Wiring diagram
Discussion in 'XJ Technical Chat' started by Richardl801, May 18, 2022.
  1. Richardl801
    Richardl801 New Member
    Ks
    Hi I have xj 1100 and have till 7th if June to be riding have a military ride to east coast to go in very important I have no instrument panel but they seem to be all the wires for it there I see fuses and light bulbs from a instrument panel but the wiring harness might be from a 82 xj 750 will this work the same and does anyone have a diagram this bike is from a fallen brother in my unit so it’s a must for this soldier to ride it to the east coast n his name and I’m just thinking that I am close but the magnitude of it I am thinking is causing me to be clouded by it please help I can put up or send pics to anyone if it helps I’m pretty much look at regulated wires and a few empty plugs the bike was burnt at one point so not all plugs were stil on it but that was figured out before this I’m hoping just a diagram of it all will set me straight also it has the yics delete installed as well and doing a on off switch on side and start button on side panel I have made
    You would be better off wiring with the minimum wiring diagram. Why do you think you possibly have a 750 wiring harness in front of you?
    Richardl801 likes this.
  3. XJ550H
  4. Rooster53
    Pictures would help and can be posted here, sometimes you need 5 posts to avoid SPAM filter
  5. a100man
    a100man Well-Known Member
    Bedford, UK
    ..and you'd be better off adding some punctuation to encourage people to read to the end.
