Wont stop leaking gas!!!!!!!!!!!
Discussion in 'XJ Technical Chat' started by snayke62, Jun 5, 2009.
  1. wingnut325
    wingnut325 Member
    Havelock North Carolina
    Thats a problem but an unrelated one to the fuel leaking out of your carbs. The floats must stop the fuel flow at the proper level or the bike will run super rich all the time. If the needle valves stop the fuel flow like they should you can have no petcocks and it will not matter. Petcocks are not fuel regulating devices they are just shutoff valves for when the engine is not running. Fix the float level problem first. Then you can still ride while you straighten the petcock issue out.
  2. snayke62
    snayke62 Member
    Illinois
    Well. i didnt get a chance to work on it further but read your advice. Im sure the floats are in right. the stopper tang that stops the float from hanging down too far are on the left with the perches towards your body when holding upside down. just like the photo in one of the threads. Ill double check though. I have checked the vacuum hose on the petcock-its dry. as far as the floats hanging too low---what kind of measurement am i looking at? but-its not an anitial fill problem. i had it together last time and they held fuel. the bike ran good. it sat in garage for a week and didnt leak a drop. fired up first push of the button every time and idled. it wasnt until i drove it around and to the gas station and filled up that it started to leak again. i had to take off the fuel line at the filter and kink it closed to make it stop. i am pretty sure there is some pretty good end play between the float brackets and perches. ill shim them centered. I am leaning toward crappy aftermarket parts. but maybe this time around i can get them to work. Ive dabbled with snowmobiles, motorcyles,and quads since i was 12 years old. not saying im an expert but i know the basics. ive never ever had such a hard time with a set of carbs.
  3. chacal
    Yes there are! The HSC32 Hitachi carbs vent the bowls back thru the "air compensator jets" into the airbox boots....that's why overflowing bowls will drain back into the airbox. The later HSC33 Hitachi carbs (700 air-cooled models) use seperate overflow tubes in-between each set of carbs.
    The Hitachi's are a closed, solid float. Haven't ever sacrificied a set of Mikuni floats yet, but I would assume that they are similar. NOTE: carb dip solution will eat the floats!
    Do NOT set the floats in this manner! Float "height" is a nebulous term since the end points aren't properly defined. Only AFTER setting one carb correctly, via the clear-tube gauge method, can you use that carb's measured "float height" as a basis for preliminary setting of the other carbs (assuming all of the other carbs are equipped with the same type needle and seats)......and again, this "float height" is a PRELIMINARY setting, you still need to measure the fuel levels via the clear-tube gauge method (and adjust as needed) these other three carbs; each one may end up requiring a slightly different float setting to get the desired results:
    Float HEIGHT sets the Fuel LEVEL:
    - When it comes time to Set the Float Height and thus the Fuel Level within the carb bowls, our advice is to get all the proper tools and fixtures ready, and then bribe someone who knows how to do it to come over and let them do this task for you!
    It's not rocket science, but it sure can be a messy, pain-in-the-butt, trial-and-error procedure.......especially if this is going to be your first fuel-level rodeo.
    If that's not possible, then read the manual and proceed accordingly. But please take the time to set the fuel levels correctly, not just by the float height measurements, but via the fuel level "sight tube gauge" method-----as the proper fuel level in the bowls is a critical issue in whether the carbs perform properly or not. NOTE that the "float height" measurement is just a "shortcut" method used to try to acquire the correct "fuel level" measurement, as it is the fuel level measurement and specification that must be met in order to insure that the carbs perform properly:
    * Fuel levels that are too low results in a lean mixture.
    * Fuel levels that are too high results in a rich mixture.
    In order to achieve the proper fuel level.....as measured by the "clear tube method" outlined in the service manuals......there obviously will be some particular "float height" that will achieve that FUEL LEVEL. But that actual float height can vary between various carbs due to a number of factors; for example, in the case of the Hitachi carbs, it also depends on which set of float valves and needles were originally installed by Hitachi (we've seen three different types in original carbs) AND which replacement style of needles and seats that you purchased. The factory specified "float height" is for an original carb, using the original float needle seats and valves, which may no longer be available for your bike.
