Why wont bike start?
Discussion in 'XJ Technical Chat' started by Anthony P, Mar 18, 2019.
  1. Anthony P
    Anthony P New Member
    Pittsburgh
    Was doing a few things to my 83 xj750jm, took off exhaust system because i wanted to clean it and put on new turn signals. When i put it the exhaust back on the bike and started it, it started right up, ran for a minute then the bike started to smoke some of the cleaning products and then it shut itself off. i cant get it to start back up. Starts for a second with ether but then shuts off. Please help. So confused.
  2. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Did you have the exhaut plugged with rags n leave em in when you put the exhaust on?
    I NEVER did that once on a quad... Lol!
    Otherwise for some reason your not getting fuel.
    Jetfixer and jayrodoh like this.
  3. Anthony P
    Pittsburgh
    I had paper towel stuffed in but i took em all out
  4. Colin 85 700
    Thunder Bay, ON
    Try petcock on pri setting, maybe carbs are dry from sitting?
  5. XJ550H
    if starting fluid makes the bike run than it sounds like a lack of fuel issue.
    and how much fuel do you have in the tank?
    if your fuel tank is low on gas could be you just have to set petcock to reserve
    fuel filter?
    vacuum hose connected?
    just want to get the simple things out of the way first
    battery run low? charge the battery.
    CHECK your oil level incase your carbs drained into the crankcase
  6. XJ550H
    If thing above checks out try opening a drain screw on carb bowls see if you have fuel in carb bowls
    centerstand the bike.
    connect a drain hose to one carb bowl open drain screw let fuel drain with petcock on prime. see if you have fuel flow down to the carbs.
    if fuel flows freely. close screw, remove hose, put gas away.
    see if bike starts.
    if bike starts switch to run see if it still runs.
    How about a little history on the bike?
    what have you done to the bike for maintenance?
    when was bike running last?
  7. Anthony P
    Pittsburgh
    Im an idiot! The day it was taken apart i forgot the gas level was in reserve territory. Thanks for the reply, thought i left a towel in the exhaust
  8. k-moe
    You aren't an idiot.
    An idiot would check the gas, see that it's low, and still wonder why the bike won't start.
  9. XJ550H
    so did you get it running?;)
  10. Anthony P
    Pittsburgh
    Sure did. Sold her. Going to look at a 94 cb1000 and a 2005 fzr1000 tomorrow
    Jetfixer likes this.
  11. Colin 85 700
    Thunder Bay, ON
    Oh, how sad... Get rid if a nice classic so you can go a million miles an hour and get a speeding ticket...
    Each to his own lol! ;)
  12. hogfiddles
    Did you remember to tell the new owner that is out of gas?
  13. Anthony P
    Pittsburgh
    I filled it up for him! And my bike had a great engine but it was really rough cosmetically. He wants to chop it and make a bobber (good luck) and the fz1 is pretty fast. Ill be honest tho, doesnt quite give me the fiz like that old maxim.
