Wireing from 1981 seca 750
Discussion in 'XJ Technical Chat' started by Hunterbro1, Apr 20, 2017.
  1. Hunterbro1
    Hunterbro1 New Member
    Pennsylvanis
    Someone rigged a new ignition switch. I accidntly pulled the connetions running from under my tank, a red and green set of wires. Having blown 4 fuses I thought it best to consult. It was running fine before my tampering.
    Where do the wires go. There are no loose wires in the stock harness. Everything is wrapped.
  3. XJ550H
    red could be main fuse and rectifier or power from battery to main fuse , green rectifier, alt single winding , high beam indicator, dimmer switch, atari
    did you ohm the fuses to make sure they "blew"
