Won't start! :-( help, please?
Discussion in 'XJ Technical Chat' started by Sarah, Apr 23, 2020.
  1. Sarah
    Sarah maxim-um fun
    Indiana
    Me, too! *fingers crossed!*
  2. hogfiddles
    For ticking.... first thing I suggest—-
    check all your exhaust collars and nuts. It’s very possible you have a loose one
    Sarah likes this.
  3. Sarah
    Sarah maxim-um fun
    Indiana
    Will do!
  4. Sarah
    Sarah maxim-um fun
    Indiana
    Had a loose spark plug. Like, very loose. Think I found the ticking.
    (It wasn't loose when this all started, I pulled and checked them all after the no starting started lol.
  5. hogfiddles
    Pretty much the same thing... glad you found it
    Sarah likes this.
  6. Sarah
    Sarah maxim-um fun
    Indiana
    As soon as we bent down to start looking, it was pretty obvious. That plug was so loose, we could just pull it out by hand...
    Franz likes this.
  7. Sarah
    Sarah maxim-um fun
    Indiana
    Thank you, Hogfiddles, and everyone else for your suggestions and everything! It lives again!
    chacal, hogfiddles and Franz like this.
  8. Franz
    Glad l was wrong Sarah.
    Sarah likes this.
  9. Sarah
    Sarah maxim-um fun
    Indiana
    Sorry to "like" that, but I am quite happy as well that I don't have a long engine rebuild ahead of me! Yet, lol..
    QUOTE="Franz, post: 641600, member: 19000"]Glad l was wrong Sarah.[/QUOTE]
    Franz likes this.
  10. Sarah
    Sarah maxim-um fun
    Indiana
    Is this main gear stripped? It has a like, kind of a bevel that I don't see on new gears.
  11. SQLGuy
    SQLGuy Well-Known Member
    Wow! So it was the starter? That gear looks fine to me.
  12. Sarah
    Sarah maxim-um fun
    Indiana
    Apparently!
    Pic shows my next best guess. I think they were thin when I rebuilt.
  13. hogfiddles
    Gear pics look fine
    Sarah likes this.
  14. Sarah
    Sarah maxim-um fun
    Indiana
    Kinda figured. Hmm
  15. SQLGuy
    Doesn't sound like brushes should be the issue, since the starter was spinning just fine. I wonder if there's a shim or a bushing out of place that makes the gear not stick out the correct amount.
  16. Sarah
    Sarah maxim-um fun
    Indiana
    Interesting theory. I might have to disassemble both (for comparison) and make sure that isn't it. I kinda think the copper strips the brushes spin around are too thin, they aren't even copper colored anymore.
  17. Rooster53
    Can you rotate that gear with your hand and is it fairly difficult to rotate, which would be normal? If you place a meter on the large terminal and chassis you should see about .3V being generated when you rotate the gear. With the meter positive on the large terminal and black on chassis you should see a positive voltage when you rotate the gear CW (viewed from starter gear end).
    If the above checks out then powering the starter to check the direction of spin could still be in order. The brushes appear to be correct in the pic you posted, but shorted commutator rings might get it going in the wrong direction.
    Franz likes this.
  18. Sarah
    Sarah maxim-um fun
    Indiana
    I'll have to do those tests on it tomorrow. Apparently I have coronavirus! Yah!:(
    I will get around to the testing, though, because I'm super curious why it doesn't start the bike. I'm also going to measure it for SQLguys suggestions.
