Will xj750j fork springs fit xj650j?
Discussion in 'XJ Technical Chat' started by 750MaximSeattle, May 30, 2019.
  1. 750MaximSeattle
    750MaximSeattle Active Member
    Seattle, WA
    I’d like to use fork springs from 750 Maxim and install in 650 Maxim. Same dimensions? Any issues i might encounter?
    TIA!
  2. Toomanybikes
    Tsawwassen bc
    You probably have both on hand only way to know is give it a try. Or just swap the entire fork, wheel and brakes.
    750MaximSeattle likes this.
  3. Kickaha
    New Zealand
    Why do you want to do that? are you looking for a stiffer spring rate?
  4. XJ550H
    650 G and H 606mm 650J 467 mm
    750 J and K 458.5 mm
    so length wise 750 is shorter than 650J
  5. 750MaximSeattle
    Seattle, WA
    Tomorrow, I take delivery of an xj650j project, which has sagging front springs. I'm considering pulling springs from xj750j forks with bent tubes. By the way, once those fork tubes are removed, I'll probably offer the lowers for sale.
  6. Toomanybikes
    Tsawwassen bc
    If forks are sagging then install longer sleeves and heavier fork oil
  7. 750MaximSeattle
    Seattle, WA
    Oil is probably low, both seals leak. I have new seals to replace them. Could low oil alone cause the front to sag?
  8. k-moe
    No.
    Toomanybikes and 750MaximSeattle like this.
