in existence kind of machine, from the design, execution, the hand turned parts and an engine completely ahead of its time, make this almost the rarest beast on the planet. the engine alone is a beautiful masterpiece, I had to share it with you all, I'm talking about the 1916 1,278cc butterscotch painted (probably lead based paint) Traub Motorcycle.
    It can be seen and read about here:
    https://www.motorcycleclassics.com/classic-american-motorcycles/traub-motorcycle-zmmz07jfzraw/
    So I'm curious to know of any other rare or highly sought after machines I may never have heard of that any of you may know of. What are your thoughts ?
  2. ColoradoDan
    ColoradoDan Active Member
    Longmont, CO
    The evolution of the XJ only available in the EU, and maybe down under. Yamaha XJR1300. Here is a pic of one I got to check out up close in the Netherlands 4 yrs ago. 20170710_120132.jpg
  3. Mechanic1978
    NOYB
    Would have preferred seeing that with a mono rear shock, however I do love it...
  4. XJ550H
    when I was in High school a lifetime ago we designed motorcycle frames on the drafting boards. full size drawings.
    we would design around an existing motor. With the help of our teacher and other shop departments we did put a several bikes on the street.
  5. Mechanic1978
    NOYB
    Is that xjr1300 shaft or chain driven?
  6. FJ111200
    FJ111200 Active Member
    Crewe, Cheshire, England
  7. Mechanic1978
    NOYB
    Beautiful! Red is my favorite color,
    So the 1300 above is chain driven?
    And I cee an inverted fork on yours with r6 blue dot calipers, you convert it?
  8. Franz
    Yes it looks great I like the inverted forks too.
  9. Simmy
    FJ1100/1200 derived motor.
    @FJ111200 what similarities and differences are there with the motors between the 2 bikes?
  10. Mechanic1978
    NOYB
    Only way to gain CC's is larger cyl bore diameter, so id guess at least the cylinder is different.
  11. FJ111200
    Yes i did all the work, FZR1000 RU EXUP front end, blue spots came from a bike i don't know, bought at an autojumble, could be R1. Both XJR12 and 1300 are chain drive, FJR1300 IS A SHAFT.
  12. FJ111200
    The only difference between FJ1100, FJ1200, and the XJR's is the bore size obviously and the the XJR's have got a longer main axle shaft to account for the bigger rear wheel and swingarm and a longer clutch push rod.
    On that XJR1200 of mine above i've used a FJ1100 set of crankcases and a FJ1100 crankshaft, only because i had them lying around and the crankshaft has done 140,000 miles and i just used the biggest crank bearings, the blue ones, just to account for any wear. It runs sweet as.
    Simmy likes this.
  13. Mechanic1978
    NOYB
    The blue spot calipers are iconic early 2000R6....they switched to blue spot radial mounts half way though production, but thats just mount type. so yours are early 2001 to 2003 R6. Just in case u need rebuild kits for them later. Nice bik tho man, I like it!!
    FJ111200 likes this.
  14. k-moe
    '82 XJ 750R
    Hmm.......
  15. FJ111200
    Thanks. I've also got them on my XS/XJ1100 hybrid affair. I usually buy brake pads for a XJR1300 and rebuild kits for the same from a member of the UK XJR Owners forum who has got a shop. I take it you know the 1100 is a shaft drive?
    [​IMG]WP_20210530_15_07_07_Pro_LI by Billy Bananahead, on Flickr
  16. dkavanagh
    Rochester, NY
    Heh, I'm just selling some blue-spots right now... picked up some gold spots for my FZR1000!
  17. RangerG
    RangerG Member
    Lloydminster, Saskatchewan
    I’d like either an Indian 4 cylinder with the skirted fenders or a top of the line Motus Sport-touring bike.
  18. Mechanic1978
    NOYB
    I somehow knew that an Indian would be mentioned at some point. Nice choice.
  19. Simmy
    I want a 1961 motorcycle, same age as me.
    Thinking a 1961 BSA Goldstar Catalina would do nicely.
    That's me below with the poor man's version.
    My 441 Victor is worth about 1/10th the value of the Goldie, LOL
    Franz and jayrodoh like this.
  20. Kickaha
    New Zealand
    I'm just building a 1956 BSA A10 into something very similar along the lines of the Spitfire Scrambler
  21. Simmy
    So essentially a pre-unit Firebird?