    The float height determines what the fuel level within the bowl will be (since the float height determines when the float valve needle assembly "cuts off" fuel flow from the gas tank into the carb bowl), and thus an adjustment to the float height is how you adjust the fuel level. The float height is adjusted by very small amounts of bending the float TANG ARM on the float supporting structure. This tang is the central metal "arm" that contacts and supports----via the little float needle clip - hook (on most models)----the float needle itself. You would bend this tang down (away from the needle) to raise the float height (and thus raise the fuel level in the bowl), or you would bend this tang upward (towards the needle) to lower float height (and this will lower the fuel level in the bowl).
    Please note that although you typically are messing around with the float height and adjusting that tang WHILE THE CARBS ARE UPSIDE DOWN----so you can easily access the floats----the descriptive actions such as "downward" and "upward" that you may read about in various manuals are describing such directional movements in relation to the normal orientation of the carbs as on the bike! THIS CAN BE INCREDIBLY CONFUSING WHEN YOU FIRST START PERFORMING THIS ADJUSTMENT PROCESS!!!
    Also note that the fuel level check (with the sight tube gauge) must be done with the carbs oriented in the same manner as if they were installed on the bike, meaning perfectly level from side-to-side (you'll want to use a bubble-glass level to make sure they are perfectly level) and completely "vertical". NOTE: the "vertical" orientation confuses some people, as the carbs, when installed on the bike, are actually tilted a bit forward from true vertical in the normal riding position. However, when checking the fuel level with the sight tube gauge, the carbs should be in both a horizontally and vertically level orientation.
    Here are some other useful hints, culled from the factory service manual, regarding how to prepare yourself for the correct check of the float height measurement:
    - Hold the carb in an upside down position.
    - Incline the carb at 60-70-degrees so that the end of the float valve does not hang down as a result of the float weight.
    - Measure the distance from the mating surface of the chamber without the gasket in place, to the top of the float.
    - NOTE: the float should be just resting on, but not depressing, the spring loaded inlet needle.
    Well, okay! Now, although you may not have noticed it immediately, there is a very important and very cryptic passage in the above set of instructions, which is this:
    "Measure the distance from the mating surface of the chamber without the gasket in place, to the top of the float."
    The "mating surface" is, of course, the bottom of the carb body (where the float bowl gasket would be located) but without the gasket in place.......check. But the next part......the "to the top of the float" bit......well, that's a bit more mysterious, because:
    a) of course, as it with the "direction warning" issued earlier, the "top of" the floats, when viewed with the carbs being upside down in your hands (which is the only way to perform such measurements), is actually the physical bottom of the floats!
    Told you this would get interesting.......
    But that little detail aside, now we have to explore the more challenging part of that statement, which is "what and where, exactly, is the "top" of this bottom of the float?"
    This simple question is, unfortunately:
    a) ]not[/b] so easy to answer, and.....
    b) varies by which carb model you are holding, upside down, in your hands and trying to measure..........
    For some models, the information as to exactly WHERE to perform this measurement at the float is either not known, or incredibly confusing.....and the factory service manuals are not much of a help in this regard, what with their tiny, grainy images. It seems as though Yamaha wanted people to focus on the fuel level setting (of course, as that is the end result you're actually shooting for), and figured it wasn't worth the trouble or effort to go over the float-height-measurement procedures necessary to achieve that--------rather, they tell you what fuel level measurement to acquire, and then tell you to just "bend that tang arm" and re-measure the fuel level and just keep going back-and-forth until you get it right! And then do that messy, smelly, spill-gas-all-over-yourself with this trial-and-error procedure three more times.........
    Three Blind Carbs: See How It's Done:
    Because of all the considerations mentioned previously, and due to the importance of getting this job done once, and done correctly, the procedure that we suggest you follow is to work on achieving the proper FUEL LEVEL in any one carb.......so, install the needle and seat, install the float, fill the bowl with fuel, and measure the fuel level (although the factory gives a rather wide range of acceptable fuel level limits, such as 3mm +/- 1mm----in other words, anywhere from 2mm to 4mm----we feel that you should always strive to get that fuel level right in the center of the range (in the above example, right at 3mm).
