Will this come back and bite me in the a@#
Discussion in 'XJ Technical Chat' started by Door dude, Nov 3, 2018.
  1. Door dude
    Door dude Active Member Premium Member
    Mountain Home Arkansas
    The question is, why did that happen?
  3. Door dude
    I was cleaning the carbon off with a wire brush wheel and a drill, i was holding the piston head with a shop towel and the wheel grabbed the rag and flipped it out of my hand and it hit the floor.
  4. XJ550H
  5. Rice_Burnarr
    Rice_Burnarr Member
    Near Philadelphia, PA
    Wow. A bunch of "never do that" in that one sentence.
    Starting with the most obvious... Never anything loose fitting or dangly around rotating machinery. Glad you didn't lose a finger.
    Good luck finding a replacement piston and getting the motor back together. And I'm no expert, but if you haven't yet used the wire brush on the other three pistons, I wouldn't do that either. Looking at the marks left on the piston from the wheel, it seems too aggressive.
    Stumplifter, Colin 85 700 and k-moe like this.
  6. Franz
    Better with a strong plastic scraper to get carbon off. At least its worth a try. Better for not damaging the soft aluminium.
  7. tabaka45
    tabaka45 Well-Known Member
    Brunswick, Georgia
    I agree—way to aggressive! I think a new piston is in order.
  8. vashtsdaytona
    vashtsdaytona Active Member
    Fargo
    I think it would run, probably for a while if no burs. BUT for the cost I'd replace it for the piece of mind.
  9. Door dude
    I agree with you guys, way too aggressive. Ive got a parts motor for parts. Thanks xj550h for the ebay listing
  10. k-moe
    Brass brush next time, after a soak in 50/50 ATF and acetone. No power tools need apply.
  11. Jetfixer
    ^^^+1 know is right ,harbor freight has brass wire brushes you can get for high speed drill ,wont mar or cut into the metal . Your. Going to need to replace piston , this will make a nice ashtray, or flower pot.:(
  12. XJ550H
    some of those brass wire brushes are steel coated with brass
    jayrodoh likes this.
  13. joejr2
    Santa Fe,NM
    Last week I did a top end rebuild on an xj maxim engine. The old pistons were petty beat up and the #1 had a cut off skirt. I ordered a new set
    from ebay but tested my cleaning methods on the old set first. The wire brush was too aggressive, so I tested a suggestion I got on this
    forum. 50/50 Acetone and ATF with a brass wire bush. I substituted various grits of scotchbrite pads for the brass brush. I used a coarse
    paint stripper pad on the tops and medium and then fine pads all over. After an overnight soak in ATF the pads cleaned each piston
    spotlessly in about ten minutes.
    Colin 85 700, k-moe and chacal like this.
  14. jayrodoh
    jayrodoh YimYam Premium Member
    Cleveland
    Yup, misread that before and damaged some stuff.
  15. k-moe
  16. Door dude
    Seems like iv'e read that somewhere.
  17. Colin 85 700
    Colin 85 700 Active Member
    Thunder Bay, ON
    Please tell me you didn't use this method on your gasket mating surfaces already...
    Same solution mentioned above and some NEW razor blades work best there, with finesse!
    Scratches of any magnitude are your enemy ;)
  18. Door dude
    Nope, xj forever degreaser and a putty knife came off in one piece.
  19. joejr2
    Santa Fe,NM
    I use one of those single edge razor scrapers, being careful to not nick the surface, then I clean the surface up with a rag with lacquer thinner and 400 grit
    wet paper wrapped around a wood block that has at least one good flat side.
