Winterized bike? Fill with motor oil
Discussion in 'XJ Technical Chat' started by Alain, Dec 17, 2012.
  1. Alain
    Alain Member
    Ok, i've winterized my bike (put in wonder oil in pistons, put in fuel stabilizer) and had all the oil removed to replace springs on my gear changer mechanism.
    My question is, since i drained out all the oil to change my gear changer springs, do i need to refill it since it's jsut going to pool at the bottom?
    Theoratically, shouldn't it not matter? since the oil has cycled through the engine previously prior to me draining the oil out. i also put in a few drops of wonder oil in the pistons. the only variable is that the new springs in my gear changer might rust in the next 3 months?
  2. Thrasher
    Thrasher Member
    Oak Ridge, Tennessee
    What are you referring to as the gear changer and what bike is this?
  3. hogfiddles
    I would assume he means the clutch basket springs. but purely an assumption.....yeah, I know what 'assume' means...............
    dave
  4. bigfitz52
    I think he means shifter mousetrap springs. But the answer is still the same, store the bike with oil in it.
  5. Alain
    Alain Member
  6. Thrasher
    Thrasher Member
    No photos, still wondering. Where are you located?
  7. pnthubb
    pnthubb Member
    San Diego
    Link is broken friend.
  8. maverickbr77
    maverickbr77 Member
    Lowville, New York
