Where do I get new rubber seals for my carbs
Discussion in 'XJ Technical Chat' started by Xjriley, Aug 15, 2020.
  1. Xjriley
    Xjriley New Member
    Ohio
    I have recently got an 82 xj550 maxim. I'm preparing to crack the carbs or "break the rack" and replace as much stuff with new stuff as possible. But I cannot find where to get new rubber seals for the throttle shaft and choke shaft and fule tube seals. If anyone knows where to get a set or what kind of rubber seal kit to bu . It would be appreciated guidance.
    My first post
  2. Mezzmo
    Mezzmo Active Member
    I replaced mine recently, bought them from eBay. See this link, o-rings can work but I think v rings are the best option and worth paying for.
    https://www.ebay.com.au/itm/254570907087
    also see my build video as that should help too.
    JCH and Jetfixer like this.
  3. Huntchuks
    Huntchuks Well-Known Member
    East Rochester, NY
    Or click on the big "Everything XJ" icon in the top right corner of this page to find what you want. You need to do your own digging to get to the correct parts.
    Jetfixer likes this.
    Do not buy carb parts on Ebay, unless it's just a spare rack or carb body.
    @chacal stocks the proper rebud kits and loose parts for all XJ carbs. Most kits on E-bay are not actually correct.
    Nyk B and Jetfixer like this.
  5. k-moe
    Nah. Just start a conversation with Chacal and he'll give you a quote within a day or two, including the appropriate aftermarket optons.
    The catalog is worth reading through though. Lots of extra information about OEM fitment and fault diagnosis.
  6. Xjriley
    Xjriley New Member
    Ohio
    Wow thanks guys! This site is the shit!
    I already ordered a 4 carb kit off Ebay but I'm going to look at the everything xj right now. Thank you all!
  7. JPaganel
    JPaganel Well-Known Member
    Minneapolis
    Carb kits pretty much never include shaft seals.
    Yamaha does not list them as a separate part for the XJ.
    That said, Mikuni shaft seals, which is what you need for a 550, are available new from Yamaha. Part number 256-14997-00-00
  8. k-moe
    Not to lay it on too heavy, but every Yamaha dealer I've ordered XJ parts from had to have them shipped in from Japan. Chacal has the parts in stock. 4 days at most from Chacal compared to a month from Yamaha.
  9. Jetfixer
    Cannot say enough good things about xj4ever , his parts are spot on , some may wine about cost ...but my favorite adage "buy the best ...cry once" I'm lucky I have an old Yamaha dealer close by , they can order parts , but many times xj4ever has the parts in stock . I got my seals for the throttle shaft from him perfect fit.
  10. Nyk B
    Nyk B New Member
    Detroit
    So true.
  11. Mezzmo
    Those seals worked perfectly for me, I doubt you will have any issue. Just make sure you put them in the right way around. Eg V faces outwards...
