why lol please help
Discussion in 'XJ Technical Chat' started by mgjmlg, Feb 23, 2017.
  1. mgjmlg
    mgjmlg New Member
    kingston ON
    Hi i got a 83 xj750 maxim.. the other day i only had 2 cylinders outa 4... i took carbs off and cleaned the bowls and blrw air through the hole thing (did that b4 with weed eater worked great) anyways.. now i have 3 cylenders firing but the one carb is just pooring out the gas out the air intake side (see attached pic) iv pointed to the hole with my screwdriver.... and i meen poors out that hole.... why... is it something iv done? What should i look at or adjust... btw im a complet noob to this bike just got it on monday.... thanks for your time
  2. mgjmlg
    mgjmlg New Member
    kingston ON
    Oh btw i meen not only when bike is running but off too... as soon as i turn my tank on it starts and as soon as i shut it off it stops
  3. k-moe
    Float or float needle is stuck. Petcock is working correctly.
    Open the oil fill cap and have a sniff. You might have gas in the crankcase too.
    If you haven't rebuilt the carbs yet, plan on doing that soon.
    IN THE CHURCH OF CLEAN
    The Information Overload Hour
    Stumplifter and hogfiddles like this.
  4. mgjmlg
    mgjmlg New Member
    kingston ON
    Ok thanks il check that out...iv had bike for 4days now 2 of them were spent cleaning it off lol
  5. k-moe
    Please be cautious and thoroughly read through the second link I provided.
    Any used bike must be assumed to need all of the maintainance caught up on, and some of that missed maintenance can cost you a ruined engine, or even your life.
    Stumplifter likes this.
  6. Stumplifter
    Stumplifter Well-Known Member
    near Irma, WI
    Listen to "the dude".
    This is not a weed eater - complete carb rack teardown and rebuild (replacing 30 year old worn components) is the right way.
  7. Jetfixer
    A full tear down and replacement of ALL rubber seals shaft and fuel rail "O" rings highly recommend the soild brass tip needles. Soaking carbs I recommend Berrymans get a 1 gallon container after trear down soak each carb body for about 45 minutes . Wash carb body with Dawn dish soap and wash with lots of water blow dry. Reassemble check float height 17mm measured from the flange to highest point ofthe float you will need to bend the tang on the float to get measurement. This the dry setting ideally you need to do a wet set 3mm from top of flost bowl. After reassembly do a bench synch I use 2 buissness cards cut in two slide under each butterfly adjust synch screws until you get a slight drag when pulling on the card...this will get you close note there are 3 screws only . I have a 4 vacuum gauge manifold for synching carbs this my prefence or make a two bottle manometer. You will find most of this info at church of clean. Just be aware what I outlined is best way to "clean carbs correctly" good luck
  8. Door dude
    Door dude Active Member
    Mountain Home Arkansas
    mgjmlg, church of clean is the gospel to the xj's been there done that and didn't have to do it again.
    Jetfixer likes this.
  9. mgjmlg
    mgjmlg New Member
    kingston ON
    Wow thanks for all the info guys... i really want to get this bike workin mint.. been wanting my own bike since 16...( hate riding the oldmans bike lol) just cause its not mine im always scared of somethin happening to it... i will check out the church of clean...
    Medici and k-moe like this.
  10. Stumplifter
    near Irma, WI
    Read both of those links thoroughly that KMoe posted. Invest some time and $$$ to get it right and mint it shall be - your reward will be that big ass goofy grin (and all that comes with it) when you twist the throttle and you get pulled into the power band range! Hold ON!