    You'll do this by very slight bending of that central float tang arm (the one that the needle clip fits over) until you get the measured fuel level (drain and measure a couple of times, to be sure!) that it's correct.
    Now, since you know that this one carb fuel level is correct, and if you're using the same float seats and needles in all the other carbs, then simply measure the "float height" of this now known good carb.....and, you can "measure" that height in any way and at any point that you desire, preferably whatever measurement is the most consistent to perform and the easiest to see.......and then that becomes your "float height" for all of the other carbs, too. Just adjust the other float tang arms to achieve that same unique "float height", and you're done!
    BUT, I would still fill and measure each individual carb and check the fuel level, just to be sure, before you install them on the bike!
    The above may seem like a more time-consuming and "tedious" way of doing things, but it is the only way that we know of to make CERTAIN that your fuel levels are correct........rather than having a "correct" float height.......and as we stated earlier, it is the fuel level that is the end result that you're seeking, not any particular float height (except for the necessary float height needed to get to that proper fuel level, of course!).
    The proper FUEL LEVEL is a vastly over-looked, but vitally important part of having your carbs perform properly, as improper fuel levels WILL result in either lean or rich fuel mixtures, and will most likely tempt you to try to "compensate" for such a situation by other, NON-NECESSARY and perhaps COUNTER-PRODUCTIVE changes in other circuits or carb settings, which may affect and degrade other areas of the engine performance. IT IS ALWAYS BEST TO ADDRESS AND SOLVE THE "ROOT" PROBLEMS (or, to put it another way, to FOLLOW PROPER PROCEDURES AND ACHIEVE PROPER SETTINGS) in all of the basic areas.
    This method will allow you to actually save time, money, effort, and achieve more accurate, consistent, and reliable results!
    Fuel Level Cheat Sheet:
    Hitachi all HSC32 series models:
    -Fuel level measured via the clear-tube gauge: 3mm +/- 1mm (.12 +/- .04 inches)
  4. wingnut325
    wingnut325 Member
    I did notice one thing that may or may not be pertinent. When using the aftermarket valve needles that are 1 mm longer than stock the tang is much closer to the fulcrum point when the levels are correct. I think this effects the gain on the adjustment meaning a little goes a long way. One way to counteract this is to use the thinner fiber seat gaskets which has the effect of lowering the seat. If you use the copper thick crush gaskets it compounds the longer needle issue and maybe affecting the amount of closure force being applied to the needle during normal static conditions. Just throwing some stuff against the wall so to speak and would like to hear your thoughts.
  5. snayke62
    snayke62 Member
    Illinois
    I can see your logic in the longer needles affecting closing pressure. chacal, i understand your post but have only one question----float level via clear tube method spec is 3mm +/- 1mm. at what reference point to compare to- i see somewhere here that it was to the bowl mating surface-is this correct?
  6. Foxman48
    Foxman48 New Member
    Calgary, Alberta Canada
    Check the seats are a real snug fit in the carb bodies. maybe fuel is getting past one of the seats. It happened to me. There is an O-ring lubricant on the market that will SLIGHTLY swell the orings and provide a better seal in this area. These leaks can be a mother%$#*(& to find. You will learn a lot about carbs and fuel systems. Let us know what solves the problem.
  7. chacal
    The reference point for the clear-tube gauge is the bottom of the carb body itself....where the top edge of the bowl "disappears" up into the carb body.
  8. bill
    bill Active Member
    Raleigh, NC
    I didn't say they weren't vented but that there were no external or dedicated vent tubes. As you point out the vent is actually an air jet not a separate vent. Of course your answer was way more complete than mine :)
    Original question...
    Interesting about the floats they are so light it is hard to tell. I have had issues with hollow floats in the past, not fun to find sometimes.
