Why you should replace butterfly (throttle shaft) seals.
Discussion in 'XJ Technical Chat' started by Jetfixer, May 12, 2019.
  1. Secacsm89
    Secacsm89 Member
    Replaced both with the throttle shaft seals and v seals on fuel rails with a complete rebuild minus the main 120 jets. Now when I try and start it only starts up when promised then shuts down. I adjusted the idle adjustment screws out a 1\2 turn in between the starts. Next,is remove the carbs and install the new intake manifolds I just got, unless anyone has a better idea with less hassle. Got the bar clamps and heat gun ready. Appreciate any advise received on this very long and tedious task.
  2. Franz
    Did you wet set the floats and bench sync the carburettors before you tried to start it? You could check it for vacuum leaks too. Watch the bolts holding the intake boots to the head they can shear. Probably the original factory ones been there a long time.
    Brhatweed likes this.
  3. Franz
    Where did you get your intake boots? The Chinese ones on ebay are poor quality.
  4. Secacsm89
    Secacsm89 Member
    They are I just them.
  5. Secacsm89
    Secacsm89 Member
    I did the bench test and adjusted the floats to spec also I can drain each float bowl on the carbs.. Completed the "church of clean" including replacing most of the butterfly
    shaft screws.. Thanks for the replies.
