Would this gauge work good for carb syncing?
Discussion in 'Hangout Lounge' started by Piersol, Jun 26, 2007.
  1. Piersol
    Piersol Member
    Red Lake Falls, MN U.S.A.
  2. vinco
    vinco Member
    Hot Springs, Arkansas
    Should work better - I'll let you know in a couple of days after I get my carbs back on. I bought 2 liquid-filled combination pressure/vacuum gauges with 2.5" dial from my local Grainger supply house the other day for $18 apiece - no shipping or waiting. Look up Grainger online to find the nearest location to you.
  3. Robert
    Not a bad choice, they should do nicely. You still may need to create the dampers to get it stable. Another means of damping could be a needle valve from an old fish aquarium set up. The thumb screw would close off the passage with a very fine pitch thread. Should give you plenty of control. The gauges I got from JC Whitney have plastic valves, check out McMaster Carr as well.
  4. Polock
    get a short length of hose (2 inches) that fits your gauge
    roll up a chunk of paper towel and jam it in the hose
    use that to connect the gauge, it might take a few tries, thats why the hose is
    short, shove it out and try again
    2 or 3 tries and you'll have it, thinking 5 to 10 is the range you need
  5. vinco
    vinco Member
    OK, so the liquid-filled gauges flutter like a moth on crack. You'll still need some kind of dampening to get anything like a steady reading.
  6. TaZMaNiaK
    TaZMaNiaK Member
    NJ
    Wish I had seen this sooner, could've saved you the $.. Liquid filled gauges only damp external vibration/shock movement of the needle, not rapid fluctuations in the vacuum/pressure source. Glycerin is just not viscous enough and the surface area of the needle isn't large enough to create the necessary drag. You will still need a damper, or use a mercury/oil manometer (a 4 column manometer is the best way, because you can see at a glance that the carbs are pulling the same vacuum without having to messs with switches or comparing readings)