  9. snayke62
    snayke62 Member
    Illinois
    okay boys.....i been messing with these carbs for ten hours now. i tried the shim the floats endplay idea. i have polished the seats. i even found a float that was bent and bottoming out. i made damn sure the screen/ o-ring was in and seated correctly when installing the seats. i polished the float axle and inside the float axle housing. the washer that seals the seats are good. every time i connect the carb set to remote tank they leak. i have the clear tubes attached and can watch the fuel migrate to the air jets and out. it is an intermittant issue. one time 1 & 2 will overflow, other times 1 &4, other times 3&1, you get my point. The data has no pattern. i found that a slight tap will make them close. I was able to set the levels indevidually if i tapped constanly until the fuel level equalled out. After i set them and verified good a second time while tapping, i drained and let them fill up without tapping. overflow again. cant say which carb # because its irratic data. If i tap its okay. The seats are NOT leaking betwen the washer because a tap wouldnt fix that. My floats all float good in water. The geometry of the needle valve and float adjustment tang seems good-90 degrees angle when fully closed manually. Ive tried setting all carbs extremely lean with the same results. I went so lean that at one point i had all float valves adjusted closed-no fuel would flow through at all. I left each bowl off whlie i adjustd each one totally seperate flom the rest. My only concern was achieving the correct level using the clear tubes as a reference. I believe ive taken every step in order to safely say i need to get oem needle valves and seats. or at least a set that will that close. I can say that the reason i got new needle valves and seats in the first place was because i opened the carbs to find one needle different than the rest. the diffenrt needle valve would not seat and overflow that carb. the new needle valves i purchased were identical to the different needle that origanally leaked. oh yeah-if i hold the carb set upside down and blow through the inlet hose- the seats stay closed.all i can say is there is a problem with the needle valve sealing in the seats. i cant set the float levels right if tha bastard float valves wont close. jesus. I know where there is another 750 maxim------------think ill have to do a midnight carb swap and play stupid when they ask me whats wrong with their bike. haha not sure what else i can do.
  10. wizard
    It is the float valves, they are such a simple mechanism, almost primitive.
    You have got compatable needles & seats? If you hold the float up manualy does it stop the flow? sometiimes this will happen, the lift the float gets from the fuel is not quite enough pressure.
    I have had this, like you say you can get them to shut off by tapping the fuel bowl, what I found is the vibration when the engine is running is the same as tapping the bowl & you don't get the problem you have on the bench.
  11. snayke62
    snayke62 Member
    Illinois
    Agreed wizard.............before i read this post i said piss on it and installed the carbs after adjusted. The bike runs like a raped ape. its raining here and i had a hard time keeping the rear whell in traction. I only put 2 miles on it. i ve started it several tiimes in the garage. every time fires and idles. no leaks. i leave the airbox drain tube and the crackcase tube disconnected so the gas will go on the groung and not in the oiol. also i can tell right away if the carbs overflow. ive thought ive fixed the problem before only to be disapointed. it will run good for a while then all of a suddon--------leak. i will say that it is running better than before....as of now.
  12. snayke62
    snayke62 Member
    Illinois
    I hope yall can see the previous post okay.
  13. wingnut325
    wingnut325 Member
    Sounds like you have it fixed. Just keep an eye on the oil level. If it starts to go up in the window after a couple of rides check the oil for fuel contamination.
  14. bill
    bill Active Member
    Raleigh, NC
    Well sounds like progress - hopefully you have it cured....
  15. snayke62
    snayke62 Member
    Illinois
    I dont know if it made a difference or not, but what i did to dress the float valve seats was take a small, appropriate sized drill bit and twist it by hand into the seats. not to hard but enough to shine up and make the beveled area more noticeable as you look at it. If it leaks again ill have no choice but to buy different float valves. as i mentioned before i did shim the float end play with little tiny washers. this seemed to have no affect and after about to 40th time of assembling and disassembling i got tired of putting them in.
  16. snayke62
    snayke62 Member
    Illinois
    Update-----------I took the bike for about 10 miles. Longest trip so far since ive had it. Started and idles good. Runs good, has lots of power. Im actually suprised on the power. I think it needs about two more gears though. Anyway, no flooding yet. The true test will be when i fill the tank with fuel. This bike seems like a nice one. I want to keep it but finances are low. If it dont leak again i will re-paint the engine black. I think ill ask $1200 if it all goes good. Yall think thats reasonable?
